VPIWrapMap can not be allocate
hello,
here is the code I allocate vpi map,
but vpiWarpMapAllocData return 2,
terminal shows:
what(): VPI_ERROR_INVALID_ARGUMENT: Number of horizontal regions must be between 1 and 4,
    VPIWarpMap map            = {};
    memset(&map, 0, sizeof(map));
    map.grid.numHorizRegions  = 1;
    map.grid.numVertRegions   = 1;
    map.grid.regionWidth[0]   = rec_width;  // 640
    map.grid.regionHeight[0]  = rec_height;  //480
    map.grid.horizInterval[0] = 1;
    map.grid.vertInterval[0]  = 1;
    printf("num region:%d\n", map.grid.numHorizRegions);
    CHECK_STATUS(vpiWarpMapAllocData(&map));
We tested the below allocation and it can work as expected.
        map.grid.regionWidth[0]   = 640;
        map.grid.regionHeight[0]  = 480;
Could you double-check the issue?
If the error still occurs, could you share a runnable sample with us?
here is runnable sample
11-fisheye.zip (678.7 KB)
Thanks for sharing the sample.
When we test this locally, the app looks for an input source to work.
Could you share the file with us as well?
$ ./vpi_sample_11_fisheye
[ WARN:0@0.020] global loadsave.cpp:248 findDecoder imread_('/home/orin-nx/seeker_omni_dataset/left/frame0000.jpg'): can't open/read file: check file path/integrity
terminate called after throwing an instance of 'std::runtime_error'
  what():  Can't read /home/orin-nx/seeker_omni_dataset/left/frame0000.jpg
Aborted (core dumped)
image.zip (619.8 KB)
hi, here is image zip
by the way, i found fisheye recitfy is for mono not for stereo
then i rectify stereo with opencv
can remap use with VPI?
Thank you
Thanks for sharing the image.
We will give it a try and provide more info to you.
You can run OpenCV’s algorithm to get the map and use VPI remap to warp the image.
We try the same on VPI 3.2 of JetPack 6.2.
It can work correctly without errors.
Please also give it a try:
in wrap opencv
in wrap opencv
map return type: 2
error occur
cam_matrix[0][0] : 1667.657593
cam_matrix[0][1] : 0.000000
cam_matrix[0][2] : 520.105225
cam_matrix[1][0] : 0.000000
cam_matrix[1][1] : 1655.588867
cam_matrix[1][2] : 459.897186
tran_matrix[0][0] : -0.001894
tran_matrix[0][1] : -0.024520
tran_matrix[0][2] : -0.999698
tran_matrix[0][3] : -0.047487
tran_matrix[1][0] : 0.002791
tran_matrix[1][1] : 0.999695
tran_matrix[1][2] : -0.024525
tran_matrix[1][3] : -0.001042
tran_matrix[2][0] : 0.999994
tran_matrix[2][1] : -0.002836
tran_matrix[2][2] : -0.001825
tran_matrix[2][3] : -0.047252
after fisheye dist : 1667.657593
after fisheye dist : 1687.516602
after fisheye dist : 0.000000
after fisheye dist : 520.105225
after fisheye dist : 545.379517
after fisheye dist : 1655.588867
after fisheye dist : 1675.695435
after fisheye dist : 459.897186
after fisheye dist : 426.758575
payload : 0
1
image size 2
2
3
4
5
remap status : 0
7
8
2
3
4
5
remap status : 0
7
8
