Vulkan not working on MX130
I have an some older laptop (Dell Latitude 5590) with dual GPU: Intel iGPU + MX130, and I run Gentoo on it with currently installed nvidia-drivers 580.178.04.
I can easily run vkcube or vkgears on iGPU - works flawless. But when trying to run on nvidia gpu with nvx start vkcube|vkgears it crashes:
$ nvx start vkcube
Selected WSI platform: wayland
Selected GPU 0: NVIDIA GeForce MX130, type: DiscreteGpu, apiVersion: 4211000 (1.4.312), driverVersion: -1859354368 (68.712.256)
(exit code: 245)
I was able to trace it to the vkCreateSwapchainKHR call which returns -13 and swapchain value in NULL.
I have currently installed vulkan tools in version 1.4.357.0.
(I have no problem with running glxgears on MX130).
Anyone can help with solving this issue?
is nvx some Gentoo specific utility? If so, you may have more luck asking on Gentoo forums.
Normally, the way to start vkcube on a specific device is by using --gpu_number option. If this also fails, then please provide some more debug info before posting again: ideally an Nvidia bug report file, relevant log excerpts (nvidia|nvrm|nvl|gsp|nouveau), output of vulkaninfo --summary etc…
No, this is just external too to easy switching GPUs in Optimus systems: GitHub - pedro00dk/nvidia-exec: GPU switching without log out for Nvidia Optimus laptops under Linux · GitHub
nvx start app just loads nvidia module, sets env variables and runs the app at nvidia GPU. I run normally on integrated iGPU and want nVidia only for games or so.
I can also use it to load GPU with nvx on, and then:
This works fine:
$ vkcube --gpu_number 1
Selected GPU 1: Intel(R) UHD Graphics 620 (KBL GT2), type: IntegratedGpu, apiVersion: 4211042 (1.4.354), driverVersion: 109060097 (26.2.1
This crashes:
$ vkcube --gpu_number 0
Segmentation violationvkcube --gpu_number 0
This is what happens in my system logs:
Sep  6 23:44:24 coop kernel: pci 0000:03:00.0: [10de:174d] type 00 class 0x030200 PCIe Endpoint
Sep  6 23:44:24 coop kernel: pci 0000:03:00.0: BAR 0 [mem 0xee000000-0xeeffffff]
Sep  6 23:44:24 coop kernel: pci 0000:03:00.0: BAR 1 [mem 0xd0000000-0xdfffffff 64bit pref]
Sep  6 23:44:24 coop kernel: pci 0000:03:00.0: BAR 3 [mem 0xe0000000-0xe1ffffff 64bit pref]
Sep  6 23:44:24 coop kernel: pci 0000:03:00.0: BAR 5 [io  0xe000-0xe07f]
Sep  6 23:44:24 coop kernel: pci 0000:03:00.0: ROM [mem 0x00000000-0x0007ffff pref]
Sep  6 23:44:24 coop kernel: pci 0000:03:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:1c.4 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
Sep  6 23:44:24 coop kernel: pci 0000:03:00.0: BAR 1 [mem 0xd0000000-0xdfffffff 64bit pref]: assigned
Sep  6 23:44:24 coop kernel: pci 0000:03:00.0: BAR 3 [mem 0xe0000000-0xe1ffffff 64bit pref]: assigned
Sep  6 23:44:24 coop kernel: pci 0000:03:00.0: BAR 0 [mem 0xee000000-0xeeffffff]: assigned
Sep  6 23:44:24 coop kernel: pci 0000:03:00.0: ROM [mem 0xef000000-0xef07ffff pref]: assigned
Sep  6 23:44:24 coop kernel: pci 0000:03:00.0: BAR 5 [io  0xe000-0xe07f]: assigned
Sep  6 23:44:24 coop kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Sep  6 23:44:24 coop kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  580.178.04  Tue Jul  7 12:38:21 UTC 2026
Sep  6 23:44:24 coop kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  580.178.04  Tue Jul  7 12:03:04 UTC 2026
Sep  6 23:44:24 coop kernel: [drm] [nvidia-drm] [GPU ID 0x00000300] Loading driver
Sep  6 23:44:25 coop kernel: [drm] Initialized nvidia-drm 0.0.0 for 0000:03:00.0 on minor 1
Sep  6 23:44:25 coop kernel: nvidia 0000:03:00.0: [drm] No compatible format found
Sep  6 23:44:25 coop kernel: nvidia 0000:03:00.0: [drm] Cannot find any crtc or sizes
Sep  6 23:44:25 coop kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Sep  6 23:44:25 coop kernel: vkcube[3084359]: segfault at 180 ip 00007ff0d3b695f3 sp 00007fffce23bf78 error 4 in libnvidia-glcore.so.580.178.04[d695f3,7ff0d3200000+c00000] likely on CPU 1 (core 1, socket 0)
Sep  6 23:44:25 coop kernel: Code: 00 00 c7 45 70 00 00 00 00 e9 f1 fa ff ff 66 0f 1f 84 00 00 00 00 00 4c 8d 5e b0 48 85 f6 b8 00 00 00 00 49 89 d2 4c 0f 44 d8 <45> 8b 8b 80 01 00 00 48 85 c9 74 51 44 39 0a 44 0f 46 0a 45 85 c9
Sep  6 23:44:25 coop kernel: [drm] [nvidia-drm] [GPU ID 0x00000300] Unloading driver
Sep  6 23:44:25 coop kernel: nvidia-modeset: Unloading
Sep  6 23:44:28 coop kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
For iGPU:
VULKANINFO
Vulkan Instance Version: 1.4.357
Instance Extensions: count = 27
VK_EXT_acquire_drm_display             : extension revision 1
VK_EXT_acquire_xlib_display            : extension revision 1
VK_EXT_debug_report                    : extension revision 10
VK_EXT_debug_utils                     : extension revision 2
VK_EXT_direct_mode_display             : extension revision 1
VK_EXT_display_surface_counter         : extension revision 1
VK_EXT_headless_surface                : extension revision 1
VK_EXT_layer_settings                  : extension revision 2
VK_EXT_surface_maintenance1            : extension revision 1
VK_EXT_swapchain_colorspace            : extension revision 5
VK_KHR_device_group_creation           : extension revision 1
VK_KHR_display                         : extension revision 23
VK_KHR_external_fence_capabilities     : extension revision 1
VK_KHR_external_memory_capabilities    : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2         : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2       : extension revision 1
VK_KHR_portability_enumeration         : extension revision 1
VK_KHR_surface                         : extension revision 25
VK_KHR_surface_maintenance1            : extension revision 1
VK_KHR_surface_protected_capabilities  : extension revision 1
VK_KHR_wayland_surface                 : extension revision 6
VK_KHR_xcb_surface                     : extension revision 6
VK_KHR_xlib_surface                    : extension revision 6
VK_LUNARG_direct_driver_loading        : extension revision 1
VK_NV_display_stereo                   : extension revision 1
Instance Layers: count = 12
VK_LAYER_FROG_gamescope_wsi_x86_64 Gamescope WSI (XWayland Bypass) Layer (x86_64)               1.3.221  version 1
VK_LAYER_KHRONOS_validation        Khronos Validation Layer                                     1.4.357  version 1
VK_LAYER_MANGOHUD_overlay_x86_64   Vulkan Hud Overlay                                           1.3.0    version 1
VK_LAYER_MESA_anti_lag             Open-source implementation of the VK_AMD_anti_lag extension. 1.4.303  version 1
VK_LAYER_MESA_device_select        Linux device selection layer                                 1.4.303  version 1
VK_LAYER_MESA_overlay              Mesa Overlay layer                                           1.4.303  version 1
VK_LAYER_NV_optimus                NVIDIA Optimus layer                                         1.4.312  version 1
VK_LAYER_NV_present                NVIDIA GR2608 layer                                          1.4.312  version 1
VK_LAYER_VALVE_steam_fossilize_32  Steam Pipeline Caching Layer                                 1.3.207  version 1
VK_LAYER_VALVE_steam_fossilize_64  Steam Pipeline Caching Layer                                 1.3.207  version 1
VK_LAYER_VALVE_steam_overlay_32    Steam Overlay Layer                                          1.3.207  version 1
VK_LAYER_VALVE_steam_overlay_64    Steam Overlay Layer                                          1.3.207  version 1
Devices:
GPU0:
        apiVersion         = 1.4.354
        driverVersion      = 26.2.1
        vendorID           = 0x8086
        deviceID           = 0x5917
        deviceType         = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
        deviceName         = Intel(R) UHD Graphics 620 (KBL GT2)
        driverID           = DRIVER_ID_INTEL_OPEN_SOURCE_MESA
        driverName         = Intel open-source Mesa driver
        driverInfo         = Mesa 26.2.1
        conformanceVersion = 1.4.0.0
        deviceUUID         = 86801759-0700-0000-0002-000000000000
        driverUUID         = beb33ed6-1b6b-4804-f218-acbcea808065
but for nvidia modules loaded:
ERROR while creating surface for extension VK_KHR_display : /var/tmp/portage/dev-util/vulkan-tools-1.4.357.0/work/Vulkan-Tools-vulkan-sdk-1.4.357.0/vulkaninfo/./vulkaninfo.h:249:vkGetPhysicalDeviceDisplayPropertiesKHR failed with ERROR_UNKNOWN
nvidia-bug-report.log.gz (370.7 KB)
