AastaLLL
5
This API targets for the format convertion.
The resample here is used since some format may have half color plane resolution. Ex. I420.
If you want to resample the image, please use this API instead:
https://docs.nvidia.com/vpi/algo_image_resampler.html
Related topics
| VPI resample On CUDA | 1 | 507 | July 24, 2020 | |
| Nvidia vpi image format conversion | 2 | 780 | August 22, 2022 | |
| VPI 1.1.12 VPI_ERROR_INVALID_IMAGE_FORMAT: Input format's color range must be same as output'sa | 4 | 797 | August 4, 2022 | |
| VPI Image Format Conversion: ERROR Input format's color range must be same as output's | 6 | 1489 | April 29, 2022 | |
| VPI do not support conversion between VPI_IMAGE_FORMAT_YUYV and VPI_IMAGE_FORMAT_RGB8 | 5 | 1086 | September 19, 2022 | |
| vpiSubmitConvertImageFormat CPU usage is high | 6 | 150 | September 25, 2025 | |
| Artifact when color-converting with VPI on JETSON XAVIER only, driver issue? | 4 | 1046 | August 19, 2021 | |
| Performance about VPI ConvertImageFormat | 3 | 284 | July 18, 2024 | |
| VPI RGBA -> NV12 more than 2x slower than documented | 5 | 918 | August 27, 2020 | |
| Nosiy image generated after vpiSubmitRescale | 3 | 1119 | April 29, 2021 |
