I am attempting to run the nvsstich_sample for a 360 camera in monoscopic mode. However, I am getting a rather unhelpful error:
XmlUtil: Reading Input Media Feed XML: …/…/footage/video_input.xml
XmlUtil: Reading Stitcher Properties XML: …/…/footage/stitcher_spec.xmlError at line 251: Bad parameter passed
Stitching failed.
Is there a way to dig into what parameter is failing?
Hey aj, did you figure out what was wrong?
I am getting this error
XmlUtil: Reading Input Media Feed XML: …..\footage\video_input.xml
XmlUtil: Reading Stitcher Properties XML: …..\footage\stitcher_spec.xml
XmlUtil: Reading Audio Rig XML: …..\footage\audio_rig_spec.xml
XmlUtil: Reading Input Audio Feed XML: …..\footage\audio_rig_spec.xml
Error at line 307: Failed to initialize decoder
Stitching failed.
Ed, I’m getting the “Failed to initialize decoder” error as well - have you found a solution?
Sorry, the code is too large and complex for me at my level to go through and see why the error is happening so i gave up with Nvidia unfortunately.
Tried to contact support but always received an error when sending so stopped that too.
Got it, I’ll have to reach out to support. Thanks!
Let me know how you get on please
