VPI Lens Correction without Cropping
Set up info:
Jetson AGX ORIN
Deepstream version : 6.3
Jetpack version: 5.1.2
TRT: 8.5.2
Issue: I am trying to calibrate my camera using ‘remap’ in VPI with CUDA back-end. I already have done camera calibration(without crop) using Opencv which I am trying to replicate using VPI. However, image is calibrated only with cropping. Could you let me know if there’ s any way to resolve it?
Currently, I am using the below code using opencv calibration method which gives me complete image without cropping:
new_K = cv2.fisheye.estimateNewCameraMatrixForUndistortRectify(scaled_K, D, dim2, np.eye(3), balance=balance)
map1, map2 = cv2.fisheye.initUndistortRectifyMap(scaled_K, D, np.eye(3), new_K, dim3, cv2.CV_16SC2)
undistorted_img = cv2.remap(img, map1, map2, interpolation=cv2.INTER_LINEAR, borderMode=cv2.BORDER_CONSTANT)
The below code gives me an error if I try to change grid size to the size I need. Otherwise, it works fine.
grid = vpi.WarpGrid((960, 540))
undist_map = vpi.WarpMap.fisheye_correction(grid,
                                            K=K[0:2,:], X=np.eye(3,4), coeffs=D.flatten(),
                                            mapping=vpi.FisheyeMapping.EQUIDISTANT)
with vpi.Backend.CUDA:
   undistort_img = vpi.asimage(img).convert(vpi.Format.NV12_ER).remap(undist_map, interp=vpi.Interp.CATMULL_ROM, border=vpi.Border.ZERO).convert(vpi.Format.RGB8)
und_image = undistort_img.cpu()
Please note that VPI uses backward warping.
The default the size between output and input is equal.
Have you tried to set a bigger output size to reduce the cropped region?
Hi AastaLLL,
Yes, I gave the required output size to create the WarpGrid. But, it seems to only accept original input size.
If you want to preserve the view angle in the same resolution, scaling down is required.
Could you give it a try?
Generate a new undistortion matrix with a scaling matrix.
Hi AastaLL,
Thanks for your response.
The given solution might work. We’ ll give it a try. Thank you.
