I am showing an error with nvidia-smi.exe but have no idea of the purpose. UNder ‘Volatile GPU-Util’ I just have ‘ERR!’ This may be nothing or it may explain other issues I have. Not sure if this is related to the insufficient permissions problem below or not.
My Machine is Windows 7 (64bit) and NVIDIA version is 7.5. Card is Quadro 4000.
| NVIDIA-SMI 353.90 Driver Version: 353.90 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 Quadro 4000 WDDM | 0000:03:00.0 On | N/A |
| 36% 80C P12 N/A / N/A | 86MiB / 2048MiB | ERR! Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 4 C Insufficient Permissions N/A |
I am facing the same problem.
I have Cuda 7.5 installed on my server with Windows Server 2012 R2, and Nvidia Quadro K6000 GPU installed. It’s a 64 bit machine.
I can import theano, and nvidia-smi is showing GPU status.
But in nvidia-smi, Volatile GPU-Util shows ERR!
| 0 Quadro K6000 WDDM | 0000:08:00.0 Off | 40 |
| 26% 36C P8 21W / 225W | 357MiB / 11520MiB | ERR! Default |
| 0 32 C+G ...x86)\Google\Chrome\Application\chrome.exe N/A |
| 0 476 C+G C:\Windows\Explorer.EXE N/A |
| 0 620 C+G Insufficient Permissions N/A |
| 0 2924 C+G Insufficient Permissions N/A |
| 0 3040 C+G Insufficient Permissions N/A |
| 0 3568 C+G Insufficient Permissions N/A |
| 0 3804 C+G Insufficient Permissions N/A |
| 0 3828 C+G Insufficient Permissions N/A |
| 0 5036 C+G Insufficient Permissions N/A |
Please explain me why this is happening, and how to fix it.
Thanks in advance.
The uncorrected ECC error column showing 40 could be a sign that the on-board Quadro K6000 GPU memory is starting to fail. Try powering the system off and rebooting, and see if the utilization column propagates correctly. Also check that the PCI-E power connections to the card are all populated correctly and that the card is firmly seated in the motherboard you are using. If you have a spare GPU, place it in the same slot and see if the behavior follows the card or the motherboard.
