VLC picture is too late to be displayed
In Deepstream pipeline: I use yolov3 model (batchsize 16) in nvinfer,and sink is rtmpsink;
the stream server is nginx with http-flv model.
when camera is 1 the stream is good
when camera is 8 the stream is warn by VLC:picture is too late to be displayed … ;and Viewing the stream through the browser is stuck。Is it processed at the push end to make the video stream smoother or at the playback end?
• DeepStream Version5.0
• TensorRT Version
did you boost Jetson device clock?
$ sudo nvpmodel -m --for MAX perf and power mode is 0
$ sudo jetson_clocks
do you run with deepstream-app , or deepstream application?
if deepstream-app, you can use “export NVDS_ENABLE_COMPONENT_LATENCY_MEASUREMENT=1” to check the plugin latency.
if deepstream application, refer to Slow real-time performance when running custom YOLOv3 app - #7 by mchi to measure the output fps
