Hi
I have problems on adding a vgpu on a vmware vm. The vm had enabled VBS (Virtual Based Security). I have disabled it, but anyway I get the message, that VVTD (Intel Virtualization Technology for Directed I/0) is not supported.
On a fresh clean vm I can add the vpu.
How could I disable that VVTD on that vm?
Thanks, I disabled Intel VT-D in BIOS but still got this message. So I searched the setting in the VM settings via the vSphere Client but found nothing. The vmx file can be found using “find /vmfs/volumes/ | grep vmx$” on the vSphere server command line.
