VPI on Drive AGX Orin
Software Version
DRIVE OS Linux 6.0.8.1 and DriveWorks 5.10
Hardware Platform
DRIVE AGX Orin
We are wondering if VPI with CUDA backend could be installed and used on a Drive AGX Orin based system. Obviously only CPU and CUDA backends could be available on this platform, but it would be great if we could use the VPI algorithms with CUDA backend.
As I see VPI arm64 package that uses dGPU is available, can this package be used on Drive AGX Orin as well? Will it work with the integrated SoC GPU?
Kind regards,
Adam
Dear @AdamBalazsVay,
VPI is not supported on DRIVE. Can you check if the modules listed at DriveWorks SDK Reference: Modules helps?
