[Vulkan][Windows][616.92 / 617.42][RTX 4070 Ti SUPER] Each vkCreateDevice + vkDestroyDevice leaks 3 process handles
On Windows, every vkCreateDevice + vkDestroyDevice pair leaks exactly 3 kernel handles with drivers 616.92 and 617.42 (GeForce RTX 4070 Ti SUPER). The process handle count (GetProcessHandleCount) grows by 3 per cycle and never returns, also after vkDestroyInstance.
Repro (minimal, below): one VkInstance, then in a loop vkCreateDevice with a single graphics queue, no extensions and no features, vkDeviceWaitIdle, vkDestroyDevice.
Configuration Handles per cycle (50 cycles)
RTX 4070 Ti SUPER, 616.92 3.00
RTX 4070 Ti SUPER, 617.42 3.00
Same, new VkInstance every cycle 3.00
Same, all implicit layers disabled (VK_LOADER_LAYERS_DISABLE=~implicit~; loader log shows the call going straight to nvoglv64.dll) 3.00
AMD Radeon integrated GPU in the same machine, same loader and program 0
D3D12 and OpenGL on the same NVIDIA GPU (create/destroy device) 0
Expected: the handle count returns to its previous value after vkDestroyDevice.
Impact: long-running applications that re-create devices (after device loss, or components that create and dispose a renderer on demand) lose 3 handles per re-creation.
System: Windows 11 Pro 10.0.26300, GeForce RTX 4070 Ti SUPER, drivers 616.92 and 617.42 (Vulkan API 1.4.351), Vulkan loader from the driver package.
Repro (Rust, ash = "0.38", windows = { version = "0.62", features = ["Win32_System_Threading"] }):
use ash::vk;
use windows::Win32::System::Threading::{GetCurrentProcess, GetProcessHandleCount};
fn handles() -> u32 {
    let mut count = 0u32;
    unsafe { GetProcessHandleCount(GetCurrentProcess(), &mut count).unwrap() };
    count
fn main() {
    unsafe {
        let entry = ash::Entry::load().unwrap();
        let app = vk::ApplicationInfo::default().api_version(vk::API_VERSION_1_3);
        let instance = entry.create_instance(&vk::InstanceCreateInfo::default().application_info(&app), None).unwrap();
        let physical = instance.enumerate_physical_devices().unwrap()[0];
        let family = instance
            .get_physical_device_queue_family_properties(physical)
            .iter()
            .position(|f| f.queue_flags.contains(vk::QueueFlags::GRAPHICS))
            .unwrap() as u32;
        let priorities = [1.0f32];
        let queues = [vk::DeviceQueueCreateInfo::default().queue_family_index(family).queue_priorities(&priorities)];
        let cycle = || {
            let device = instance.create_device(physical, &vk::DeviceCreateInfo::default().queue_create_infos(&queues), None).unwrap();
            device.device_wait_idle().unwrap();
            device.destroy_device(None);
        cycle(); // warm-up
        let start = handles();
        for i in 1..=50 {
            cycle();
            if i % 10 == 0 {
                println!("cycle {i}: {:+} handles", handles() as i64 - start as i64);
        instance.destroy_instance(None);
Output with 617.42:
cycle 10: +32 handles
cycle 20: +62 handles
cycle 30: +92 handles
cycle 40: +122 handles
cycle 50: +152 handles
Found while building a headless wgpu-based renderer; the same 3 handles per device show up through wgpu’s Vulkan backend, and not through its D3D12 or OpenGL backends.
