I ran the quickstart guide with hardware setup done(can see RGB frames. stereo working in realsense-viewer) but I don’t see anything in the rviz viewer.
Kindly help me debug this issue.
Thank you for your post.
Are you running the Isaac ROS RealSense Setup verification before executing vslam as follows?
https://nvidia-isaac-ros.github.io/getting_started/hardware_setup/sensors/realsense_setup.html
Could you please share the logs of ros2 launch file and share the environment information, are you running VSLAM on Orin or x86, what’s platform you’re using?
Thanks,
Ariel
Yes, I ran the realsense-setup before the vslam quickstart guide. I’m running the example on nvidia jetson orin nano developer kit(8GB) with jetpack 6.0. I reflashed the jetson nano, will try to run the example again and share the logs if I still don’t see any output.
