VPI Fisheye Distortion Correction
Hi there,
May I know what is the maximum FOV allowed for the correction api in VPI. Does it work with fisheye with 180FOV.
Also, is it possible to achieve a correction with no pixel loss?
It’s recommended to give it a try.
You can see the document for the algorithm info below:
https://docs.nvidia.com/vpi/algo_ldc.html#algo_ldc_overview
Hi I have given it a try, but most of the pixel is loss, is it possible to undistort the image without any pixel loss (the result image will have a star shape)
Would you mind sharing the input/output image you got so we can check if this is expected?
