I have tested the performance of vpiImageCreateCUDAMemWrapper
and it seems to be very slow compared to simple memcpy
For 100000 bytes of managed memory vpiImageCreateCUDAMemWrapper
takes 320 micro seconds to wrap. memcpy
takes 13 micro seconds. (xavier , power mode 3)
Can somebody explain what is going on here?
Code for testing vpiImageCreateCUDAMemWrappert
performance:
#include <string>
#include <chrono>
#include <vpi/Stream.h>
#include <vpi/Image.h>
#include <vpi/algo/ConvertImageFormat.h>
#include <vpi/CUDAInterop.h>
#include <iostream>
#include <vector>
#include <cstdint>
#include <cstring>
#include <cuda.h>
#include "cuda_runtime.h"
inline bool cudaAllocMapped( void** cpuPtr, void** gpuPtr, size_t size )
if( !cpuPtr || !gpuPtr || size == 0 )
return false;
if( cudaHostAlloc(cpuPtr, size, cudaHostAllocMapped) != cudaSuccess )
return false;
if( cudaHostGetDevicePointer(gpuPtr, *cpuPtr, 0) != cudaSuccess )
return false;
memset(*cpuPtr, 0, size);
return true;
inline bool cudaAllocMapped( void** ptr, size_t size )
void* cpuPtr = NULL;
void* gpuPtr = NULL;
if( !ptr || size == 0 )
return false;
if( !cudaAllocMapped(&cpuPtr, &gpuPtr, size) )
return false;
if( cpuPtr != gpuPtr )
std::cout<<"CUDA: cudaAllocMapped() - addresses of CPU and GPU pointers don't match"<<std::endl;
return false;
*ptr = gpuPtr;
return true;
class VPITest {
public:
VPITest();
~VPITest();
void wrapCUDAMemoryU8(void * data,VPIBackend backend,VPIImage * image,
int32_t height,int32_t width);
void runTests();
private:
VPIStream m_vpiStream;
VPIImage m_currImageU8;
int m_width, m_height;
VPITest::VPITest() :
m_width(1000),
m_height(100)
vpiStreamCreate(0, &m_vpiStream);
cudaSetDeviceFlags(cudaDeviceMapHost);
VPITest::~VPITest()
vpiStreamDestroy(m_vpiStream);
void VPITest::wrapCUDAMemoryU8(void * data,VPIBackend backend,VPIImage * image,
int32_t height,int32_t width) {
VPIImageData imgData;
memset(&imgData, 0, sizeof(imgData));
imgData.format = VPI_IMAGE_FORMAT_U8;
imgData.numPlanes = 1;
imgData.planes[0].width = width;
imgData.planes[0].height = height;
imgData.planes[0].pitchBytes = width;
imgData.planes[0].data = data;
if(vpiImageCreateCUDAMemWrapper(&imgData,backend,image)!=VPI_SUCCESS)
std::cout<<"VPITest::wrapCUDAMemoryU8: vpiImageCreateCUDAMemWrapper failed"<<std::endl;
void VPITest::runTests(){
uint8_t * data;
std::vector<uint8_t> testVec;
testVec.resize(m_height * m_width);
auto startedAlloc = std::chrono::high_resolution_clock::now();
if( !cudaAllocMapped((void**)&data,m_height * m_width) )
return;
auto doneAlloc = std::chrono::high_resolution_clock::now();
wrapCUDAMemoryU8(data, VPI_BACKEND_CUDA,&m_currImageU8,m_height,m_width);
auto doneWrap = std::chrono::high_resolution_clock::now();
vpiStreamSync(m_vpiStream);
auto doneSync = std::chrono::high_resolution_clock::now();
std::memcpy(&data[0], &testVec[0], m_height * m_width);
auto doneCpy = std::chrono::high_resolution_clock::now();
std::cout<<"Alloc time: "<<std::chrono::duration_cast<std::chrono::microseconds>(doneAlloc-startedAlloc).count()<<std::endl;
std::cout<<"Wrap time: " <<std::chrono::duration_cast<std::chrono::microseconds>(doneWrap-doneAlloc).count()<<std::endl;
std::cout<<"Sync time: "<<std::chrono::duration_cast<std::chrono::microseconds>(doneSync-doneWrap).count()<<std::endl;
std::cout<<"Memcpy time: "<<std::chrono::duration_cast<std::chrono::microseconds>(doneCpy-doneSync).count()<<std::endl;
int main(int argc, char *argv[]) {
VPITest vpiTest;
vpiTest.runTests();
return 0;
