I’m getting the following error when I run vma_stats. I just re-installed VMA after I had a similar issue. Now I just re-installed and I have no clue what this means. Any ideas?
vma_stats
vmastat: Version faf1dc67b1d47be83a0b5da469894aa0 is not compatible with stats protocol version d
As far as I can tell the VMA version matches the VMA Stats 7.0.14-0. Any Idea what could be going wrong?
vma_stats --version
vmastat: Linked with VMA version: 7.0.14.0
vmastat: Revision: 1
/home/mst/run_mlnx_helper.sh
VMA INFO: ---------------------------------------------------------------------------
VMA INFO: VMA_VERSION: 7.0.14-0 Release built on Jan 28 2016 20:51:14
VMA INFO: Cmd Line: taskset -c 0 /home/mst/bin/test1 --cfg /home/mst/test.cfg
VMA INFO: OFED Version: MLNX_OFED_LINUX-3.2-1.0.1.1:
VMA INFO: Log Level INFO [VMA_TRACELEVEL]
VMA INFO: Ring allocation logic TX 20(Ring per thread) [VMA_RING_ALLOCATION_LOGIC_TX]
VMA INFO: Ring allocation logic RX 20(Ring per thread) [VMA_RING_ALLOCATION_LOGIC_RX]
VMA INFO: Rx Mem Bufs 16777216 [VMA_RX_BUFS]
VMA INFO: Rx QP WRE 1600000 [VMA_RX_WRE]
VMA INFO: Rx Poll Loops -1 [VMA_RX_POLL]
VMA INFO: Select Poll (usec) -1 [VMA_SELECT_POLL]
VMA INFO: Select Poll OS Ratio Disabled [VMA_SELECT_POLL_OS_RATIO]
VMA INFO: Select Skip OS Disabled [VMA_SELECT_SKIP_OS]
VMA INFO: CQ Drain Thread Disabled [VMA_PROGRESS_ENGINE_INTERVAL]
VMA INFO: CQ Interrupts Moderation Disabled [VMA_CQ_MODERATION_ENABLE]
VMA INFO: CQ Adaptive Moderation Disabled [VMA_CQ_AIM_INTERVAL_MSEC]
VMA INFO: QP Compensation Level 16384 [VMA_QP_COMPENSATION_LEVEL]
VMA INFO: Internal Thread Affinity 0 [VMA_INTERNAL_THREAD_AFFINITY]
VMA INFO: Cmd Line: /home/mst/bin/test1 --cfg /home/mst/test.cfg
