Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyACM0, 09:00:58
Press CTRL-A Z for help on special keys
[0000.064] I> MB1 (version: 0.23.0.0-t234-54845784-92215740)
[0000.070] I> t234-A01-0-Silicon (0x12347) Prod
[0000.074] I> Boot-mode : Coldboot
[0000.077] I> Emulation:
[0000.079] I> Entry timestamp: 0x00000000
[0000.083] I> last_boot_error: 0x0
[0000.086] I> BR-BCT: preprod_dev_sign: 0
[0000.090] I> rst_source: 0x0, rst_level: 0x0
[0000.094] I> Task: CRC check (0x5001cf71)
[0000.098] I> Skip CRC check as records_integrity fuse is not burned
[0000.104] I> Task: Crypto init (0x5001c0d9)
[0000.108] I> Task: Secure debug controls (0x5000cb19)
[0000.113] I> Task: strap war set (0x5000b739)
[0000.117] I> strap value(0x4000401) set to 0x4000401
[0000.122] I> Task: Initialize SOC Therm (0x5001a509)
[0000.127] I> Task: Program NV master stream id (0x5000cad1)
[0000.132] I> Task: Verify boot mode (0xd482021)
[0000.138] I> Task: Alias fuses (0x50010749)
[0000.143] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.150] I> Task: Print SKU type (0x5000fba9)
[0000.155] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.160] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.164] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.168] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.173] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.177] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.181] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.185] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.189] I> FUSE_SKU_INFO_0 = 0xd0
[0000.192] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.197] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.200] I> SKU: Prod
[0000.202] I> Task: Boost clocks (0x50013db1)
[0000.207] I> Initializing PLLC2 for AXI_CBB.
[0000.211] I> AXI_CBB : src = 35, divisor = 0
[0000.215] I> Task: Voltage monitor (0x50013dbd)
[0000.219] I> VMON: Vmon re-calibration and fine tuning done
[0000.225] I> Task: UPHY init (0x5000da39)
[0000.229] E> UPHY: UPHY lane info table is empty in MB1 BCT.
[0000.234] I> Task: Boot device init (0x50000a3d)
[0000.239] I> Boot_device: QSPI_FLASH instance: 0
[0000.243] I> Qspi clock source : pllc_out0
[0000.247] I> QSPI Flash: Macronix 64MB
[0000.251] I> QSPI-0l initialized successfully
[0000.255] I> Task: TSC init (0x5001ed35)
[0000.259] I> Task: Load membct (0x5001190d)
[0000.263] I> RAM_CODE 0x4000401
[0000.266] I> Loading MEM-BCT to SysRAM
[0000.270] I> Scratch RSV109: 0x00000001 active chain: 0
[0000.275] I> Slot: 0
[0000.277] I> Binary[0] block-0 (partition size: 0x40000)
[0000.282] I> get_binary_info: Binary name: MEM-BCT-0
[0000.287] I> Size of crypto header is 8192
[0000.291] I> BCH load address is : 0x40050000
[0000.295] I> Size of crypto header is 8192
[0000.299] I> BCH of MEM-BCT-0 read from storage
[0000.304] I> BCH address is : 0x40050000
[0000.308] I> MEM-BCT-0 header integrity check is success
[0000.313] I> Binary magic in BCH component 0 is MEM0
[0000.318] I> component binary type is 0
[0000.322] I> MEM-BCT-0 binary is read from storage
[0000.327] I> MEM-BCT-0 binary integrity check is success
[0000.332] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.338] I> RAM_CODE 0x4000401
[0000.344] I> RAM_CODE 0x4000401
[0000.348] I> Task: Load Page retirement list (0x50011139)
[0000.353] I> Task: SDRAM params override (0x50011b79)
[0000.358] I> Task: Save mem-bct info (0x50014071)
[0000.362] I> Task: Carveout allocate (0x500140d5)
[0000.367] I> RCM blob carveout will not be allocated
[0000.372] I> ECC region[0]: Start:0x0, End:0x0
[0000.376] I> ECC region[1]: Start:0x0, End:0x0
[0000.380] I> ECC region[2]: Start:0x0, End:0x0
[0000.384] I> ECC region[3]: Start:0x0, End:0x0
[0000.389] I> ECC region[4]: Start:0x0, End:0x0
[0000.393] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0000.399] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.404] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.408] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.413] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.422] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0000.430] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0000.437] I> allocated(CO:39) base:0x83a000000 size:0x6000000 align: 0x200000
[0000.444] I> allocated(CO:20) base:0x838000000 size:0x2000000 align: 0x2000000
[0000.451] I> allocated(CO:24) base:0x836000000 size:0x2000000 align: 0x2000000
[0000.458] I> allocated(CO:28) base:0x834000000 size:0x2000000 align: 0x2000000
[0000.465] I> allocated(CO:29) base:0x832000000 size:0x2000000 align: 0x2000000
[0000.472] I> allocated(CO:43) base:0x830000000 size:0x2000000 align: 0x200000
[0000.479] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0000.486] I> allocated(CO:41) base:0x82f000000 size:0x1000000 align: 0x100000
[0000.493] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0000.500] I> allocated(CO:03) base:0x82e800000 size:0x800000 align: 0x800000
[0000.507] I> allocated(CO:06) base:0x82e000000 size:0x800000 align: 0x800000
[0000.514] I> allocated(CO:10) base:0x82d800000 size:0x800000 align: 0x800000
[0000.521] I> allocated(CO:56) base:0x82d000000 size:0x800000 align: 0x200000
[0000.528] I> allocated(CO:07) base:0x82cc00000 size:0x400000 align: 0x400000
[0000.535] I> allocated(CO:33) base:0x82c800000 size:0x400000 align: 0x200000
[0000.542] I> allocated(CO:47) base:0x82c400000 size:0x400000 align: 0x200000
[0000.549] I> allocated(CO:72) base:0x82c200000 size:0x200000 align: 0x10000
[0000.555] I> allocated(CO:01) base:0x82c100000 size:0x100000 align: 0x100000
[0000.562] I> allocated(CO:04) base:0x82c000000 size:0x100000 align: 0x100000
[0000.569] I> allocated(CO:05) base:0x82bf00000 size:0x100000 align: 0x100000
[0000.576] I> allocated(CO:08) base:0x82be00000 size:0x100000 align: 0x100000
[0000.583] I> allocated(CO:09) base:0x82bd00000 size:0x100000 align: 0x100000
[0000.590] I> allocated(CO:15) base:0x82bc00000 size:0x100000 align: 0x100000
[0000.597] I> allocated(CO:17) base:0x82bb00000 size:0x100000 align: 0x100000
[0000.604] I> allocated(CO:23) base:0x82ba00000 size:0x100000 align: 0x100000
[0000.611] I> allocated(CO:27) base:0x82b900000 size:0x100000 align: 0x100000
[0000.618] I> allocated(CO:42) base:0x82b800000 size:0x100000 align: 0x100000
[0000.625] I> allocated(CO:54) base:0x82b780000 size:0x80000 align: 0x80000
[0000.631] I> allocated(CO:26) base:0x82b740000 size:0x40000 align: 0x2000
[0000.638] I> allocated(CO:48) base:0x82b720000 size:0x20000 align: 0x10000
[0000.645] I> allocated(CO:69) base:0x82b700000 size:0x20000 align: 0x10000
[0000.652] I> allocated(CO:34) base:0x82b6f0000 size:0x10000 align: 0x10000
[0000.658] I> allocated(CO:35) base:0x82b6e0000 size:0x10000 align: 0x10000
[0000.665] I> allocated(CO:49) base:0x82b6d0000 size:0x10000 align: 0x10000
[0000.672] I> allocated(CO:50) base:0x82b6c0000 size:0x10000 align: 0x10000
[0000.679] I> allocated(CO:52) base:0x82b6b0000 size:0x10000 align: 0x10000
[0000.685] I> Task: Thermal check (0x5001fba1)
[0000.689] I> max_chip_limit = 115
[0000.693] I> min_chip_limit = -30
[0000.696] I> max temp read = 33
[0000.699] I> min temp read = 32
[0000.702] I> Task: Update FSI SCR with thermal fuse data (0x5001fc3d)
[0000.708] I> Task: Enable WDT 5th expiry (0x5001f929)
[0000.713] I> Task: Disable WDT globally (0x5001f965)
[0000.718] I> Task: I2C register (0x50000a31)
[0000.722] I> Task: Reset FSI (0x50013db9)
[0000.726] I> Task: Pinmux init (0x50013219)
[0000.730] I> Task: Prod config init (0x50013631)
[0000.735] I> Task: Pad voltage init (0x500132a5)
[0000.739] I> Task: Prod init (0x500136d5)
[0000.743] I> Task: Common rail init (0x50013bd1)
[0000.747] W> Thermal config not found in BCT
[0000.752] W> Generic i2c config not found in BCT
[0000.756] W> Platform rail config not found in BCT
[0000.762] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.770] W> MEMIO rail config not found in BCT
[0000.774] I> Task: Mem clock src (0x500119c5)
[0000.779] I> Task: Misc. board config (0x50013c29)
[0000.783] W> Platform config not found in BCT
[0000.788] I> Task: SDRAM init (0x500119c9)
[0000.794] I> SDRAM-params @ 0xd485000
[0000.797] I> MSS code-drop: NvBootSdramInit
[0000.801] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0000.809] I> MSS CAR: Init PLLM
[0000.812] I> MSS CAR: Init PLLHUB
[0000.817] I> Encryption: MTS: en, TX: dis, VPR: dis, GSC: en
[0000.829] I> mb1_sdram_init Done !
[0000.832] I> SDRAM Size in Total 0x800000000
[0000.836] I> Task: Dram Ecc scrub (0x50011261)
[0000.840] I> Task: DRAM alias check (0x50011b71)
[0000.871] I> Task: Program NSDRAM carveout (0x50014921)
[0000.878] I> NSDRAM carveout encryption is disabled
[0000.883] I> Program NSDRAM carveout
[0000.887] I> Task: Register checker (0x50011b75)
[0000.896] I> Task: Enable clock-mon (0x5001ed25)
[0000.912] I> FMON: Fmon re-programming done
[0000.917] I> Task: Mapper init (0x5001d451)
[0000.922] I> Task: SC7 Context Init (0x5001f02d)
[0000.928] I> Task: CCPLEX IST init (0x5000d335)
[0000.934] I> Task: CPU WP0 (0x5000c635)
[0000.939] I> Loading MCE
[0000.942] I> Scratch RSV109: 0x00000001 active chain: 0
[0000.948] I> Slot: 0
[0000.950] I> Binary[8] block-0 (partition size: 0x80000)
[0000.956] I> get_binary_info: Binary name: MCE
[0000.961] I> Size of crypto header is 8192
[0000.965] I> BCH load address is : 0x4003e000
[0000.971] I> Size of crypto header is 8192
[0000.976] I> BCH of MCE read from storage
[0000.980] I> BCH address is : 0x4003e000
[0000.985] I> MCE header integrity check is success
[0000.990] I> Binary magic in BCH component 0 is MTSM
[0000.996] I> component binary type is 8
[0001.000] I> Size of crypto header is 8192
[0001.006] I> MCE binary is read from storage
[0001.012] I> MCE binary integrity check is success
[0001.017] I> Binary MCE loaded successfully at 0x40000000 (0x2c080)
[0001.024] I> Size of crypto header is 8192
[0001.039] I> Size of crypto header is 8192
[0001.044] I> Sending WP0 mailbox command to PSC
[0001.054] I> Task: MB1 fixed firewalls (0x5001e55d)
[0001.074] I> Task: Load bpmp-fw (0x5001e801)
[0001.079] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.085] I> Slot: 0
[0001.087] I> Binary[15] block-0 (partition size: 0x180000)
[0001.094] I> get_binary_info: Binary name: BPMP_FW
[0001.099] I> Size of crypto header is 8192
[0001.103] I> BCH load address is : 0x807fe000
[0001.109] I> Size of crypto header is 8192
[0001.114] I> BCH of BPMP_FW read from storage
[0001.118] I> BCH address is : 0x807fe000
[0001.124] I> BPMP_FW header integrity check is success
[0001.129] I> Binary magic in BCH component 0 is BPMF
[0001.134] I> component binary type is 15
[0001.139] I> Size of crypto header is 8192
[0001.154] I> BPMP_FW binary is read from storage
[0001.161] I> BPMP_FW binary integrity check is success
[0001.167] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfb3c0)
[0001.175] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.181] I> Slot: 0
[0001.183] I> Binary[16] block-10000 (partition size: 0x400000)
[0001.190] I> get_binary_info: Binary name: BPMP_FW_DTB
[0001.195] I> Size of crypto header is 8192
[0001.200] I> BCH load address is : 0x807fc000
[0001.205] I> Size of crypto header is 8192
[0001.210] I> BCH of BPMP_FW_DTB read from storage
[0001.215] I> BCH address is : 0x807fc000
[0001.221] I> BPMP_FW_DTB header integrity check is success
[0001.227] I> Binary magic in BCH component 0 is BPMD
[0001.232] I> component binary type is 16
[0001.236] I> Size of crypto header is 8192
[0001.242] I> BPMP_FW_DTB binary is read from storage
[0001.248] I> BPMP_FW_DTB binary integrity check is success
[0001.254] I> Binary BPMP_FW_DTB loaded successfully at 0x807db9f0 (0x20440)
[0001.263] I> Task: Load psc-fw (0x5001ea0d)
[0001.269] I> Scratch RSV109: 0x00000001 active chain: 0
��Ƥ�冄�ńG��DŽd��䥇��Ć���b憆Ƈ���b憆Ƈ��b憆��m����������DC#ㄥ������GC#�����b憆Ƈ��ƃ��b憆Ƈ��e��F��̇b椆 t
L4TLauncher: Attempting DireEFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-5273-d7000) (aarch64-buil2
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x805405a98 SMBIOS=0xffff0000 SMBIOS 3.0=0x8039a0000 MEMATTR=0x80
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000803790a18 to 0x0000000803790a50.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000817800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000835ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000007ffffffff]
[ 0.000000] node 0: [mem 0x0000000800000000-0x00000008021bffff]
[ 0.000000] node 0: [mem 0x00000008021c0000-0x0000000803570fff]
[ 0.000000] node 0: [mem 0x0000000803571000-0x000000080370cfff]
[ 0.000000] node 0: [mem 0x000000080370d000-0x000000080398ffff]
[ 0.000000] node 0: [mem 0x0000000803990000-0x00000008039affff]
[ 0.000000] node 0: [mem 0x00000008039b0000-0x000000080453ffff]
[ 0.000000] node 0: [mem 0x0000000804540000-0x00000008046cffff]
[ 0.000000] node 0: [mem 0x00000008046d0000-0x000000080473ffff]
[ 0.000000] node 0: [mem 0x0000000804740000-0x000000080475ffff]
[ 0.000000] node 0: [mem 0x0000000804760000-0x000000080477ffff]
[ 0.000000] node 0: [mem 0x0000000804780000-0x000000080499ffff]
[ 0.000000] node 0: [mem 0x00000008049a0000-0x00000008049bffff]
[ 0.000000] node 0: [mem 0x00000008049c0000-0x0000000804a0ffff]
[ 0.000000] node 0: [mem 0x0000000804a10000-0x0000000804a9ffff]
[ 0.000000] node 0: [mem 0x0000000804aa0000-0x0000000804e4ffff]
[ 0.000000] node 0: [mem 0x0000000804e50000-0x0000000804e5ffff]
[ 0.000000] node 0: [mem 0x0000000804e60000-0x0000000804e6ffff]
[ 0.000000] node 0: [mem 0x0000000804e70000-0x0000000804e7ffff]
[ 0.000000] node 0: [mem 0x0000000804e80000-0x0000000804ebffff]
[ 0.000000] node 0: [mem 0x0000000804ec0000-0x000000080534ffff]
[ 0.000000] node 0: [mem 0x0000000805350000-0x000000080539ffff]
[ 0.000000] node 0: [mem 0x00000008053a0000-0x00000008053cffff]
[ 0.000000] node 0: [mem 0x00000008053d0000-0x00000008053effff]
[ 0.000000] node 0: [mem 0x00000008053f0000-0x000000080553ffff]
[ 0.000000] node 0: [mem 0x0000000805540000-0x00000008055dffff]
[ 0.000000] node 0: [mem 0x00000008055e0000-0x000000080568ffff]
[ 0.000000] node 0: [mem 0x0000000805690000-0x000000080572ffff]
[ 0.000000] node 0: [mem 0x0000000805730000-0x00000008057bffff]
[ 0.000000] node 0: [mem 0x00000008057c0000-0x000000080585ffff]
[ 0.000000] node 0: [mem 0x0000000805860000-0x000000080612ffff]
[ 0.000000] node 0: [mem 0x0000000806130000-0x000000080630ffff]
[ 0.000000] node 0: [mem 0x0000000806310000-0x00000008278bffff]
[ 0.000000] node 0: [mem 0x00000008278c0000-0x000000082790ffff]
[ 0.000000] node 0: [mem 0x0000000827910000-0x000000082b6affff]
[ 0.000000] node 0: [mem 0x000000082c400000-0x000000082c7fffff]
[ 0.000000] node 0: [mem 0x0000000834000000-0x0000000835ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000835ffffff]
[ 0.000000] On node 0, zone Normal: 336 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90136 r8192 d32744 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7925040
[ 0.000000] Kernel command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 mminit_l
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 30994412K/32205504K available (18432K kernel code, 3172K rwdata, 7156)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_i0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046s
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000729] Console: colour dummy device 80x25
[ 0.000921] printk: console [tty0] enabled
[ 0.000955] Calibrating delay loop (skipped), value calculated using timer frequency.. 62)
[ 0.000965] pid_max: default: 32768 minimum: 301
[ 0.001025] LSM: Security Framework initializing
[ 0.001046] Yama: becoming mindful.
[ 0.001062] SELinux: Initializing.
[ 0.001142] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001186] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.002987] rcu: Hierarchical SRCU implementation.
[ 0.003073] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.003600] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/s
[ 0.003609] DTB Build time: Aug 10 2022 20:31:40
[ 0.005022] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.005134] Remapping and enabling EFI services.
[ 0.006347] smp: Bringing up secondary CPUs ...
[ 0.035010] Detected PIPT I-cache on CPU1
[ 0.035045] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.035072] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.063676] Detected PIPT I-cache on CPU2
[ 0.063686] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.063700] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.092272] Detected PIPT I-cache on CPU3
[ 0.092281] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.092295] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.122912] Detected PIPT I-cache on CPU4
[ 0.122933] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.122957] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.151588] Detected PIPT I-cache on CPU5
[ 0.151599] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.151613] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.180207] Detected PIPT I-cache on CPU6
[ 0.180217] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.180231] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.208832] Detected PIPT I-cache on CPU7
[ 0.208842] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.208856] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.239482] Detected PIPT I-cache on CPU8
[ 0.239505] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.239530] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.268153] Detected PIPT I-cache on CPU9
[ 0.268163] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.268178] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.297387] Detected PIPT I-cache on CPU10
[ 0.297398] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.297412] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.326614] Detected PIPT I-cache on CPU11
[ 0.326625] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.326639] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.326695] smp: Brought up 1 node, 12 CPUs
[ 0.326758] SMP: Total of 12 processors activated.
[ 0.326763] CPU features: detected: Privileged Access Never
[ 0.326766] CPU features: detected: LSE atomic instructions
[ 0.326768] CPU features: detected: User Access Override
[ 0.326771] CPU features: detected: 32-bit EL0 Support
[ 0.326774] CPU features: detected: Common not Private translations
[ 0.326777] CPU features: detected: RAS Extension Support
[ 0.326779] CPU features: detected: Data cache clean to the PoU not required for I/D cohee
[ 0.326783] CPU features: detected: CRC32 instructions
[ 0.326786] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.360151] CPU: All CPU(s) started at EL2
[ 0.362362] devtmpfs: initialized
[ 0.377642] Registered cp15_barrier emulation handler
[ 0.377654] Registered setend emulation handler
[ 0.377659] KASLR enabled
[ 0.377774] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7s
[ 0.377788] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.379257] pinctrl core: initialized pinctrl subsystem
[ 0.379730] SMBIOS 3.0.0 present.
[ 0.379737] DMI: /, BIOS 1.0-d7fb19b 08/10/2022
[ 0.379981] NET: Registered protocol family 16
[ 0.380695] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.380896] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.381091] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.381116] audit: initializing netlink subsys (disabled)
[ 0.381186] audit: type=2000 audit(0.380:1): state=initialized audit_enabled=0 res=1
[ 0.381331] thermal_sys: Registered thermal governor 'step_wise'
[ 0.381333] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.381338] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.383370] cpuidle: using governor menu
[ 0.383473] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.383590] ASID allocator initialised with 32768 entries
[ 0.383675] Serial: AMBA PL011 UART driver
[ 0.385223] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.385246] Tegra reboot handler registered.
[ 0.402955] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2c10000
[ 0.402969] mc: mapped MMIO address: 0xffff800011210000 -> 0x2c20000
[ 0.402977] mc: mapped MMIO address: 0xffff800011230000 -> 0x2c30000
[ 0.402984] mc: mapped MMIO address: 0xffff800011250000 -> 0x2c40000
[ 0.402992] mc: mapped MMIO address: 0xffff800011270000 -> 0x2c50000
[ 0.403001] mc: mapped MMIO address: 0xffff800011290000 -> 0x2b80000
[ 0.403009] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x2b90000
[ 0.403016] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x2ba0000
[ 0.403022] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x2bb0000
[ 0.403029] mc: mapped MMIO address: 0xffff800011310000 -> 0x1700000
[ 0.403035] mc: mapped MMIO address: 0xffff800011330000 -> 0x1710000
[ 0.403042] mc: mapped MMIO address: 0xffff800011350000 -> 0x1720000
[ 0.403049] mc: mapped MMIO address: 0xffff800011370000 -> 0x1730000
[ 0.403055] mc: mapped MMIO address: 0xffff800011390000 -> 0x1740000
[ 0.403061] mc: mapped MMIO address: 0xffff8000113b0000 -> 0x1750000
[ 0.403068] mc: mapped MMIO address: 0xffff8000113d0000 -> 0x1760000
[ 0.403075] mc: mapped MMIO address: 0xffff8000113f0000 -> 0x1770000
[ 0.403085] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.403107] mc-err: mcerr ops are set to t23x
[ 0.403360] tegra234-cbb 13a00000.cbb-fabric: secure_irq = 21
[ 0.403412] tegra234-cbb c600000.aon-fabric: secure_irq = 22
[ 0.403453] tegra234-cbb d600000.bpmp-fabric: secure_irq = 23
[ 0.403487] tegra234-cbb de00000.dce-fabric: secure_irq = 24
[ 0.403520] tegra234-cbb be00000.rce-fabric: secure_irq = 25
[ 0.403555] tegra234-cbb b600000.sce-fabric: secure_irq = 26
[ 0.403757] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 66, base_baud = 0) is a SBSA
[ 1.704208] printk: console [ttyAMA0] enabled
[ 1.712522] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.719233] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.725934] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.732632] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.741020] ACPI: Interpreter disabled.
[ 1.746004] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.750881] vbusA-cvb: supplied by vdd-5v-sys
[ 1.755355] vbusB-cvb: supplied by vdd-5v-sys
[ 1.759831] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.764729] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.769788] iommu: Default domain type: Translated
[ 1.774701] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.780954] SCSI subsystem initialized
[ 1.784759] usbcore: registered new interface driver usbfs
[ 1.790256] usbcore: registered new interface driver hub
[ 1.795580] usbcore: registered new device driver usb
[ 1.800804] mc: Linux media interface: v0.10
[ 1.805083] videodev: Linux video capture interface: v2.00
[ 1.810704] pps_core: LinuxPPS API ver. 1 registered
[ 1.815668] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giomett>
[ 1.824805] PTP clock support registered
[ 1.828910] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.836073] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.843751] Registered efivars operations
[ 1.848192] FPGA manager framework
[ 1.851625] Advanced Linux Sound Architecture Driver Initialized.
[ 1.857952] Bluetooth: Core ver 2.22
[ 1.861534] NET: Registered protocol family 31
[ 1.865978] Bluetooth: HCI device and connection manager initialized
[ 1.872336] Bluetooth: HCI socket layer initialized
[ 1.877214] Bluetooth: L2CAP socket layer initialized
[ 1.882270] Bluetooth: SCO socket layer initialized
[ 1.887610] camchar: rtcpu character device driver loaded
[ 1.893223] clocksource: Switched to clocksource arch_sys_counter
[ 2.050285] VFS: Disk quotas dquot_6.6.0
[ 2.054247] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.061254] pnp: PnP ACPI: disabled
[ 2.066595] la/ptsa driver initialized.
[ 2.070478] NET: Registered protocol family 2
[ 2.075030] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.084734] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, l)
[ 2.093477] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.101766] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 2.109661] TCP: Hash tables configured (established 262144 bind 65536)
[ 2.116351] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 2.123282] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 2.130714] NET: Registered protocol family 1
[ 2.135310] RPC: Registered named UNIX socket transport module.
[ 2.141244] RPC: Registered udp transport module.
[ 2.145947] RPC: Registered tcp transport module.
[ 2.150647] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.157094] PCI: CLS 0 bytes, default 64
[ 2.161133] Trying to unpack rootfs image as initramfs...
[ 2.275613] Freeing initrd memory: 8196K
[ 2.281676] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.289668] kvm [1]: IPA Size Limit: 48 bits
[ 2.294098] kvm [1]: VHE mode initialized successfully
[ 2.299937] Initialise system trusted keyrings
[ 2.304473] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 2.312977] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.319048] NFS: Registering the id_resolver key type
[ 2.324111] Key type id_resolver registered
[ 2.328293] Key type id_legacy registered
[ 2.332331] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.339039] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.346443] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.362378] NET: Registered protocol family 38
[ 2.366827] Key type asymmetric registered
[ 2.370922] Asymmetric key parser 'x509' registered
[ 2.375816] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.383268] io scheduler mq-deadline registered
[ 2.387800] io scheduler kyber registered
[ 2.395652] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.401257] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.406852] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.412442] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.420382] tegra_dc_assign_hw_data: no matching compatible node
[ 2.426397] tegradccommon module_init failed
[ 2.430667] tegradc module_init failed
[ 2.434657] EINJ: ACPI disabled.
[ 2.439345] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.446226] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 2.451538] tegra-pmc: ### PMC reset level: L0
[ 2.455979] tegra-pmc: ### PMC reset status reg: 0x0
[ 2.462280] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.475584] random: fast init done
[ 2.475941] printk: console [ttyTCU0] enabled
[ 4.162908] arm-smmu 12000000.iommu: probing hardware configuration...
[ 4.170865] arm-smmu 12000000.iommu: SMMUv2 with:
[ 4.175691] arm-smmu 12000000.iommu: stage 1 translation
[ 4.181231] arm-smmu 12000000.iommu: stage 2 translation
[ 4.186758] arm-smmu 12000000.iommu: nested translation
[ 4.192213] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.199629] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.208340] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.215034] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.221729] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.229208] arm-smmu 10000000.iommu: probing hardware configuration...
[ 4.235905] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.240730] arm-smmu 10000000.iommu: stage 1 translation
[ 4.246259] arm-smmu 10000000.iommu: stage 2 translation
[ 4.251800] arm-smmu 10000000.iommu: nested translation
[ 4.257256] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.264660] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.273356] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.280045] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.286745] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.293857] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.300472] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.305206] arm-smmu 8000000.iommu: stage 1 translation
[ 4.310648] arm-smmu 8000000.iommu: stage 2 translation
[ 4.316089] arm-smmu 8000000.iommu: nested translation
[ 4.321449] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.328776] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.337412] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.344015] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.350627] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.357876] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.368439] tegra_profiler: version: 1.147, samples/io: 49/28
[ 4.374409] tegra_profiler: auth: init
[ 4.378536] nvsciipc: loaded module
[ 4.383042] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[ 4.389216] tegra23x-qspi 3270000.spi: Node prod has invalid entries
[ 4.395736] tegra23x-qspi 3270000.spi: Node prod: Child has not proper setting
[ 4.403140] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[ 4.410729] tegra23x-qspi 3270000.spi: Prod settings list not found
[ 4.417274] tegra23x-qspi 3270000.spi: Failed to get reset control: -517
[ 4.424714] tun: Universal TUN/TAP device driver, 1.6
[ 4.430311] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.437729] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.443205] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.448287] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.454378] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.459915] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.465770] PPP generic driver version 2.4.2
[ 4.470185] PPP BSD Compression module registered
[ 4.475017] PPP Deflate Compression module registered
[ 4.480216] PPP MPPE Compression module registered
[ 4.485156] usbcore: registered new interface driver r8152
[ 4.490796] usbcore: registered new interface driver asix
[ 4.496347] usbcore: registered new interface driver ax88179_178a
[ 4.502609] usbcore: registered new interface driver cdc_ether
[ 4.508591] usbcore: registered new interface driver net1080
[ 4.514413] usbcore: registered new interface driver cdc_subset
[ 4.520489] usbcore: registered new interface driver zaurus
[ 4.526232] usbcore: registered new interface driver cdc_ncm
[ 4.532036] usbcore: registered new interface driver aqc111
[ 4.537864] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.544212] ohci-pci: OHCI PCI platform driver
[ 4.548785] ohci-platform: OHCI generic platform driver
[ 4.554417] tegra-xusb 3610000.xhci: Adding to iommu group 1
[ 4.560703] usbcore: registered new interface driver uas
[ 4.566178] usbcore: registered new interface driver usb-storage
[ 4.572471] tegra-xudc 3550000.xudc: Adding to iommu group 2
[ 4.578578] mousedev: PS/2 mouse device common for all mice
[ 4.584318] usbcore: registered new interface driver xpad
[ 4.591707] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.597180] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:28 UTC (28)
[ 4.605401] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.611784] i2c /dev entries driver
[ 4.615463] tegra-i2c 3160000.i2c: Adding to iommu group 3
[ 4.621271] tegra-i2c c240000.i2c: Adding to iommu group 3
[ 4.626937] tegra-i2c 3180000.i2c: Adding to iommu group 3
[ 4.632596] tegra-i2c 3190000.i2c: Adding to iommu group 3
[ 4.638288] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[ 4.643956] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[ 4.649635] tegra-i2c c250000.i2c: Adding to iommu group 3
[ 4.655304] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[ 4.663015] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoin.
[ 4.671582] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoin.
[ 4.680844] device-mapper: uevent: version 1.0.3
[ 4.685656] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.m
[ 4.695413] sdhci: Secure Digital Host Controller Interface driver
[ 4.701766] sdhci: Copyright(c) Pierre Ossman
[ 4.706239] Synopsys Designware Multimedia Card Interface Driver
[ 4.712475] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.718422] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[ 4.718629] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[ 4.719126] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.720006] tegra-bpmp bpmp: firmware: 888a114dda6bea50b6c6-eac380526d6
[ 4.721874] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.722447] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[ 4.726631] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.760013] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��debugfs initialized
��[ 5.989432] hid: raw HID events driver (C) Jiri Kosina
[ 5.995153] usbcore: registered new interface driver usbhid
[ 6.000896] usbhid: USB HID core driver
[ 6.005600] tegra-dce d800000.dce: Adding to iommu group 6
[ 6.012534] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
[ 6.021725] tegra234-aon c000000.aon: Adding to iommu group 7
[ 6.027927] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB :]
[ 6.030378] c000000.aon:hsp: probed
[ 6.036912] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [0]. Ignore.
[ 6.036924] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [0]. Ignore.
[ 6.049434] tegra234-aon c000000.aon: init done
[ 6.049834] tegra23x-psc e860000.psc: Adding to iommu group 8
[ 6.058238] dce: dce_admin_send_cmd_ver:413 version : [0x2] err : [0x0]
[ 6.063246] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 6.069419] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB :]
[ 6.075748] tegra23x-psc e860000.psc: init done
[ 6.075897] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 9
[ 6.082222] dce: dce_admin_setup_clients_ipc:542 Channel Reset Complete for Type [1] ...
[ 6.082224] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [1]. Ignore.
[ 6.082236] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [1]. Ignore.
[ 6.091887] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.095897] dce: dce_admin_setup_clients_ipc:518 Get queue info failed for [2]
[ 6.096279] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB :]
[ 6.106122] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff siz4
[ 6.110989] dce: dce_admin_setup_clients_ipc:542 Channel Reset Complete for Type [3] ...
[ 6.110991] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [3]. Ignore.
[ 6.111001] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [3]. Ignore.
[ 6.119819] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000
[ 6.128757] dce: dce_start_boot_flow:100 DCE_BOOT_DONE
[ 6.137181] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0
[ 6.217397] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d800
[ 6.229169] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[0
[ 6.241780] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[0
[ 6.254645] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080
[ 6.267017] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (117)
[ 6.273851] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.285599] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=7a10e460
[ 6.299523] t19x_cache tegra-cache: probed
[ 6.304024] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.323162] optee: probing for conduit method.
[ 6.327762] optee: revision 3.16 (65cc2218)
[ 6.328539] optee: dynamic shared memory is enabled
[ 6.337974] optee: initialized driver
[ 6.353766] nvpmodel: initialized successfully
[ 6.358429] tegra_hv: get_hvd: not initialized yet
[ 6.363380] user_ivc_mempool: hypervisor not present
[ 6.369522] usbcore: registered new interface driver snd-usb-audio
[ 6.376664] u32 classifier
[ 6.379457] input device check on
[ 6.383230] Actions configured
[ 6.386855] Initializing XFRM netlink socket
[ 6.391642] NET: Registered protocol family 10
[ 6.397296] Segment Routing with IPv6
[ 6.401105] NET: Registered protocol family 17
[ 6.405700] NET: Registered protocol family 15
[ 6.410335] bridge: filtering via arp/ip/ip6tables is no longer available by default. Upd.
[ 6.424291] Bluetooth: RFCOMM socket layer initialized
[ 6.429597] Bluetooth: RFCOMM ver 1.11
[ 6.433467] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.439573] Bluetooth: HIDP socket layer initialized
[ 6.445401] 9pnet: Installing 9P2000 support
[ 6.449852] Key type dns_resolver registered
[ 6.454584] registered taskstats version 1
[ 6.458824] Loading compiled-in X.509 certificates
[ 6.467265] Loaded X.509 cert 'Build time autogenerated kernel key: 90ac610178c49616e6b7a'
[ 6.477961] tegra194-pcie 14100000.pcie: Adding to iommu group 10
[ 6.489848] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.496907] tegra194-pcie 14160000.pcie: Adding to iommu group 11
[ 6.508358] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.515139] tegra194-pcie 141a0000.pcie: Adding to iommu group 12
[ 6.526401] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.553978] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 13
[ 6.563781] host1x 13e40000.host1x: Adding to iommu group 14
[ 7.580111] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 7.600759] host1x 13e40000.host1x: initialized
[ 7.605754] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 15
[ 7.613888] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu)
[ 7.625870] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 16
[ 7.633941] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu)
[ 7.645905] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 17
[ 7.653971] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu)
[ 7.665947] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 18
[ 7.674014] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu)
[ 7.686010] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 19
[ 7.694077] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu)
[ 7.706033] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 20
[ 7.714097] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu)
[ 7.726062] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 21
[ 7.734133] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu)
[ 7.746091] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 22
[ 7.754145] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu)
[ 7.766098] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 23
[ 7.774190] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu)
[ 7.786153] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 24
[ 7.794207] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu)
[ 7.806185] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 25
[ 7.814235] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu)
[ 7.826213] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 26
[ 7.834265] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu)
[ 7.846226] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 27
[ 7.854287] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu)
[ 7.866246] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 28
[ 7.874309] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu)
[ 7.886273] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 29
[ 7.894314] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu)
[ 7.906275] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 30
[ 7.914364] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu)
[ 7.926340] falcon 15340000.vic: Adding to iommu group 31
[ 7.939981] falcon 15340000.vic: initialized
[ 7.944633] falcon 15380000.nvjpg: Adding to iommu group 32
[ 7.955146] falcon 15380000.nvjpg: initialized
[ 7.959842] falcon 15540000.nvjpg1: Adding to iommu group 33
[ 7.970670] falcon 15540000.nvjpg1: initialized
[ 7.975460] falcon 154c0000.nvenc: Adding to iommu group 34
[ 7.989169] falcon 154c0000.nvenc: initialized
[ 7.993866] falcon 15a50000.ofa: Adding to iommu group 35
[ 8.004119] falcon 15a50000.ofa: initialized
[ 8.008640] nvdec 15480000.nvdec: Adding to iommu group 36
[ 8.025128] nvdec 15480000.nvdec: initialized
[ 8.029730] tsec 15500000.tsec: Adding to iommu group 37
[ 8.043716] tsec 15500000.tsec: initialized
[ 8.051964] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 8.067979] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 8.082801] gpio-394 (camera-control-output-low): hogged as output/low
[ 8.089582] gpio-397 (camera-control-output-low): hogged as output/low
[ 8.096370] gpio-487 (camera-control-output-low): hogged as output/low
[ 8.103166] gpio-486 (camera-control-output-low): hogged as output/low
[ 8.110827] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 8.118009] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 8.125040] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 8.131452] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 8.137888] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 8.144102] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 8.152076] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 8.160643] tegra194-isp5 14800000.isp: Adding to iommu group 38
[ 8.169472] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to U
[ 8.179035] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 8.185594] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 39
[ 8.193720] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 40
[ 8.201777] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled dueU
[ 8.211669] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 8.218495] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled dueU
[ 8.228389] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 8.235194] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled dueU
[ 8.245084] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 8.251921] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 41
[ 8.260669] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18)
[ 8.272067] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 42
[ 8.280794] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19)
[ 8.292205] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 43
[ 8.300911] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20)
[ 8.312328] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 44
[ 8.321053] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21)
[ 8.332444] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 45
[ 8.341192] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22)
[ 8.352620] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 46
[ 8.361347] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23)
[ 8.372733] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 47
[ 8.372790] random: crng init done
[ 8.381438] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24)
[ 8.396055] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 48
[ 8.404782] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25)
[ 8.416172] pva 16000000.pva0: Adding to iommu group 49
[ 8.440905] pva 16000000.pva0: initialized
[ 8.451179] nvdla 15880000.nvdla0: Adding to iommu group 50
[ 8.465193] nvdla 15880000.nvdla0: initialized
[ 8.471374] nvdla 158c0000.nvdla1: Adding to iommu group 51
[ 8.491146] nvdla 158c0000.nvdla1: initialized
[ 8.497337] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[ 8.504508] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 8.511982] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 8.518617] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 8.525350] serial-tegra 3100000.serial: Adding to iommu group 3
[ 8.532281] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud = 0) is a TEGRT
[ 8.541946] serial-tegra 3130000.serial: Adding to iommu group 3
[ 8.548711] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 65, base_baud = 0) is a TEGRT
[ 8.558294] tegra23x-qspi 3270000.spi: Node prod has invalid entries
[ 8.564870] tegra23x-qspi 3270000.spi: Node prod: Child has not proper setting
[ 8.572331] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[ 8.579998] tegra23x-qspi 3270000.spi: Prod settings list not found
[ 8.616961] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Versione
[ 8.626771] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.632356] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 8.641005] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000
[ 8.650654] tegra-xusb 3610000.xhci: irq 235, io mem 0x03610000
[ 8.657109] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.665664] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.673118] usb usb1: Product: xHCI Host Controller
[ 8.678154] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 8.684456] usb usb1: SerialNumber: 3610000.xhci
[ 8.689802] hub 1-0:1.0: USB hub found
[ 8.693701] hub 1-0:1.0: 4 ports detected
[ 8.698079] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.703660] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 8.711480] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 8.719030] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.727584] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.735053] usb usb2: Product: xHCI Host Controller
[ 8.740107] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 8.746412] usb usb2: SerialNumber: 3610000.xhci
[ 8.752028] hub 2-0:1.0: USB hub found
[ 8.755934] hub 2-0:1.0: 4 ports detected
[ 8.794053] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2007000z
[ 8.808110] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2069000z
[ 8.822251] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2011000z
[ 8.834858] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 8.842715] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 8.844926] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.850051] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 8.853461] mmc0: CQHCI version 5.10
[ 8.862976] irq: IRQ302: trimming hierarchy from :interrupt-controller@f400000-1
[ 8.865020] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x00301000
[ 8.872691] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 302
[ 8.881355] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x00400000
[ 8.881551] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 8.904496] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x20800000
[ 8.961218] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 8.977016] mmc0: Command Queue Engine enabled
[ 8.981598] mmc0: periodic cache flush enabled
[ 8.986168] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.993056] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 8.997911] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (511:0)
[ 9.014469] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 9.021219] tegra194-pcie 14100000.pcie: Link up
[ 9.027825] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 9.034659] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 9.040316] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100)
[ 9.050186] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus addre)
[ 9.061050] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 9.069007] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 9.075368] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 9.085394] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 9.091736] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 9.097681] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 9.106132] pci 0001:01:00.0: supports D1 D2
[ 9.110541] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 9.121511] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 9.128964] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 9.129386] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 9.135346] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 9.143776] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.143777] usb 1-3: Product: Bluetooth Radio
[ 9.143778] usb 1-3: Manufacturer: Realtek
[ 9.143779] usb 1-3: SerialNumber: 00e04c000001
[ 9.172551] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 9.178877] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 9.184261] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 9.190540] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 9.197919] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 2
[ 9.206690] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 2
[ 9.215630] pcieport 0001:00:00.0: Adding to iommu group 10
[ 9.221611] pcieport 0001:00:00.0: PME: Signaling with IRQ 51
[ 9.227767] pcieport 0001:00:00.0: AER: enabled with IRQ 51
[ 9.234322] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 9.241799] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 9.248987] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x00361000
[ 9.254123] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 9.257696] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x00400000
[ 9.274190] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x21400000
[ 9.303120] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 9.311552] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.318906] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 9.323655] usb 2-3: Manufacturer: Generic
[ 9.338425] hub 2-3:1.0: USB hub found
[ 9.344459] hub 2-3:1.0: 4 ports detected
[ 9.389367] tegra194-pcie 14160000.pcie: Link up
[ 9.395091] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 9.401919] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 9.407574] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36)
[ 9.417714] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus addre)
[ 9.421358] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 9.428571] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 9.443398] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 9.449739] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 9.459392] pci 0004:01:00.0: [144d:a809] type 00 class 0x010802
[ 9.465763] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 9.478004] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 9.485459] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 9.493441] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 9.498817] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 9.506187] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 2
[ 9.514950] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 2
[ 9.523896] pcieport 0004:00:00.0: Adding to iommu group 11
[ 9.529864] pcieport 0004:00:00.0: PME: Signaling with IRQ 53
[ 9.536022] pcieport 0004:00:00.0: AER: enabled with IRQ 53
[ 9.542083] nvme 0004:01:00.0: Adding to iommu group 11
[ 9.547909] nvme nvme0: pci function 0004:01:00.0
[ 9.552839] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 9.558793] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 9.564466] nvme nvme0: Shutdown timeout set to 8 seconds
[ 9.570918] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 9.575962] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 9.580906] vdd-dp: supplied by vdd-3v3-sys
[ 9.585365] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 9.587036] nvme nvme0: allocated 64 MiB host memory buffer.
[ 9.590461] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 9.604221] tegra194-isp5 14800000.isp: initialized
[ 9.616077] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 9.618730] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 9.624510] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.631012] (NULL device *): fops function table already registered
[ 9.638734] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 9.638737] usb 1-4: Manufacturer: Generic
[ 9.646105] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 9.652002] hub 1-4:1.0: USB hub found
[ 9.653218] nvme nvme0: 12/0/0 default/read/poll queues
[ 9.654878] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 9.655078] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 9.661129] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[ 9.664617] hub 1-4:1.0: 4 ports detected
[ 9.668523] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 302
[ 9.778613] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 9.785806] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a1000
[ 9.794499] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x00400000
[ 9.803190] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x27400000
[ 10.389363] usb 1-4.2: new full-speed USB device number 4 using tegra-xusb
[ 10.508726] usb 1-4.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.1
[ 10.517331] usb 1-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.524856] usb 1-4.2: Product: USB Receiver
[ 10.529257] usb 1-4.2: Manufacturer: Logitech
[ 10.539783] input: Logitech USB Receiver as /devices/platform/3610000.xhci/usb1/1-4/1-4.20
[ 10.609825] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logit0
[ 10.626916] input: Logitech USB Receiver Mouse as /devices/platform/3610000.xhci/usb1/1-41
[ 10.640204] input: Logitech USB Receiver Consumer Control as /devices/platform/3610000.xh2
[ 10.712318] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 10.713435] input: Logitech USB Receiver System Control as /devices/platform/3610000.xhci3
[ 10.734479] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse 1
[ 10.751742] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logi2
[ 10.918680] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 10.924856] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 10.931665] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 10.937308] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a)
[ 10.947428] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus addre)
[ 10.958255] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 10.966185] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 10.972520] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 10.985674] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 10.991071] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 2
[ 11.000020] pcieport 0005:00:00.0: Adding to iommu group 12
[ 11.005983] pcieport 0005:00:00.0: PME: Signaling with IRQ 55
[ 11.012262] pcieport 0005:00:00.0: AER: enabled with IRQ 55
[ 11.018235] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 11.024337] pci 0005:00:00.0: Removing from iommu group 12
[ 11.030004] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 11.037820] nvethernet 6810000.ethernet: Adding to iommu group 52
[ 11.044479] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 11.052658] nvethernet 6810000.ethernet: failed to read MDIO address
[ 11.059222] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 11.066153] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 11.464060] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:82:7a:46
[ 11.472354] nvethernet 6810000.ethernet: Macsec not enabled
[ 11.478100] nvethernet 6810000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 11.489277] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 11.497959] irq: IRQ317: trimming hierarchy from :pmc@c360000
[ 11.503951] irq: IRQ318: trimming hierarchy from :interrupt-controller@f400000-1
[ 11.511652] irq: IRQ319: trimming hierarchy from :pmc@c360000
[ 11.517614] input: gpio-keys as /devices/platform/gpio-keys/input/input5
[ 11.525562] tegra-se-nvhost 15810000.se: Adding to iommu group 53
[ 11.532326] tegra-se-nvhost 15810000.se: initialized
[ 11.548095] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 11.554474] tegra-se-nvhost 15820000.se: Adding to iommu group 54
[ 11.561124] tegra-se-nvhost 15820000.se: initialized
[ 11.568347] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 11.574723] tegra-se-nvhost 15840000.se: Adding to iommu group 55
[ 11.581287] tegra-se-nvhost 15840000.se: initialized
[ 11.588904] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 11.595720] tegra_actmon d230000.actmon: in actmon_register()...
[ 11.602154] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 11.608593] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 11.617022] hvc_sysfs: hypervisor is not present
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
��[ 11.753034] ALSA device list:
[ 11.756093] No soundcards found.
[ 11.760154] Freeing unused kernel memory: 3968K
[ 11.764889] Run /init as init process
[ 11.780171] Root device found: nvme0n1p1
[ 11.784690] Found dev node: /dev/nvme0n1p1
[ 11.881990] EXT4-fs (nvme0n1p1): 3 orphan inodes deleted
[ 11.887465] EXT4-fs (nvme0n1p1): recovery complete
[ 11.895637] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.905235] Rootfs mounted over nvme0n1p1
[ 11.917599] Switching from initrd to actual rootfs
[ 11.969712] systemd[1]: System time before build time, advancing clock.
[ 11.999097] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +S)
[ 12.022824] systemd[1]: Detected architecture arm64.
[ 12.050387] systemd[1]: Set hostname to <surveily-orin-01>.
[ 12.179809] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the lo.
[ 12.192896] systemd[1]: (This warning is only shown for the first unit using IP firewalli)
[ 12.202602] systemd[1]: Created slice system-modprobe.slice.
[ 12.208917] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 12.215770] systemd[1]: Created slice User and Session Slice.
[ 12.221817] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.229902] systemd[1]: Set up automount Arbitrary Executable File Formats File System Au.
[ 12.239681] systemd[1]: Reached target User and Group Name Lookups.
[ 12.246196] systemd[1]: Reached target Slices.
[ 12.250860] systemd[1]: Reached target Mounting snaps.
[ 12.256214] systemd[1]: Reached target Swap.
[ 12.260870] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 12.267747] systemd[1]: Listening on Syslog Socket.
[ 12.272907] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 12.279896] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 12.286854] systemd[1]: Listening on Journal Audit Socket.
[ 12.292634] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.298886] systemd[1]: Listening on Journal Socket.
[ 12.304163] systemd[1]: Listening on udev Control Socket.
[ 12.309832] systemd[1]: Listening on udev Kernel Socket.
[ 12.316444] systemd[1]: Mounting Huge Pages File System...
[ 12.323186] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.330662] systemd[1]: Mounting NFSD configuration filesystem...
[ 12.337972] systemd[1]: Mounting RPC Pipe File System...
[ 12.344635] systemd[1]: Mounting Kernel Debug File System...
[ 12.344892] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 12.358084] systemd[1]: Mounting Kernel Trace File System...
[ 12.365367] systemd[1]: Starting Journal Service...
[ 12.370552] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS b.
[ 12.381274] systemd[1]: Starting Set the console keyboard layout...
[ 12.388878] systemd[1]: Starting Create list of static device nodes for the current kerne.
[ 12.398928] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 12.405840] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 12.415269] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 12.422655] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 12.430006] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 12.437397] systemd[1]: Starting Load Kernel Module ramoops...
[ 12.444635] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 12.452096] pstore: Using crash dump compression: deflate
[ 12.453090] systemd[1]: Started Nameserver information manager.
[ 12.464947] printk: console [ramoops-1] enabled
[ 12.469647] pstore: Registered ramoops as persistent store backend
[ 12.469650] ramoops: using 0x200000@0x82c200000, ecc: 0
[ 12.481591] systemd[1]: Reached target Network (Pre).
[ 12.487826] systemd[1]: Condition check resulted in Set Up Additional Binary Formats bein.
[ 12.497178] systemd[1]: Condition check resulted in File System Check on Root Device bein.
[ 12.508038] systemd[1]: Starting Load Kernel Modules...
[ 12.514443] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.521687] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[ 12.522320] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 12.522791] systemd[1]: Starting udev Coldplug all Devices...
[ 12.539994] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x000000082f006
[ 12.542008] systemd[1]: Started Journal Service.
[ 12.549593] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 12.549599] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000849802
[ 12.549600] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 12.549604] nvmap_page_pool_init: Total RAM pages: 7817180
[ 12.549605] nvmap_page_pool_init: nvmap page pool size: 977147 pages (3816 MB)
[ 12.549652] nvmap_background_zero_thread: PP zeroing thread starting.
[ 12.549738] misc nvmap: created heap vpr base 0x0000000849800000 size (892928KiB)
[ 12.552695] misc nvmap: created heap fsi base 0x000000082f000000 size (16384KiB)
[ 12.597891] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_u0
[ 12.597891]
[ 12.649705] systemd-journald[313]: Received client request to flush runtime journal.
[ 12.901198] nvidia: loading out-of-tree module taints kernel.
[ 13.106790] 1 fixed-partitions partitions found on MTD device spi6.0
[ 13.113844] Creating 1 MTD partitions on "spi6.0":
[ 13.121920] 0x000000000000-0x000004000000 : "Whole_flash0"
[ 13.146680] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 13.159083] gpio gpiochip0: (tegra234-gpio): gpiochip_lock_as_irq: tried to flag a GPIO sQ
[ 13.169848] gpio gpiochip0: (tegra234-gpio): unable to lock HW IRQ 126 for IRQ
[ 13.177413] genirq: Failed to request resources for 1-0008 (irq 323) on irqchip gpio
[ 13.185550] ucsi_ccg 1-0008: request_threaded_irq failed - -5
[ 13.197445] ucsi_ccg: probe of 1-0008 failed with error -5
[ 13.740689] using random self ethernet address
[ 13.745395] using random host ethernet address
[ 13.923090] using random self ethernet address
[ 13.927700] using random host ethernet address
[ 14.942264] Bridge firewalling registered
[ 15.824093] audit: type=1326 audit(1675669663.897:2): auid=4294967295 uid=0 gid=0 ses=4290
[ 16.504524] audit: type=1326 audit(1675669664.577:3): auid=4294967295 uid=0 gid=0 ses=4290
[ 16.530659] audit: type=1326 audit(1675669664.605:4): auid=4294967295 uid=0 gid=0 ses=4290
Ubuntu 20.04.5 LTS surveily-orin-01 ttyTCU0
surveily-orin-01 login: [ 99.458167] BUG: scheduling while atomic: swapper/0/0/0x00000102
[ 99.464906] WARNING: CPU: 0 PID: 0 at kernel/rcu/tree_plugin.h:297 rcu_note_context_switc0
[ 99.474909] ---[ end trace 77006b1ab80bd032 ]---
[ 99.480037] Unable to handle kernel paging request at virtual address ffffd293459f08c0
[ 99.488296] Mem abort info:
[ 99.491560] ESR = 0x96000005
[ 99.494849] EC = 0x25: DABT (current EL), IL = 32 bits
[ 99.500439] SET = 0, FnV = 0
[ 99.503622] EA = 0, S1PTW = 0
[ 99.506871] Data abort info:
[ 99.509864] ISV = 0, ISS = 0x00000005
[ 99.513852] CM = 0, WnR = 0
[ 99.516926] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000763fd2000
[ 99.523849] [ffffd293459f08c0] pgd=000000082c7ff003, p4d=000000082c7ff003, pud=00000000000
[ 99.532849] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 99.538593] Modules linked in: nvidia_modeset(O) fuse esp4 xt_conntrack xt_MASQUERADE nf_e
[ 99.538716] userspace_alert tegra_bpmp_thermal snd_hda_codec_hdmi snd_hda_tegra snd_hda_s
[ 99.650410] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W O 5.10.104-tegra #1
[ 99.658658] Hardware name: /, BIOS 1.0-d7fb19b 08/10/2022
[ 99.664310] pstate: 00400009 (nzcv daif +PAN -UAO -TCO BTYPE=--)
[ 99.670501] pc : cpu_logical_map+0x28/0x40
[ 99.674727] lr : cpu_logical_map+0x1c/0x40
[ 99.678948] sp : ffff800010003880
[ 99.682365] x29: ffff800010003850 x28: ffffd292c5c67d40
[ 99.687842] x27: ffff1927fb602c00 x26: ffff192851797c62
[ 99.693321] x25: ffff1927fb602ad4 x24: ffff1927fb602c28
[ 99.698796] x23: ffff8000100038c0 x22: ffffd292c432ba7c
[ 99.704267] x21: ffff800010003870 x20: ffffd292c430f9f0
[ 99.709746] x19: ffff800010003860 x18: 0000000000000060
[ 99.715217] x17: 0000000000018021 x16: ffffd292c3cf0eac
[ 99.720696] x15: ffffd292c59d2bf0 x14: 0000000000000001
[ 99.726175] x13: ffff8000100eb9c8 x12: 0000000000000002
[ 99.731645] x11: 0000000000000040 x10: ffffd292c59e2250
[ 99.737114] x9 : ffffd292c59e2248 x8 : 0000038de8d75934
[ 99.742582] x7 : 000d4f53d47019c4 x6 : 00000000000002e6
[ 99.748057] x5 : 0000000000000017 x4 : 0000000000000500
[ 99.753525] x3 : 00000000000b38ce x2 : ffffd292c3e7e090
[ 99.758999] x1 : ffffd292c59d45c0 x0 : 0000000000000000
[ 99.764474] Call trace:
[ 99.766989] cpu_logical_map+0x28/0x40
[ 99.770859] Code: 940050f1 9000e7c1 9116a021 91006021 (f873d820)
[ 99.777139] ---[ end trace 77006b1ab80bd033 ]---
[ 99.795396] Kernel panic - not syncing: Oops: Fatal exception
[ 99.801323] SMP: stopping secondary CPUs
[ 99.805533] Kernel Offset: 0x5292b3cc0000 from 0xffff800010000000
[ 99.811820] PHYS_OFFSET: 0xffffe6d940000000
[ 99.816131] CPU features: 0x0040006,4a80aa38
[ 99.820533] Memory Limit: none
[ 99.837214] ---[ end Kernel panic - not syncing: Oops: Fatal exception ]---
