VNC keyboard layout (Jetson Nano 4GB)
I have a Jetson Nano 4GB and i would like to use VNC to access it.
It works, but i get a qwerty keyboard layout, instead german qwertz layout.
For ssh connections everything is ok, and i configured german keyboard during initial setup, and if i connect it directly via USB it also works.
I used several VNC clients, which all are working with other remote systems, like Raspberry Pi.
I know there already are several threads about this problem here, but i did not find any solution for this problem in any of them. :(
Nobody out there who is using VNC ?
Problem solved: https://knowledgebase.nomachine.com/AR02R01074
Works perfectly and smooth. Of course keyboard is also working as expected. :)
Glad to know you found the solution. Thanks for sharing!
