I have to transcode a RTP VP8 encoded stream to a H264 stream. With this pipeline I have a “Floating point exception”:
gst-launch-1.0 udpsrc address=127.0.0.1 port=6789 ! application/x-rtp,encoding-name=VP8 ! rtpvp8depay ! queue ! omxvp8dec ! nvvidconv ! omxh264enc ! fakesink async=0 sync=0
Setting pipeline to PAUSED ...
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingPipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
NvMMLiteOpen : Block : BlockType = 278
TVMR: NvMMLiteTVMRDecBlockOpen: 5107: NvMMLiteBlockOpen
NvMMLiteBlockCreate : Block : BlockType = 278
TVMR: cbBeginSequence: 584: BeginSequence 1920x1088, bVPR = 0
TVMR: cbBeginSequence: 826: DecodeBuffers = 4
TVMR: cbBeginSequence: 850: Display Resolution : (1920x1080)
TVMR: cbBeginSequence: 851: Display Aspect Ratio : (1920x1080)
TVMR: cbBeginSequence: 1015: SurfaceLayout = 3
TVMR: cbBeginSequence: 1045: NumOfSurfaces = 8, InteraceStream = 0, InterlaceEnabled = 0, bSecure = 0, MVC = 0 Semiplanar = 1, bReinit = 1
Allocating new output: 1920x1088 (x 10), ThumbnailMode = 0
Framerate set to : 0 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Note that the vp8 decoding works, with this pipeline I can see the stream:
gst-launch-1.0 udpsrc address=127.0.0.1 port=6789 ! application/x-rtp,encoding-name=VP8 ! rtpvp8depay ! omxvp8dec ! nveglglessink async=0 sync=0
Can you help me?
Thank you, best regards.
Ivan
Hi DaneLLL,
thank you, but I still have problems:
if I put the plugin just after the omxvp8dec I have the same error:
gst-launch-1.0 udpsrc address=127.0.0.1 port=6789 ! application/x-rtp,encoding-name=VP8,clock-rate=90000,payload=126 ! rtpvp8depay ! queue ! omxvp8dec ! videoparse format=2 ! nvvidconv ! omxh264enc ! fakesink async=0 sync=0
===== MSENC =====
If I put it just after nvvidconv I still have errors:
gst-launch-1.0 udpsrc address=127.0.0.1 port=6789 ! application/x-rtp,encoding-name=VP8,clock-rate=90000,payload=126 ! rtpvp8depay ! queue ! omxvp8dec ! nvvidconv ! videoparse format=2 ! omxh264enc ! fakesink async=0 sync=0
ERROR: from element /GstPipeline:pipeline0/GstOMXVP8Dec-omxvp8dec:omxvp8dec-omxvp8dec0: Internal data stream error.
Additional debug info:
/dvs/git/dirty/git-master_linux/external/gstreamer/gst-omx/omx/gstomxvideodec.c(2779): gst_omx_video_dec_loop (): /GstPipeline:pipeline0/GstOMXVP8Dec-omxvp8dec:omxvp8dec-omxvp8dec0:
stream stopped, reason not-negotiated
Execution ended after 0:00:01.098222405
Setting pipeline to READY ...
TVMR: TVMRFrameStatusReporting: 3883: Closing TVMR Frame Status Thread -------------
TVMR: TVMRFrameDelivery: 3739: Closing TVMR Frame Delivery Thread -------------
TVMR: NvMMDecTVMRDestroyParser: 4290: NvAvpClose
TVMR: NvMMLiteTVMRDecBlockClose: 5263: Done
Setting pipeline to NULL ...
Freeing pipeline ...
The same happens also if I replace “videoparse format=2” with “videoconvert ! video/x-raw,format=I420 ! videoparse format=2”.
I which way I have to use this plugin?
Ivan
Please share your pipeline of running udp server. Should be similar to
[url]https://devtalk.nvidia.com/default/topic/1027423/jetson-tx2/gstreamer-issue-on-tx2/post/5225972/#5225972[/url]
Also suggest you consider Jetson Nano. It has latest r32.1 release and competitive price.
I can reproduce the error also with this udp server pipeline:
gst-launch-1.0 videotestsrc ! capsfilter caps=video/x-raw,width=1920,height=1080,framerate=30/1 ! nvvidconv ! omxvp8enc ! rtpvp8pay ! udpsink host=127.0.0.1 port=5000 &
I can see the stream with:
gst-launch-1.0 udpsrc address=127.0.0.1 port=5000 ! application/x-rtp,encoding-name=VP8 ! rtpvp8depay ! omxvp8dec ! nveglglessink async=0 sync=0
But I have the “Floating point exception” with the transcode pipeline:
gst-launch-1.0 udpsrc address=127.0.0.1 port=5000 ! application/x-rtp,encoding-name=VP8 ! rtpvp8depay ! queue ! omxvp8dec ! videoparse format=2 ! nvvidconv ! omxh264enc ! fakesink async=0 sync=0
===== MSENC =====
gst-launch-1.0 udpsrc address=127.0.0.1 port=5000 ! application/x-rtp,encoding-name=VP8 ! rtpvp8depay ! queue ! omxvp8dec ! nvvidconv ! videoparse format=2 ! omxh264enc ! fakesink async=0 sync=0
Execution ended after 0:00:00.080877802
Ivan
Somehow I cannot run your decoding pipeline on r21.5. I am able to run
$ gst-launch-1.0 udpsrc address=127.0.0.1 port=5000 ! application/x-rtp ! rtpvp8depay ! vp8dec ! videoparse format=2 ! omxh264enc ! fakesink
FYI.
I am using gstreamer 1.8 and not the r21.5 one version, so maybe this is the reason why you can’t run the decoding pipeline on “original” r21.5 (maybe due to the rtpvp8depay plugin version).
Anyway, will I have a hardware-accelerated transcoding with “vp8dec”? In the “Linux Driver Package Multimedia User Guide” it is suggested to use “omxvp8dec” with “nvvidconv” and “omxh264enc”.
Ivan
Please try
gst-launch-1.0 udpsrc address=127.0.0.1 port=5000 ! application/x-rtp,encoding-name=VP8 ! rtpvp8depay ! queue ! omxvp8dec ! <b>videoparse format=23 width=1920 height=1080</b> ! omxh264enc ! fakesink async=0 sync=0
vp8dec is a software deocder. In default Gstreamer 1.4.2, ‘rtpvp8depay ! omxvp8dec’ cannot be linked.
thank you, with this pipeline the transcoding is ok, but I don’t think it is hardware-accelerated. With both pipelines (udp-server and transcoding) I have high CPU usage (50%). Note that with the udp-server pipeline alone the CPU usage is about 20%.
Ivan
This is an optimal pipeline for TK1. Both omxvp8enc and omxvp8dec are hardware-accelerated. You may also consider other Jetson platforms to acquire good performance.
