vLLM for Inference with 2 sparks example - WARNING 06-28 14:18:56 [ray_utils.py:556] Tensor parallel size (2) exceeds available GPUs (1)
Im trying run
https://build.nvidia.com/spark/vllm/stacked-sparksI’m getting this error when doing
and getting error below .. help is appreciated…
Step 7 .
Launch inference server for Llama 3.3 70B (EngineCore pid=10887) WARNING 06-28 14:18:56 [ray_utils.py:556] Tensor parallel size (2) exceeds available GPUs (1). This may result in Ray placement group allocation failures. Consider reducing tensor_parallel_size to 1 or less, or ensure your Ray cluster has 2 GPUs available.
the ray cluster setup seems okay
docker exec $VLLM_CONTAINER ray status
Found container: node-24211
======== Autoscaler status: 2026-06-28 13:34:00.779768 ========
Node status
Active:
1 node_9b9e1770e796da8891d58fb9275c441526d421e54c27cd72d32aeec1
1 node_2de6e46c1631adf48688e7c64afec64bb08a8cc8eb2aac1daaa3c695
Pending:
(no pending nodes)
Recent failures:
(no failures)
Resources
Total Usage:
0.0/40.0 CPU
0.0/2.0 GPU
0B/223.69GiB memory
0B/19.46GiB object_store_memory
==== worker node seems ok
./start_ray_worker_node.run
Worker IP: 169.254.248.205, connecting to head node at: 169.254.82.91
2026-06-28 13:22:55,231 INFO scripts.py:1128 – Local node IP: 169.254.248.205
2026-06-28 13:22:56,425 SUCC scripts.py:1144 – --------------------
2026-06-28 13:22:56,425 SUCC scripts.py:1145 – Ray runtime started.
2026-06-28 13:22:56,425 SUCC scripts.py:1146 – --------------------
2026-06-28 13:22:56,425 INFO scripts.py:1148 – To terminate the Ray runtime, run
2026-06-28 13:22:56,425 INFO scripts.py:1149 – ray stop
2026-06-28 13:22:56,425 INFO scripts.py:1159 – --block
2026-06-28 13:22:56,426 INFO scripts.py:1160 – This command will now block forever until terminated by a signal.
2026-06-28 13:22:56,426 INFO scripts.py:1163 – Running subprocesses are monitored and a message will be printed if any of them terminate unexpectedly. Subprocesses exit with SIGTERM will be treated as graceful, thus NOT reported.
2026-06-28 13:22:56,426 INFO scripts.py:1168 – Process exit logs will be saved to: /tmp/ray/session_2026-06-28_13-21-29_344563_1/logs/ray_process_exit.log
-- head node
docker exec -it $VLLM_CONTAINER /bin/bash -c ’
vllm serve meta-llama/Llama-3.3-70B-Instruct
–tensor-parallel-size 2 --max-model-len 2048
–distributed-executor-backend ray’
(APIServer pid=10692) INFO 06-28 14:18:46 [utils.py:299]
(APIServer pid=10692) INFO 06-28 14:18:46 [utils.py:299] █ █ █▄ ▄█
(APIServer pid=10692) INFO 06-28 14:18:46 [utils.py:299] ▄▄ ▄█ █ █ █ ▀▄▀ █ version 0.20.1+7124b12a.dev
(APIServer pid=10692) INFO 06-28 14:18:46 [utils.py:299] █▄█▀ █ █ █ █ model meta-llama/Llama-3.3-70B-Instruct
(APIServer pid=10692) INFO 06-28 14:18:46 [utils.py:299] ▀▀ ▀▀▀▀▀ ▀▀▀▀▀ ▀ ▀
(APIServer pid=10692) INFO 06-28 14:18:46 [utils.py:233] non-default args: {‘model_tag’: ‘meta-llama/Llama-3.3-70B-Instruct’, ‘model’: ‘meta-llama/Llama-3.3-70B-Instruct’, ‘max_model_len’: 2048, ‘distributed_executor_backend’: ‘ray’, ‘tensor_parallel_size’: 2}
(APIServer pid=10692) WARNING 06-28 14:18:46 [envs.py:1830] Unknown vLLM environment variable detected: VLLM_VERSION
(APIServer pid=10692) WARNING 06-28 14:18:46 [envs.py:1830] Unknown vLLM environment variable detected: VLLM_FLASH_ATTN_SRC_DIR
(APIServer pid=10692) INFO 06-28 14:18:51 [nixl_utils.py:20] Setting UCX_RCACHE_MAX_UNRELEASED to ‘1024’ to avoid a rare memory leak in UCX when using NIXL.
(APIServer pid=10692) WARNING 06-28 14:18:51 [nixl_utils.py:34] NIXL is not available
(APIServer pid=10692) WARNING 06-28 14:18:51 [nixl_utils.py:44] NIXL agent config is not available
(APIServer pid=10692) INFO 06-28 14:18:51 [model.py:555] Resolved architecture: LlamaForCausalLM
(APIServer pid=10692) INFO 06-28 14:18:51 [model.py:1680] Using max model len 2048
(APIServer pid=10692) WARNING 06-28 14:18:52 [vllm.py:831] Async scheduling will be disabled because it is not supported with the ray distributed executor backend.
(APIServer pid=10692) INFO 06-28 14:18:52 [vllm.py:840] Asynchronous scheduling is disabled.
(APIServer pid=10692) INFO 06-28 14:18:52 [kernel.py:205] Final IR op priority after setting platform defaults: IrOpPriorityConfig(rms_norm=[‘native’])
(EngineCore pid=10887) INFO 06-28 14:18:56 [core.py:109] Initializing a V1 LLM engine (v0.20.1+7124b12a.dev) with config: model=‘meta-llama/Llama-3.3-70B-Instruct’, speculative_config=None, tokenizer=‘meta-llama/Llama-3.3-70B-Instruct’, skip_tokenizer_init=False, tokenizer_mode=auto, revision=None, tokenizer_revision=None, trust_remote_code=False, dtype=torch.bfloat16, max_seq_len=2048, download_dir=None, load_format=auto, tensor_parallel_size=2, pipeline_parallel_size=1, data_parallel_size=1, decode_context_parallel_size=1, dcp_comm_backend=ag_rs, disable_custom_all_reduce=False, quantization=None, quantization_config=None, enforce_eager=False, enable_return_routed_experts=False, kv_cache_dtype=auto, device_config=cuda, structured_outputs_config=StructuredOutputsConfig(backend=‘auto’, disable_any_whitespace=False, disable_additional_properties=False, reasoning_parser=‘’, reasoning_parser_plugin=‘’, enable_in_reasoning=False), observability_config=ObservabilityConfig(show_hidden_metrics_for_version=None, otlp_traces_endpoint=None, collect_detailed_traces=None, kv_cache_metrics=False, kv_cache_metrics_sample=0.01, cudagraph_metrics=False, enable_layerwise_nvtx_tracing=False, enable_mfu_metrics=False, enable_mm_processor_stats=False, enable_logging_iteration_details=False), seed=0, served_model_name=meta-llama/Llama-3.3-70B-Instruct, enable_prefix_caching=True, enable_chunked_prefill=True, pooler_config=None, compilation_config={‘mode’: <CompilationMode.VLLM_COMPILE: 3>, ‘debug_dump_path’: None, ‘cache_dir’: ‘’, ‘compile_cache_save_format’: ‘binary’, ‘backend’: ‘inductor’, ‘custom_ops’: [‘none’], ‘ir_enable_torch_wrap’: True, ‘splitting_ops’: [‘vllm::unified_attention_with_output’, ‘vllm::unified_mla_attention_with_output’, ‘vllm::mamba_mixer2’, ‘vllm::mamba_mixer’, ‘vllm::short_conv’, ‘vllm::linear_attention’, ‘vllm::plamo2_mamba_mixer’, ‘vllm::gdn_attention_core’, ‘vllm::gdn_attention_core_xpu’, ‘vllm::olmo_hybrid_gdn_full_forward’, ‘vllm::kda_attention’, ‘vllm::sparse_attn_indexer’, ‘vllm::rocm_aiter_sparse_attn_indexer’, ‘vllm::deepseek_v4_attention’, ‘vllm::unified_kv_cache_update’, ‘vllm::unified_mla_kv_cache_update’], ‘compile_mm_encoder’: False, ‘cudagraph_mm_encoder’: False, ‘encoder_cudagraph_token_budgets’: , ‘encoder_cudagraph_max_vision_items_per_batch’: 0, ‘encoder_cudagraph_max_frames_per_batch’: None, ‘compile_sizes’: , ‘compile_ranges_endpoints’: [2048], ‘inductor_compile_config’: {‘enable_auto_functionalized_v2’: False, ‘combo_kernels’: True, ‘benchmark_combo_kernel’: True}, ‘inductor_passes’: {}, ‘cudagraph_mode’: <CUDAGraphMode.FULL_AND_PIECEWISE: (2, 1)>, ‘cudagraph_num_of_warmups’: 1, ‘cudagraph_capture_sizes’: [1, 2, 4, 8, 16, 24, 32, 40, 48, 56, 64, 72, 80, 88, 96, 104, 112, 120, 128, 136, 144, 152, 160, 168, 176, 184, 192, 200, 208, 216, 224, 232, 240, 248, 256, 272, 288, 304, 320, 336, 352, 368, 384, 400, 416, 432, 448, 464, 480, 496, 512], ‘cudagraph_copy_inputs’: False, ‘cudagraph_specialize_lora’: True, ‘use_inductor_graph_partition’: False, ‘pass_config’: {‘fuse_norm_quant’: False, ‘fuse_act_quant’: False, ‘fuse_attn_quant’: False, ‘enable_sp’: False, ‘fuse_gemm_comms’: False, ‘fuse_allreduce_rms’: False}, ‘max_cudagraph_capture_size’: 512, ‘dynamic_shapes_config’: {‘type’: <DynamicShapesType.BACKED: ‘backed’>, ‘evaluate_guards’: False, ‘assume_32_bit_indexing’: False}, ‘local_cache_dir’: None, ‘fast_moe_cold_start’: False, ‘static_all_moe_layers’: }, kernel_config=KernelConfig(ir_op_priority=IrOpPriorityConfig(rms_norm=[‘native’]), enable_flashinfer_autotune=True, moe_backend=‘auto’)
(EngineCore pid=10887) 2026-06-28 14:18:56,749 INFO worker.py:1814 – Connecting to existing Ray cluster at address: 169.254.82.91:6379…
(EngineCore pid=10887) 2026-06-28 14:18:56,756 INFO worker.py:2003 – Connected to Ray cluster. View the dashboard at http://127.0.0.1:8265
Thank you for bringing this up. I will ask the team to investigate and update the playbook if needed.
In the meantime, you can check out the opensource community vllm container here: GitHub - eugr/spark-vllm-docker: Docker configuration for running VLLM on dual DGX Sparks · GitHub
That works for me. Thank you !!!
