VMA error
I get segmentation fault on SLES using LD_PRELOAD=libvma.so . I don’t have this problem using Centos/RHEL
VMA ERROR: Segmentation Fault
[tid: 23416] ------ printf_backtrace ------
[1] 0x7fe4c5330e1c: /usr/lib64/libvma.so:()
[2] 0x7fe4c2cce046: /opt/dotnet/shared/Microsoft.NETCore.App/1.1.1/libcoreclr.so:()
[3] 0x7fddcc5045b6: /opt/dotnet/shared/Microsoft.NETCore.App/1.1.1/libclrjit.so:()
[4] 0x7fe4c4e29870: /lib64/libpthread.so.0:()
[5] 0x7fe4c529d90b: /usr/lib64/libvma.so:ring_allocation_logic::should_migrate_ring()
[6] 0x7fe4c52ed8a8: /usr/lib64/libvma.so:dst_entry::try_migrate_ring(lock_base&)
[7] 0x7fe4c530a7b8: /usr/lib64/libvma.so:sockinfo_tcp::ip_output(pbuf*, void*, int)
[8] 0x7fe4c52d0212: /usr/lib64/libvma.so:tcp_output()
[9] 0x7fe4c52cc999: /usr/lib64/libvma.so:tcp_slowtmr()
Killed
Hi Oskar,
There are several things that can cause a Segmentation Fault:
  1. Which application you are trying to run with libvma.so?
Note that Netcat with VMA on SLES 11 SP1 does not function.
  1. There is also a known NetPIPE bug - Netpipe is trying to access read-only memory and there is Segmentation fault on NetPIPE exit- the solution is to upgrade to NetPIPE 3.7 or later.
  2. Directing VMA to access non-valid memory area will cause a segmentation fault.
  3. There was a segmentation fault issue in vma_stats when exceeding fds string length that was discovered in 8.0.4 and was fixed in VMA 8.1.7.
  4. There was a segmentation fault issue when running with CTL_THREAD_NO_WAKEUP - was discovered in 8.0.4 and was fixed in VMA 8.1.7.
Regards,
Viki
