I want to install VPI pack in the docker container.Before this,I installed
opencv:
OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb
OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb
cuda:
cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb
cudnn:
libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb
finally,install the vpi:
vpi-lib-0.4.4-cuda10-aarch64-l4t.deb
Error occur:
Blockquote
root@6c0cbe58163b:~/host_sdk# dpkg -i vpi-lib-0.4.4-cuda10-aarch64-l4t.deb
(Reading database … 35607 files and directories currently installed.)
Preparing to unpack vpi-lib-0.4.4-cuda10-aarch64-l4t.deb …
Unpacking vpi (0.4.4) over (0.4.4) …
dpkg: dependency problems prevent configuration of vpi:
vpi depends on cuda-cufft-10-2 | libcufft-10-2 | cuda-cufft-10-5 | libcufft-10-5 | cuda-cufft-10-4 | libcufft-10-4 | cuda-cufft-10-3 | libcufft-10-3 | cuda-cufft-10-1 | libcufft-10-1 | cuda-cufft-10-0 | libcufft-10-0; however:
Package cuda-cufft-10-2 is not installed.
Package libcufft-10-2 is not installed.
Package cuda-cufft-10-5 is not installed.
Package libcufft-10-5 is not installed.
Package cuda-cufft-10-4 is not installed.
Package libcufft-10-4 is not installed.
Package cuda-cufft-10-3 is not installed.
Package libcufft-10-3 is not installed.
Package cuda-cufft-10-1 is not installed.
Package libcufft-10-1 is not installed.
Package cuda-cufft-10-0 is not installed.
Package libcufft-10-0 is not installed.
vpi depends on cuda-cudart-10-2 | cuda-cudart-10-3 | cuda-cudart-10-1 | cuda-cudart-10-0; however:
Package cuda-cudart-10-2 is not installed.
Package cuda-cudart-10-3 is not installed.
Package cuda-cudart-10-1 is not installed.
Package cuda-cudart-10-0 is not installed.
dpkg: error processing package vpi (–install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
vpi
