VNC server on TK1
I’m having trouble getting tightVNCserver work on TK1.
Ive installed ubuntu-desktop and tightvncserver on TK1, and open session in the easiest way:
$tightvncserver -nolisten tcp :1
but when I login it from remote pc via tightvnc - client, I dont see my TK1 desktop, only gray window :(
Can anyone share a way how to do it?
This is a known issue with this VNC server on Ubuntu.
Have you tried the package x11vnc ?
configuration file for startup:
/etc/init/x11vnc.conf
start on login-session-start
script
/usr/bin/x11vnc -xkb -noxrecord -noxfixes -noxdamage -auth /var/run/lightdm/root/:0 -display :0 -passwd “” -forever -bg -o /var/log/x11vnc.log
end script
Best Regards,
Peter Bauer
http://bitkistl.blogspot.com
Just to add - I log in through Putty, run x11vnc and then use the IP::Port to log-in via tightvnc and that works well. I did add x11vnc to the startup programs but it doesn’t seem to be working, so go this route via SSH first. I’m a relative newbie to this so I’m sure there are better ways, but this one works for me.
Cheers,
coanda
I installed x11vnc then got in through realvnc viewer using the name it generated. Thanks for the tip!
you may as well consider x2goserver as a more performative solution comparing with vnc
