Vulkan regression report: transform-feedback application breaks between driver 596.49 and 610.x (RTX 3050 Laptop)
A Vulkan application that relies on VK_EXT_transform_feedback for GPU geometry read-back worked reliably on driver 596.49 (32.0.15.9649) and regressed on the 610 branch (first observed on 610.47, still present on 610.74 / 32.0.16.1074, clean-installed). Two distinct, reproducible failures appear on 610 that do not occur on 596.49. Requesting confirmation / guidance / a driver-side fix.
System configuration
  • GPU: NVIDIA GeForce RTX 3050 6GB Laptop GPU (Optimus; hybrid with Intel UHD 770)
  • OS: Windows 11 (build 26200)
  • Last-known-good driver: 596.49 (32.0.15.9649), clean install
  • First-bad driver: 610.47; currently: 610.74 (32.0.16.1074), DDU clean install
  • App stack: D3D11 title → DXVK (D3D11-to-Vulkan) → Vulkan, with a layer that enables VK_EXT_transform_feedback (transformFeedback + geometryStreams) and records vkCmdBeginTransformFeedbackEXT / vkCmdBindTransformFeedbackBuffersEXT to capture vertex output.
Failure 1 — vkCreateDevice regression (feature validation)
On 610.x, vkCreateDevice returns VK_ERROR_FEATURE_NOT_PRESENT (-8) when the pNext chain contains two VkPhysicalDeviceTransformFeedbackFeaturesEXT structures (a duplicate). On 596.49 the identical call succeeds. The Vulkan spec’s rules on duplicate pNext structs are ambiguous, but the behavior changed between branches, breaking previously-working apps. De-duplicating the chain (leaving one instance) makes vkCreateDevice succeed on 610.x — confirming the duplicate struct is what 610 now rejects.
Failure 2 — nvoglv64 crash during transform-feedback capture
After a device is created, the application crashes inside nvoglv64.dll with:
EXCEPTION_ACCESS_VIOLATION reading address 0xFFFFFFFFFFFFFFFF
callstack (top): nvoglv64 → nvoglv64 → nvoglv64 → vulkan-1 → vulkan-1 → d3d11(DXVK)
The 0xFFFFFFFFFFFFFFFF read strongly resembles a failed allocation (-1) being dereferenced. It occurs during transform-feedback capture, which allocates a large (~1.5 GB) capture buffer. Observations:
  • On a fresh boot with free VRAM, capture succeeds and is complete.
  • After prior runs (or on heavier scenes), when free VRAM is low, capture is truncated or crashes at the same point.
  • DXVK reports the device-local heap budget as ~5.1 GiB of the 6 GiB.
What was ruled out (extensive testing 2 weeks of testing)
  • Not the loader: system Vulkan loader is clean/matched 1.4.341.
  • Not VK_EXT_graphics_pipeline_library: toggled on and off, identical behavior.
  • Not the NVIDIA shader disk cache (GLCache/DXCache/D3DSCache): cleared and tested cold vs warm, no correlation.
  • Not driver install cleanliness alone: reproduced on both an in-place rollback and a full DDU clean install of 610.74.
  • Reproduced across two unrelated titles.
Requested help
  1. Was there an intentional change to transform-feedback feature validation (duplicate pNext struct handling) or to transform-feedback + large device-local allocation behavior between 596.49 and 610.x?
  2. Failure 2 looks like a missing allocation-failure check in the transform-feedback path (returning 0xFFFFFFFFFFFFFFFF instead of a VK_ERROR_OUT_OF_DEVICE_MEMORY). Can this be confirmed/fixed?
  3. Any driver setting or workaround on 610.x to restore 596.49 behavior for transform-feedback-heavy Vulkan apps on 6 GB cards?
Happy to provide a minimal repro, full VK_LOADER_DEBUG=all logs, DXVK logs, and crash dumps on request.
