I am having my Models crashing on my RTX Pro 6000 despite reboots.
Error:
sudo dmesg | grep -i “NVRM: Xid”
[ 2146.678661] NVRM: Xid (PCI:b4a2:00:00): 48, An uncorrectable double bit error (DBE) has been detected on GPU in the framebuffer at physAddr 0x1246514e60 partition 5, subpartition 1.
[ 2146.678670] NVRM: Xid (PCI:b4a2:00:00): 171, GDDR, Uncorrectable DRAM error in FBPA 5 subpartition 1 physAddr 0x1246514e60
[ 2146.701859] NVRM: Xid (PCI:b4a2:00:00): 48, pid=3370, name=nvidia-cuda-mps, channel 0x00000002
[ 2146.723831] NVRM: Xid (PCI:b4a2:00:00): 48, pid=3298, name=VLLM::EngineCor, channel 0x00000003
[ 2146.748707] NVRM: Xid (PCI:b4a2:00:00): 48, pid=3298, name=VLLM::EngineCor, channel 0x00000004
[ 2146.771851] NVRM: Xid (PCI:b4a2:00:00): 48, pid=4632, name=VLLM::EngineCor, channel 0x00000005
[ 2146.781888] NVRM: Xid (PCI:b4a2:00:00): 48, pid=4632, name=VLLM::EngineCor, channel 0x00000006
[ 2146.784129] NVRM: Xid (PCI:b4a2:00:00): 48, pid=4632, name=VLLM::EngineCor, channel 0x00000007
[ 2146.786399] NVRM: Xid (PCI:b4a2:00:00): 48, pid=4632, name=VLLM::EngineCor, channel 0x00000008
[ 2146.788598] NVRM: Xid (PCI:b4a2:00:00): 48, pid=4632, name=VLLM::EngineCor, channel 0x00000009
[ 2146.790743] NVRM: Xid (PCI:b4a2:00:00): 48, pid=4632, name=VLLM::EngineCor, channel 0x0000000a
[ 2146.793012] NVRM: Xid (PCI:b4a2:00:00): 48, pid=4632, name=VLLM::EngineCor, channel 0x0000000b
[ 2146.795256] NVRM: Xid (PCI:b4a2:00:00): 48, pid=4632, name=VLLM::EngineCor, channel 0x0000000c
[ 2146.801855] NVRM: Xid (PCI:b4a2:00:00): 63, pid=3370, name=cuda-EvtHandlr, Row Remapper: New row (0x0000001246514e60) marked for remapping, reset gpu to activate.
[ 2146.818170] NVRM: Xid (PCI:b4a2:00:00): 154, GPU recovery action changed from 0x0 (None) to 0x4 (Drain and Reset)
technocrat@ubunturtx6000:~/llm4$ sudo dmesg | grep -i “NVRM: Xid”
technocrat@ubunturtx6000:~/llm4$ nvidia-smi -q -d ECC
==============NVSMI LOG==============
Timestamp : Mon May 25 13:54:09 2026
Driver Version : 580.126.20
CUDA Version : 13.0
Attached GPUs : 1
GPU 0000B4A2:00:00.0
ECC Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
SRAM Correctable : 0
SRAM Uncorrectable Parity : 0
SRAM Uncorrectable SEC-DED : 0
DRAM Correctable : 0
DRAM Uncorrectable : 1
Aggregate
DRAM Uncorrectable : 1215
SRAM Threshold Exceeded : No
Aggregate Uncorrectable SRAM Sources
SRAM L2 : 0
SRAM SM : 0
SRAM Microcontroller : 0
SRAM PCIE : 0
SRAM Other : 0
Channel Repair Pending : No
TPC Repair Pending : No
