can you share VM to VM ASAP2 performance numbers with dpdk pktgen inside the VM
Related topics
| connectx-5 SR-IOV ASAP2 100G performance evaluation using VM's | 1 | 518 | April 3, 2019 | |
| Bench marking of DPDK-OVS with Mellanox ASAP2. | 3 | 424 | April 30, 2019 | |
| Hi I am using Mellanox connectx-5 100GbE Nic card. When i tried to run ASAP2 OVS offload, I have observed followings | 0 | 398 | February 10, 2020 | |
| OVS-DPDK Offloading VXLAN,run testpmd on VM,Tx-pps can reach 8.9Mpps, but Rx-pps only 0.7Mpps | 5 | 1459 | November 9, 2020 | |
| CentOS 7 KVM-SR-IOV Performance? | 12 | 1333 | January 10, 2017 | |
| DPDK/VMA | 4 | 1113 | July 31, 2016 | |
| The bandwidth of of virtual ethernet over PCIe between two xaviers is low | 91 | 11261 | July 30, 2020 | |
| Mellanox NIC’s Throughput Test using two Hostsn | 1 | 672 | August 29, 2023 | |
| Pinging between KVM guests using IPOIB over Virtual Functions. | 1 | 868 | January 14, 2020 | |
| Can't get RDMA working on a KVM-VM on AMD Epyc cores. | 4 | 1731 | March 18, 2020 |
