VR not working after Driver update
Version 107
Driver 576 then rolled back to 572.83 to fix it.
Installed latest driver and vr was black screen. Other Steam VR elements worked, just Omniverse not working. Rolled back to Earlier driver but still not working.
Thank you in advance.
This is the error message:
2025-05-18 18:59:36 [104,707ms] [Error] [omni.usd] HydraEngine::render failed to end the compute graph: error code 6
2025-05-18 18:59:36 [104,708ms] [Error] [omni.kit.xr.system.openxr.plugin] EXCEPTION: invalid parameter
2025-05-18 18:59:36 [104,748ms] [Error] [gpu.foundation.plugin] Texture creation failed for the device: 0.
2025-05-18 18:59:36 [104,748ms] [Error] [carb.scenerenderer-rtx.plugin] Failed to allocate 189600x204000 LdrColor resource for device mask 0x1
2025-05-18 18:59:36 [104,748ms] [Error] [omni.usd] HydraEngine::render failed to end the compute graph: error code 6
2025-05-18 18:59:36 [104,749ms] [Error] [omni.kit.xr.system.openxr.plugin] EXCEPTION: invalid parameter
2025-05-18 18:59:38 [107,223ms] [Warning] [omni.kit.renderer.plugin] Reducing ‘/app/runLoops/present/rateLimitFrequency’ from 120.000000 to primary monitor’s refresh rate of 60.000000 (‘Dell U2723QE (HDMI)’, ‘\.\DISPLAY1\Monitor0’)
To close this out, I did a reinstall of kit 107. Thanks
