Vulkan Cuda support VK_NVX_binary_import
Since the last Vulkan release (1.2.182.0) there is VK_NVX_binary_import to load and execute cuda bins. I just wanted to ask where I can get a driver that also supports it?
The normal nvidia drivers have supported this extension for quite awhile. 465 and 470 definitely both have it, but I believe much earlier did as well. It’s very poorly documented though.
You are probably right, totally missed that. thanks
Is there any example code out there?
I have Vulkan 1.2.182.0, with a GTX 1050Ti (471.41) but vulkaninfo.exe does not report VK_NVX_binary_import.
Is it available on newer architectures only?
Can’t get it working. Even with the simplest cuda kernel, I get a ERROR_INITIALIZATION_FAILED error when it is loaded with vkCreateCuModuleNVX. I compiled it with nvcc -cubin.
