Test Environment
- Platform: Jetson AGX Thor Dev-Kit
- JetPack version: 7.0
- VPI version: 4.0.0
- Camera: Stereo Camera
- Camera resolution: 2560 x 1984
- VPI StereoDisparity backends tested:
vpi.Backend.OFA | vpi.Backend.PVA | vpi.Backend.VIC\
I am currently testing VPI StereoDisparity with a stereo camera, and I would like to ask about an issue I observed when using the `OFA | PVA | VIC` backend.
I attached the pipeline structure image for reference.
Issue
With the `OFA | PVA | VIC` backend, the first frame is processed successfully.
The disparity image and confidence image can be displayed with OpenCV `imshow`.
However, after the first frame is displayed, the application does not proceed to the next frame. It appears to hang or freeze in the live loop.
As a cross test, I changed the backend to OFA only:
BACKEND = vpi.Backend.OFA
With the OFA-only backend, the live loop continues normally. However, confidence map output is not available in this mode.
Therefore, I suspect that the issue may be related to the OFA | PVA | VIC backend path, especially the PVA / confidence map side.
Related Code
BACKEND = vpi.Backend.OFA | vpi.Backend.PVA | vpi.Backend.VIC
conf_map = None # Also tested with confidence map enabled.
stream = vpi.Stream()
disp_bl = vpi.stereodisp(
left_bl,
right_bl,
backend=BACKEND,
stream=stream,
out_confmap=conf_map,
conftype=vpi.ConfidenceType.RELATIVE,
window=WINDOW,
maxdisp=MAX_DISP,
confthreshold=CONF_THRESH,
quality=QUALITY,
p1=P1,
p2=P2,
p2alpha=P2ALPHA,
numpasses=NUMPASSES,
stream.sync()
Question
Could you please help confirm whether I am using the VPI StereoDisparity API incorrectly, or whether this behavior is a known issue in VPI 4.0?
If this is related to a known VPI 4.0 issue, could you also let me know if there is any recommended workaround or planned fix?
I attached the related test code for reference.
Thank you.
