Vulkan descriptor assertion in UE 5.4.4 editor on headless Linux RTX A5000; ray tracing extensions present but engine reports platform refusal
Environment:
- Unreal Engine 5.4.4 editor, Linux build, running headless on a cloud host (no display attached).
- Renderer: Vulkan. GPU: NVIDIA RTX A5000, driver 535.183.01.
- The application renders and computes normally in every other respect we have measured: direct lighting, materials, and hundreds of captured frames across multiple sessions, with zero shader compile failures.
Finding 1: a descriptor set assertion.
The engine has a debug console variable for global distance field statistics, r.GlobalDistanceField.Debug.ShowStats. It exists and reads “false”. Setting it to “true” is accepted. On the first rendered frame after the set, the editor asserts inside the Vulkan descriptor write path and hangs:
Assertion failed: WriteDescriptors[DescriptorIndex].descriptorType == VK_DESCRIPTOR_TYPE_STORAGE_BUFFER || WriteDescriptors[DescriptorIndex].descriptorType == VK_DESCRIPTOR_TYPE_STORAGE_BUFFER_DYNAMIC [File:Runtime/VulkanRHI/Private/VulkanDescriptorSets.h] [Line: 1016]
No statistics are emitted before the assertion. In the same level and configuration, hundreds of frames across three prior sessions rendered without this assertion; enabling the debug variable was the only changed variable in the session that crashed.
Finding 2: ray tracing extensions present, platform refusal.
Under the SM6 shader platform, the same boot that enumerates the card’s Vulkan ray tracing extensions as present and enabled produces this line at renderer init:
“Ray tracing is disabled. Reason: disabled on current platform.”
On the SM5 shader platform the engine instead reports that Vulkan ray tracing is disabled because the SM6 shader platform is required. We understand the second refusal is an engine platform decision. We are reporting it here only because the extension enumeration and the refusal arrive in the same boot, and the boundary between the driver layer and the engine layer is what we are trying to draw.
What we are asking:
1. Is the descriptor type assertion above a known issue on any driver branch for the RTX A5000 under Linux Vulkan? Does the answer change with driver version, and is there a driver version recommended for Unreal Engine Vulkan workloads on this card?
2. On a headless Linux host with no display attached, in what order does the driver enumerate Vulkan devices? The host is a cloud instance; if any other device (software renderer or management adapter) can enumerate ahead of the A5000, we need to know, because the engine’s capability checks run against whichever device it selects.
3. Are there known descriptor indexing issues on this card or driver family that an engine debug draw or statistics path could trip while normal rendering stays clean?
We are not asking NVIDIA to debug the engine’s lighting. The engine questions are with Epic. These three are the points where the evidence crosses into the driver layer, and they are the ones we cannot measure from inside the guest.
