VOC format
I have created my dataset on roboflow and export it to PASCAL VOC format. I successfully trained it on the ultralytics web site and export in onnx, I found out that the onnx model had just 1 output and the jetson inference onnx model used 2 of them.
So i tried to train my dataset with train_ssd.py but when i export it and launch detectnet, it doesn’t recongnize any drones.
Can you help me figure it out why
Thanks very much
Hi @antonin.morcrette, how many images are in your dataset and what accuracy was it trained to? You can run train_ssd.py with the --validate-mean-ap flag and it will compute the per-class accuracies for you. Did you try running detectnet on some test images from your dataset before the camera?
