I’m trying to compile a project using Visual Studio 2010 on Windows 7 64bit with CUDA 5.0.35 (64bit). I need multiple .cu files, so I have to turn on Generate Relocatable Device Code (-rdc=true). Whenever I do that, though, I get the following error at the end of compilation:
nvcc : fatal error : Could not set up the environment for Microsoft Visual Studio using 'c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin/../../common7/Tools/vsvars32.bat'
I’m using “sm_20,compute_20” for Code Generation but have tried 30 and 35 as well with the same results. My card is a 675MX. The project compiles file if I move everything to a single .cu and disable rdc. Obviously that is not an ideal solution. The error occurs on both Release and Debug and I’ve tried a clean rebuild. Any help would be appreciated.
~iondune
