I have been trying to use the latest vMaterials with the version of Visualize that comes with SolidWorks Maker Edition.
At work, I have successfully installed and used vMaterials 2.4 with SOLIDWORKS(R) Visualize Standard 2024 SP5, 32.5.0.48.
At home, I have SOLIDWORKS(R) Visualize Connected 2025 SP2, 33.2.0.128, 3DEXPERIENCE R2025x HotFix 2.7. I am having the following problem:
Trying to use any MDL from this library results in an error message:
To summarize: any attempt to import any member of ::nvidia::core_definitions fails.
This error is consistent across multiple uninstalls, reinstalls, and repair installs.
While I do not have the exact error noted, I did also at one point try to install vMaterials 1.7, and it gave a different but related error; I could try that again and look it up, if needed.
Is there a version of vMaterials that is known to work with this version of Visualize?
UPDATE: Something that may be relevant: I’ve discovered that Visualize used to support three choices of rendering engine: nVidia IRay, 3DS Stellar Physically Correct, and AMD Radeon ProRender. Starting with the 2025 version, support for IRay has been discontinued and Stellar is the new default. I haven’t been able to confirm, but it seems possible that IRay used to be the default renderer. Since MDL support is handled individually by each renderer (to my knowledge), it’s possible that MDL support in Stellar (and ProRender, which I tested just now and experienced the exact same problems with as described above) lags behind the level of support in IRay.
