Im using vsan setup with rdma enabled.
I use connect x-6 dual port 100 g nics.
From the switch end, i have changed the max mtu as 9000,however, from the card, i see is max 4096(its printed on the card by default) why its showing like that?
Note, i use DVS from vcenter where i have already set mtu as 9000.
For rdma, previously it was showing as cee mode and tried to change it to ieee mode but no luck from esxi end.
Hi Anatoly,
Happy new year 2023 and thanks for the response.
I have few queries. Could you please help with this?
We use VSAN 8.0 and VSAN traffic goes via 2 * 100 G NIC.“ConnectX-6 Dx EN NIC; 100GbE; dual-port QSFP56; PCIe4.0 x16; (MCX623106AN-CDA)”.
We recently changed the mode from CEE to IEEE as per this article.After changing,now the RDMA mode is showing as “unknown”. I dont know why,My current firmware version of 100G NIC is “22.32.10.14”
2.If we disable the RDMA on 100G NIC,then the NIC will support 9000 MTU ?
3.Do we need to upgrade the latest firmware version? If yes,please suggest the version no for VSAN 8.0
