vLLM returns 400 error for tool_choice="auto" when called from OpenClaw (Qwen3.5-35B on NVIDIA Spark GB10)
Title:
vLLM returns 400 error for tool_choice="auto" when called from OpenClaw (Qwen3.5-35B on NVIDIA Spark GB10) [vLLM][Tool Calling]
Hello everyone,
I hope you are doing well. I am currently experimenting with running a local LLM inference server on an NVIDIA Spark GB10 using vLLM and Qwen3.5-35B. I encountered an issue related to tool calling when the model is accessed from OpenClaw, and I would really appreciate any guidance from the community.
System Environment
Hardware
  • System: NVIDIA Spark GB10
  • GPU Memory: 128GB
  • Storage: 4TB SSD
Model Server
  • Framework: vLLM
  • Docker Image: vllm/vllm-openai:latest
  • Model: Qwen/Qwen3.5-35B-A3B
  • API Mode: OpenAI-compatible API
Client
  • OpenClaw (running on a separate machine)
Network Topology
OpenClaw Client  --->  vLLM Server (Spark GB10)
                      Port 8000
vLLM Deployment Command
docker run -d \
--name vllm-qwen35b \
--gpus all \
--ipc=host \
-p 8000:8000 \
-e OMP_NUM_THREADS=16 \
-e VLLM_WORKER_MULTIPROC_METHOD=spawn \
-v ~/.cache/huggingface:/root/.cache/huggingface \
vllm/vllm-openai:latest \
Qwen/Qwen3.5-35B-A3B \
--served-model-name qwen35b \
--host 0.0.0.0 \
--tensor-parallel-size 1 \
--gpu-memory-utilization 0.85 \
--max-model-len 8192 \
--max-num-seqs 256 \
--max-num-batched-tokens 32768 \
--block-size 16 \
--enable-chunked-prefill \
--disable-log-stats \
--enable-auto-tool-choice \
--tool-call-parser hermes
Verification
The vLLM server starts normally. Example log excerpt:
version 0.17.0
model Qwen/Qwen3.5-35B-A3B
enable_auto_tool_choice: True
tool_call_parser: hermes
max_model_len: 8192
Basic API test works:
GET /v1/models
returns:
 "data":[
   {"id":"qwen35b"}
Problem
When OpenClaw sends a request with tool_choice="auto" to the vLLM server, the following error occurs:
run error: 400 "auto" tool choice requires --enable-auto-tool-choice and --tool-call-parser to be set
connected | error
agent main | session main (openclaw-tui) | vllm/qwen35b | tokens ?/16k
However, both parameters are already set in the startup command:
Expected Behavior
The server should accept requests with:
tool_choice = "auto"
and allow tool calling through the OpenAI-compatible API.
Actual Behavior
The server returns HTTP 400 with the message:
even though both parameters are enabled.
Questions
  1. Is hermes the correct --tool-call-parser for Qwen3.5 models in vLLM?
  2. Should another parser (for example qwen3_xml or openai) be used instead?
  3. Could the issue be caused by request formatting differences from OpenClaw?
Additional Information
If needed, I can also provide:
  • The exact HTTP request payload sent by OpenClaw
  • Full vLLM logs
  • Docker environment details
  • GPU utilization information
Thank you very much for your time and assistance.
Additional info for context:
  • vLLM version: 0.17.0
  • Model: Qwen3.5-35B-A3B
  • Hardware: NVIDIA Spark GB10, 128GB GPU memory
  • Docker deployment works; /v1/models endpoint returns correctly
  • The 400 error only occurs when OpenClaw sends requests with “tool_choice”: “auto”
  • Minimal test request to reproduce:
curl -X POST http://<VLLM_IP>:8000/v1/chat/completions
-H “Content-Type: application/json”
-d ‘{
“model”: “qwen35b”,
“messages”: [{“role”: “user”, “content”: “Hello”}],
Error received:
400 “auto tool choice requires --enable-auto-tool-choice and --tool-call-parser to be set”
The example on HuggingFace uses --tool-call-parser qwen3_coder:
Tool Call: To support tool use, you can use the following command.
vllm serve Qwen/Qwen3.5-35B-A3B --port 8000 --tensor-parallel-size 8 --max-model-len 262144 --reasoning-parser qwen3 --enable-auto-tool-choice --tool-call-parser qwen3_coder
