Is this expected? How should I process images rendered in GLES using VPI?
The code below gives the output at the bottom.
Run on a Xavier with JetPack 4.4.
Copy the code to yourFileName.cpp, chmod +x the file, run ./yourFileName.cpp to compile and run it.
It’s odd that the output says NVMEDIA_VPI : 156, Version 2.3 but /opt/nvidia/include/vpi says version 3.7.0 and so does the lib
//usr/bin/g++ $0 -lEGL -lGLESv2 -lnvvpi && ./a.out; exit
#include <GLES3/gl32.h>
#include <GLES2/gl2ext.h>
#include <vpi/VPI.h>
#include <vpi/EGL.h>
#include <stdio.h>
#include <vector>
int main() {
EGLDisplay eglDisplay = eglGetDisplay(EGL_DEFAULT_DISPLAY);
eglInitialize(eglDisplay, nullptr, nullptr);
EGLContext eglContext;
EGLint configAttributes[] = {
EGL_RENDERABLE_TYPE, EGL_OPENGL_ES3_BIT,
EGL_SURFACE_TYPE, EGL_PBUFFER_BIT,
EGL_RED_SIZE, 8,
EGL_GREEN_SIZE, 8,
EGL_BLUE_SIZE, 8,
EGL_ALPHA_SIZE, 8,
EGL_NONE
EGLConfig config;
EGLint numConfigs;
eglChooseConfig(eglDisplay, configAttributes, &config, 1, &numConfigs);
EGLint contextAttributes[] = {
EGL_CONTEXT_MAJOR_VERSION, 3,
EGL_CONTEXT_MINOR_VERSION, 2,
EGL_NONE
eglContext = eglCreateContext(eglDisplay, config, EGL_NO_CONTEXT, contextAttributes);
eglMakeCurrent(eglDisplay, EGL_NO_SURFACE, EGL_NO_SURFACE, eglContext);
GLuint texture;
glGenTextures(1, &texture);
glBindTexture(GL_TEXTURE_2D, texture);
int width = 256, height = 256;
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, width, height, 0, GL_RGBA, GL_UNSIGNED_BYTE, std::vector<uint64_t>(width*height, 0xFFFFFFFF).data());
GLenum oglError = glGetError();
if (oglError != GL_NO_ERROR) fprintf(stderr, "OGL Error %x\n", oglError);
EGLAttrib eglImgAttrs[] = { EGL_IMAGE_PRESERVED, EGL_FALSE, EGL_NONE, EGL_NONE };
EGLImageKHR eglImage = eglCreateImage(eglDisplay, eglContext, EGL_GL_TEXTURE_2D_KHR, (EGLClientBuffer)(intptr_t)texture, eglImgAttrs);
EGLint eglErrorCode = eglGetError();
if (eglErrorCode != EGL_SUCCESS) fprintf(stderr, "EGL Error %x\n", eglErrorCode);
VPIImage img = nullptr;
VPIStatus vpiErrorCode = vpiImageWrapEglImage(eglImage, 0, &img);
if (vpiErrorCode != VPI_SUCCESS) fprintf(stderr, "VPI Error %x\n", vpiErrorCode);
return 0;
NVMEDIA_ARRAY: 53, Version 2.1
[ERROR] 2020-08-22 17:45:33 VPI_ERROR_INVALID_IMAGE_TYPE: Image type isn't accepted
[WARN ] 2020-08-22 17:45:33 src/private/mem/img/Mapping_EGLImage_NvMediaImage.cpp:157 (EGLExport:NvError_Timeout)
VPI Error 3
