Using the SDK volume rendering as an example Ive been looking at loading different datasets into the application, it seems they can only be loaded during startup of the app, is it possible to rewrite the loading code so it can be used throughout the program rather than just at the beginning and what limitations will that produce (if possible)
Related topics
Topic | Replies | Views | Activity | |
Volume ray casting | 2 | 1943 | November 29, 2009 | |
VolumeRender example in SDK | 0 | 2528 | July 17, 2008 | |
Running OpenGL and CUDA at the same time | 0 | 3305 | December 16, 2011 | |
Question about Volume Rendering & cudaArray (s) taking the SDK example, modifying to accept 16bi | 19 | 5772 | July 10, 2010 | |
OpenCL BETA Volume Rendering example. | 1 | 2134 | January 20, 2010 | |
Dynamic initialization | 2 | 1058 | October 3, 2015 | |
Is there a way to dynamically allocate constant memory? | 0 | 3861 | April 19, 2010 | |
Hardware frame-rate synchronisation? | 2 | 1623 | November 5, 2009 | |
CUDA - C# interop | 13 | 25060 | September 17, 2010 | |
Why volume render in SDK so CPU demanding? | 5 | 3362 | March 23, 2010 |
