[code]root@3b0b9c604317:/home/samjth/NVIDIA_Transfer_Learning _Toolkit# tlt-train detectnet_v2 -e specs/train_config.txt -r result -k KEY
Using TensorFlow backend.
2019-11-29 04:18:55.397607: I tensorflow/core/platform/cpu_feature_guard.cc:141] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2019-11-29 04:18:55.477263: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:998] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-11-29 04:18:55.477696: I tensorflow/compiler/xla/service/service.cc:150] XLA service 0x698d520 executing computations on platform CUDA. Devices:
2019-11-29 04:18:55.477720: I tensorflow/compiler/xla/service/service.cc:158] StreamExecutor device (0): GeForce GTX 1070, Compute Capability 6.1
2019-11-29 04:18:55.479598: I tensorflow/core/platform/profile_utils/cpu_utils.cc:94] CPU Frequency: 3192000000 Hz
2019-11-29 04:18:55.480523: I tensorflow/compiler/xla/service/service.cc:150] XLA service 0x6aa9c10 executing computations on platform Host. Devices:
2019-11-29 04:18:55.480554: I tensorflow/compiler/xla/service/service.cc:158] StreamExecutor device (0): ,
2019-11-29 04:18:55.480685: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1433] Found device 0 with properties:
name: GeForce GTX 1070 major: 6 minor: 1 memoryClockRate(GHz): 1.7465
pciBusID: 0000:01:00.0
totalMemory: 7.93GiB freeMemory: 7.67GiB
2019-11-29 04:18:55.480715: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1512] Adding visible gpu devices: 0
2019-11-29 04:18:55.481234: I tensorflow/core/common_runtime/gpu/gpu_device.cc:984] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-11-29 04:18:55.481249: I tensorflow/core/common_runtime/gpu/gpu_device.cc:990] 0
2019-11-29 04:18:55.481256: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1003] 0: N
2019-11-29 04:18:55.481311: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 7461 MB memory) â physical GPU (device: 0, name: GeForce GTX 1070, pci bus id: 0000:01:00.0, compute capability: 6.1)
2019-11-29 04:18:55,482 [INFO] iva.detectnet_v2.scripts.train: Loading experiment spec at specs/train_config.txt.
2019-11-29 04:18:55,483 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from specs/train_config.txt
WARNING:tensorflow:From ./detectnet_v2/dataloader/utilities.py:114: tf_record_iterator (from tensorflow.python.lib.io.tf_record) is deprecated and will be removed in a future version.
Instructions for updating:
Use eager execution and:
tf.data.TFRecordDataset(path)
2019-11-29 04:18:55,494 [WARNING] tensorflow: From ./detectnet_v2/dataloader/utilities.py:114: tf_record_iterator (from tensorflow.python.lib.io.tf_record) is deprecated and will be removed in a future version.
2019-11-29 04:18:55,552 [INFO] iva.detectnet_v2.scripts.train: Cannot iterate over exactly 1562 samples with a batch size of 4; each epoch will therefore take one extra step.
WARNING:tensorflow:From /usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/op_def_library.py:263: colocate_with (from tensorflow.python.framework.ops) is deprecated and will be removed in a future version.
Colocations handled automatically by placer.
2019-11-29 04:18:55,558 [WARNING] tensorflow: From /usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/op_def_library.py:263: colocate_with (from tensorflow.python.framework.ops) is deprecated and will be removed in a future version.
WARNING:tensorflow:From /usr/local/lib/python2.7/dist-packages/horovod/tensorflow/init.py:91: div (from tensorflow.python.ops.math_ops) is deprecated and will be removed in a future version.
Deprecated in favor of operator or tf.math.divide.
2019-11-29 04:18:55,570 [WARNING] tensorflow: From /usr/local/lib/python2.7/dist-packages/horovod/tensorflow/init.py:91: div (from tensorflow.python.ops.math_ops) is deprecated and will be removed in a future version.
Layer (type) Output Shape Param # Connected to
input_1 (InputLayer) (None, 3, 2160, 4096 0
conv1 (Conv2D) (None, 64, 1080, 204 9472 input_1[0][0]
bn_conv1 (BatchNormalization) (None, 64, 1080, 204 256 conv1[0][0]
activation_1 (Activation) (None, 64, 1080, 204 0 bn_conv1[0][0]
block_1a_conv_1 (Conv2D) (None, 64, 540, 1024 4160 activation_1[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 540, 1024 256 block_1a_conv_1[0][0]
activation_2 (Activation) (None, 64, 540, 1024 0 block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D) (None, 64, 540, 1024 36928 activation_2[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 540, 1024 256 block_1a_conv_2[0][0]
activation_3 (Activation) (None, 64, 540, 1024 0 block_1a_bn_2[0][0]
block_1a_conv_3 (Conv2D) (None, 256, 540, 102 16640 activation_3[0][0]
block_1a_conv_shortcut (Conv2D) (None, 256, 540, 102 16640 activation_1[0][0]
block_1a_bn_3 (BatchNormalizati (None, 256, 540, 102 1024 block_1a_conv_3[0][0]
block_1a_bn_shortcut (BatchNorm (None, 256, 540, 102 1024 block_1a_conv_shortcut[0][0]
add_1 (Add) (None, 256, 540, 102 0 block_1a_bn_3[0][0]
block_1a_bn_shortcut[0][0]
activation_4 (Activation) (None, 256, 540, 102 0 add_1[0][0]
block_1b_conv_1 (Conv2D) (None, 64, 540, 1024 16448 activation_4[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 540, 1024 256 block_1b_conv_1[0][0]
activation_5 (Activation) (None, 64, 540, 1024 0 block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D) (None, 64, 540, 1024 36928 activation_5[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 540, 1024 256 block_1b_conv_2[0][0]
activation_6 (Activation) (None, 64, 540, 1024 0 block_1b_bn_2[0][0]
block_1b_conv_3 (Conv2D) (None, 256, 540, 102 16640 activation_6[0][0]
block_1b_bn_3 (BatchNormalizati (None, 256, 540, 102 1024 block_1b_conv_3[0][0]
add_2 (Add) (None, 256, 540, 102 0 block_1b_bn_3[0][0]
activation_4[0][0]
activation_7 (Activation) (None, 256, 540, 102 0 add_2[0][0]
block_1c_conv_1 (Conv2D) (None, 64, 540, 1024 16448 activation_7[0][0]
block_1c_bn_1 (BatchNormalizati (None, 64, 540, 1024 256 block_1c_conv_1[0][0]
activation_8 (Activation) (None, 64, 540, 1024 0 block_1c_bn_1[0][0]
block_1c_conv_2 (Conv2D) (None, 64, 540, 1024 36928 activation_8[0][0]
block_1c_bn_2 (BatchNormalizati (None, 64, 540, 1024 256 block_1c_conv_2[0][0]
activation_9 (Activation) (None, 64, 540, 1024 0 block_1c_bn_2[0][0]
block_1c_conv_3 (Conv2D) (None, 256, 540, 102 16640 activation_9[0][0]
block_1c_bn_3 (BatchNormalizati (None, 256, 540, 102 1024 block_1c_conv_3[0][0]
add_3 (Add) (None, 256, 540, 102 0 block_1c_bn_3[0][0]
activation_7[0][0]
activation_10 (Activation) (None, 256, 540, 102 0 add_3[0][0]
block_2a_conv_1 (Conv2D) (None, 128, 270, 512 32896 activation_10[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 270, 512 512 block_2a_conv_1[0][0]
activation_11 (Activation) (None, 128, 270, 512 0 block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D) (None, 128, 270, 512 147584 activation_11[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 270, 512 512 block_2a_conv_2[0][0]
activation_12 (Activation) (None, 128, 270, 512 0 block_2a_bn_2[0][0]
block_2a_conv_3 (Conv2D) (None, 512, 270, 512 66048 activation_12[0][0]
block_2a_conv_shortcut (Conv2D) (None, 512, 270, 512 131584 activation_10[0][0]
block_2a_bn_3 (BatchNormalizati (None, 512, 270, 512 2048 block_2a_conv_3[0][0]
block_2a_bn_shortcut (BatchNorm (None, 512, 270, 512 2048 block_2a_conv_shortcut[0][0]
add_4 (Add) (None, 512, 270, 512 0 block_2a_bn_3[0][0]
block_2a_bn_shortcut[0][0]
activation_13 (Activation) (None, 512, 270, 512 0 add_4[0][0]
block_2b_conv_1 (Conv2D) (None, 128, 270, 512 65664 activation_13[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 270, 512 512 block_2b_conv_1[0][0]
activation_14 (Activation) (None, 128, 270, 512 0 block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D) (None, 128, 270, 512 147584 activation_14[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 270, 512 512 block_2b_conv_2[0][0]
activation_15 (Activation) (None, 128, 270, 512 0 block_2b_bn_2[0][0]
block_2b_conv_3 (Conv2D) (None, 512, 270, 512 66048 activation_15[0][0]
block_2b_bn_3 (BatchNormalizati (None, 512, 270, 512 2048 block_2b_conv_3[0][0]
add_5 (Add) (None, 512, 270, 512 0 block_2b_bn_3[0][0]
activation_13[0][0]
activation_16 (Activation) (None, 512, 270, 512 0 add_5[0][0]
block_2c_conv_1 (Conv2D) (None, 128, 270, 512 65664 activation_16[0][0]
block_2c_bn_1 (BatchNormalizati (None, 128, 270, 512 512 block_2c_conv_1[0][0]
activation_17 (Activation) (None, 128, 270, 512 0 block_2c_bn_1[0][0]
block_2c_conv_2 (Conv2D) (None, 128, 270, 512 147584 activation_17[0][0]
block_2c_bn_2 (BatchNormalizati (None, 128, 270, 512 512 block_2c_conv_2[0][0]
activation_18 (Activation) (None, 128, 270, 512 0 block_2c_bn_2[0][0]
block_2c_conv_3 (Conv2D) (None, 512, 270, 512 66048 activation_18[0][0]
block_2c_bn_3 (BatchNormalizati (None, 512, 270, 512 2048 block_2c_conv_3[0][0]
add_6 (Add) (None, 512, 270, 512 0 block_2c_bn_3[0][0]
activation_16[0][0]
activation_19 (Activation) (None, 512, 270, 512 0 add_6[0][0]
block_2d_conv_1 (Conv2D) (None, 128, 270, 512 65664 activation_19[0][0]
block_2d_bn_1 (BatchNormalizati (None, 128, 270, 512 512 block_2d_conv_1[0][0]
activation_20 (Activation) (None, 128, 270, 512 0 block_2d_bn_1[0][0]
block_2d_conv_2 (Conv2D) (None, 128, 270, 512 147584 activation_20[0][0]
block_2d_bn_2 (BatchNormalizati (None, 128, 270, 512 512 block_2d_conv_2[0][0]
activation_21 (Activation) (None, 128, 270, 512 0 block_2d_bn_2[0][0]
block_2d_conv_3 (Conv2D) (None, 512, 270, 512 66048 activation_21[0][0]
block_2d_bn_3 (BatchNormalizati (None, 512, 270, 512 2048 block_2d_conv_3[0][0]
add_7 (Add) (None, 512, 270, 512 0 block_2d_bn_3[0][0]
activation_19[0][0]
activation_22 (Activation) (None, 512, 270, 512 0 add_7[0][0]
block_3a_conv_1 (Conv2D) (None, 256, 135, 256 131328 activation_22[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 135, 256 1024 block_3a_conv_1[0][0]
activation_23 (Activation) (None, 256, 135, 256 0 block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D) (None, 256, 135, 256 590080 activation_23[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 135, 256 1024 block_3a_conv_2[0][0]
activation_24 (Activation) (None, 256, 135, 256 0 block_3a_bn_2[0][0]
block_3a_conv_3 (Conv2D) (None, 1024, 135, 25 263168 activation_24[0][0]
block_3a_conv_shortcut (Conv2D) (None, 1024, 135, 25 525312 activation_22[0][0]
block_3a_bn_3 (BatchNormalizati (None, 1024, 135, 25 4096 block_3a_conv_3[0][0]
block_3a_bn_shortcut (BatchNorm (None, 1024, 135, 25 4096 block_3a_conv_shortcut[0][0]
add_8 (Add) (None, 1024, 135, 25 0 block_3a_bn_3[0][0]
block_3a_bn_shortcut[0][0]
activation_25 (Activation) (None, 1024, 135, 25 0 add_8[0][0]
block_3b_conv_1 (Conv2D) (None, 256, 135, 256 262400 activation_25[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 135, 256 1024 block_3b_conv_1[0][0]
activation_26 (Activation) (None, 256, 135, 256 0 block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D) (None, 256, 135, 256 590080 activation_26[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 135, 256 1024 block_3b_conv_2[0][0]
activation_27 (Activation) (None, 256, 135, 256 0 block_3b_bn_2[0][0]
block_3b_conv_3 (Conv2D) (None, 1024, 135, 25 263168 activation_27[0][0]
block_3b_bn_3 (BatchNormalizati (None, 1024, 135, 25 4096 block_3b_conv_3[0][0]
add_9 (Add) (None, 1024, 135, 25 0 block_3b_bn_3[0][0]
activation_25[0][0]
activation_28 (Activation) (None, 1024, 135, 25 0 add_9[0][0]
block_3c_conv_1 (Conv2D) (None, 256, 135, 256 262400 activation_28[0][0]
block_3c_bn_1 (BatchNormalizati (None, 256, 135, 256 1024 block_3c_conv_1[0][0]
activation_29 (Activation) (None, 256, 135, 256 0 block_3c_bn_1[0][0]
block_3c_conv_2 (Conv2D) (None, 256, 135, 256 590080 activation_29[0][0]
block_3c_bn_2 (BatchNormalizati (None, 256, 135, 256 1024 block_3c_conv_2[0][0]
activation_30 (Activation) (None, 256, 135, 256 0 block_3c_bn_2[0][0]
block_3c_conv_3 (Conv2D) (None, 1024, 135, 25 263168 activation_30[0][0]
block_3c_bn_3 (BatchNormalizati (None, 1024, 135, 25 4096 block_3c_conv_3[0][0]
add_10 (Add) (None, 1024, 135, 25 0 block_3c_bn_3[0][0]
activation_28[0][0]
activation_31 (Activation) (None, 1024, 135, 25 0 add_10[0][0]
block_3d_conv_1 (Conv2D) (None, 256, 135, 256 262400 activation_31[0][0]
block_3d_bn_1 (BatchNormalizati (None, 256, 135, 256 1024 block_3d_conv_1[0][0]
activation_32 (Activation) (None, 256, 135, 256 0 block_3d_bn_1[0][0]
block_3d_conv_2 (Conv2D) (None, 256, 135, 256 590080 activation_32[0][0]
block_3d_bn_2 (BatchNormalizati (None, 256, 135, 256 1024 block_3d_conv_2[0][0]
activation_33 (Activation) (None, 256, 135, 256 0 block_3d_bn_2[0][0]
block_3d_conv_3 (Conv2D) (None, 1024, 135, 25 263168 activation_33[0][0]
block_3d_bn_3 (BatchNormalizati (None, 1024, 135, 25 4096 block_3d_conv_3[0][0]
add_11 (Add) (None, 1024, 135, 25 0 block_3d_bn_3[0][0]
activation_31[0][0]
activation_34 (Activation) (None, 1024, 135, 25 0 add_11[0][0]
block_3e_conv_1 (Conv2D) (None, 256, 135, 256 262400 activation_34[0][0]
block_3e_bn_1 (BatchNormalizati (None, 256, 135, 256 1024 block_3e_conv_1[0][0]
activation_35 (Activation) (None, 256, 135, 256 0 block_3e_bn_1[0][0]
block_3e_conv_2 (Conv2D) (None, 256, 135, 256 590080 activation_35[0][0]
block_3e_bn_2 (BatchNormalizati (None, 256, 135, 256 1024 block_3e_conv_2[0][0]
activation_36 (Activation) (None, 256, 135, 256 0 block_3e_bn_2[0][0]
block_3e_conv_3 (Conv2D) (None, 1024, 135, 25 263168 activation_36[0][0]
block_3e_bn_3 (BatchNormalizati (None, 1024, 135, 25 4096 block_3e_conv_3[0][0]
add_12 (Add) (None, 1024, 135, 25 0 block_3e_bn_3[0][0]
activation_34[0][0]
activation_37 (Activation) (None, 1024, 135, 25 0 add_12[0][0]
block_3f_conv_1 (Conv2D) (None, 256, 135, 256 262400 activation_37[0][0]
block_3f_bn_1 (BatchNormalizati (None, 256, 135, 256 1024 block_3f_conv_1[0][0]
activation_38 (Activation) (None, 256, 135, 256 0 block_3f_bn_1[0][0]
block_3f_conv_2 (Conv2D) (None, 256, 135, 256 590080 activation_38[0][0]
block_3f_bn_2 (BatchNormalizati (None, 256, 135, 256 1024 block_3f_conv_2[0][0]
activation_39 (Activation) (None, 256, 135, 256 0 block_3f_bn_2[0][0]
block_3f_conv_3 (Conv2D) (None, 1024, 135, 25 263168 activation_39[0][0]
block_3f_bn_3 (BatchNormalizati (None, 1024, 135, 25 4096 block_3f_conv_3[0][0]
add_13 (Add) (None, 1024, 135, 25 0 block_3f_bn_3[0][0]
activation_37[0][0]
activation_40 (Activation) (None, 1024, 135, 25 0 add_13[0][0]
block_4a_conv_1 (Conv2D) (None, 512, 135, 256 524800 activation_40[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 135, 256 2048 block_4a_conv_1[0][0]
activation_41 (Activation) (None, 512, 135, 256 0 block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D) (None, 512, 135, 256 2359808 activation_41[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 135, 256 2048 block_4a_conv_2[0][0]
activation_42 (Activation) (None, 512, 135, 256 0 block_4a_bn_2[0][0]
block_4a_conv_3 (Conv2D) (None, 2048, 135, 25 1050624 activation_42[0][0]
block_4a_conv_shortcut (Conv2D) (None, 2048, 135, 25 2099200 activation_40[0][0]
block_4a_bn_3 (BatchNormalizati (None, 2048, 135, 25 8192 block_4a_conv_3[0][0]
block_4a_bn_shortcut (BatchNorm (None, 2048, 135, 25 8192 block_4a_conv_shortcut[0][0]
add_14 (Add) (None, 2048, 135, 25 0 block_4a_bn_3[0][0]
block_4a_bn_shortcut[0][0]
activation_43 (Activation) (None, 2048, 135, 25 0 add_14[0][0]
block_4b_conv_1 (Conv2D) (None, 512, 135, 256 1049088 activation_43[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 135, 256 2048 block_4b_conv_1[0][0]
activation_44 (Activation) (None, 512, 135, 256 0 block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D) (None, 512, 135, 256 2359808 activation_44[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 135, 256 2048 block_4b_conv_2[0][0]
activation_45 (Activation) (None, 512, 135, 256 0 block_4b_bn_2[0][0]
block_4b_conv_3 (Conv2D) (None, 2048, 135, 25 1050624 activation_45[0][0]
block_4b_bn_3 (BatchNormalizati (None, 2048, 135, 25 8192 block_4b_conv_3[0][0]
add_15 (Add) (None, 2048, 135, 25 0 block_4b_bn_3[0][0]
activation_43[0][0]
activation_46 (Activation) (None, 2048, 135, 25 0 add_15[0][0]
block_4c_conv_1 (Conv2D) (None, 512, 135, 256 1049088 activation_46[0][0]
block_4c_bn_1 (BatchNormalizati (None, 512, 135, 256 2048 block_4c_conv_1[0][0]
activation_47 (Activation) (None, 512, 135, 256 0 block_4c_bn_1[0][0]
block_4c_conv_2 (Conv2D) (None, 512, 135, 256 2359808 activation_47[0][0]
block_4c_bn_2 (BatchNormalizati (None, 512, 135, 256 2048 block_4c_conv_2[0][0]
activation_48 (Activation) (None, 512, 135, 256 0 block_4c_bn_2[0][0]
block_4c_conv_3 (Conv2D) (None, 2048, 135, 25 1050624 activation_48[0][0]
block_4c_bn_3 (BatchNormalizati (None, 2048, 135, 25 8192 block_4c_conv_3[0][0]
add_16 (Add) (None, 2048, 135, 25 0 block_4c_bn_3[0][0]
activation_46[0][0]
activation_49 (Activation) (None, 2048, 135, 25 0 add_16[0][0]
output_bbox (Conv2D) (None, 28, 135, 256) 57372 activation_49[0][0]
output_cov (Conv2D) (None, 7, 135, 256) 14343 activation_49[0][0]
Total params: 23,659,427
Trainable params: 23,606,307
Non-trainable params: 53,120
target/truncation is not updated to match the crop areaif the dataset contains target/truncation.
2019-11-29 04:19:46,833 [INFO] iva.detectnet_v2.scripts.train: Found 1562 samples in training set
2019-11-29 04:19:55,687 [INFO] iva.detectnet_v2.scripts.train: Found 390 samples in validation set
INFO:tensorflow:Create CheckpointSaverHook.
2019-11-29 04:20:01,853 [INFO] tensorflow: Create CheckpointSaverHook.
INFO:tensorflow:Graph was finalized.
2019-11-29 04:20:04,794 [INFO] tensorflow: Graph was finalized.
2019-11-29 04:20:04.794794: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1512] Adding visible gpu devices: 0
2019-11-29 04:20:04.794820: I tensorflow/core/common_runtime/gpu/gpu_device.cc:984] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-11-29 04:20:04.794827: I tensorflow/core/common_runtime/gpu/gpu_device.cc:990] 0
2019-11-29 04:20:04.794834: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1003] 0: N
2019-11-29 04:20:04.794894: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 7461 MB memory) â physical GPU (device: 0, name: GeForce GTX 1070, pci bus id: 0000:01:00.0, compute capability: 6.1)
INFO:tensorflow:Running local_init_op.
2019-11-29 04:20:08,496 [INFO] tensorflow: Running local_init_op.
INFO:tensorflow:Done running local_init_op.
2019-11-29 04:20:08,857 [INFO] tensorflow: Done running local_init_op.
INFO:tensorflow:Saving checkpoints for step-0.
2019-11-29 04:20:26,874 [INFO] tensorflow: Saving checkpoints for step-0.
2019-11-29 04:21:36.984125: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f03b49f00 of size 256
2019-11-29 04:21:36.984135: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f03b4a000 of size 256
2019-11-29 04:21:36.984144: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f03b4a100 of size 256
2019-11-29 04:21:36.984153: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f03b4a200 of size 256
2019-11-29 04:21:36.984162: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f03b4a300 of size 256
2019-11-29 04:21:36.984171: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f03b4a400 of size 14592
2019-11-29 04:21:36.984181: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f03b4dd00 of size 8192
2019-11-29 04:21:36.984191: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f03b4fd00 of size 2211840
2019-11-29 04:21:36.984200: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f03d6bd00 of size 2211840
2019-11-29 04:21:36.984210: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f03f87d00 of size 3964928
2019-11-29 04:21:36.984219: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0434fd00 of size 8388608
2019-11-29 04:21:36.984229: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f04b4fd00 of size 4096
2019-11-29 04:21:36.984238: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f04b50d00 of size 4096
2019-11-29 04:21:36.984247: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f04b51d00 of size 552960
2019-11-29 04:21:36.984256: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f04bd8d00 of size 552960
2019-11-29 04:21:36.984265: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f04c5fd00 of size 991232
2019-11-29 04:21:36.984275: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f04d51d00 of size 2097152
2019-11-29 04:21:36.984284: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f04f51d00 of size 2048
2019-11-29 04:21:36.984294: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f04f52500 of size 2048
2019-11-29 04:21:36.984303: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f04f52d00 of size 524288
2019-11-29 04:21:36.984313: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f04fd2d00 of size 524288
2019-11-29 04:21:36.984322: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05052d00 of size 1024
2019-11-29 04:21:36.984331: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05053100 of size 1024
2019-11-29 04:21:36.984340: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05053500 of size 65536
2019-11-29 04:21:36.984350: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05063500 of size 65536
2019-11-29 04:21:36.984359: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05073500 of size 1024
2019-11-29 04:21:36.984369: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05073900 of size 1024
2019-11-29 04:21:36.984380: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05073d00 of size 256
2019-11-29 04:21:36.984390: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05073e00 of size 256
2019-11-29 04:21:36.984402: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05073f00 of size 147456
2019-11-29 04:21:36.984414: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05097f00 of size 147456
2019-11-29 04:21:36.984425: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f050bbf00 of size 256
2019-11-29 04:21:36.984434: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f050bc000 of size 256
2019-11-29 04:21:36.984444: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f050bc100 of size 16384
2019-11-29 04:21:36.984453: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f050c0100 of size 16384
2019-11-29 04:21:36.984463: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f050c4100 of size 65536
2019-11-29 04:21:36.984472: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f050d4100 of size 65536
2019-11-29 04:21:36.984482: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f050e4100 of size 1024
2019-11-29 04:21:36.984491: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f050e4500 of size 1024
2019-11-29 04:21:36.984500: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f050e4900 of size 256
2019-11-29 04:21:36.984511: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f050e4a00 of size 256
2019-11-29 04:21:36.984520: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f050e4b00 of size 256
2019-11-29 04:21:36.984531: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f050e4c00 of size 256
2019-11-29 04:21:36.984540: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f050e4d00 of size 65536
2019-11-29 04:21:36.984550: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f050f4d00 of size 65536
2019-11-29 04:21:36.984560: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05104d00 of size 147456
2019-11-29 04:21:36.984570: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05128d00 of size 147456
2019-11-29 04:21:36.984580: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f0514cd00 of size 65536
2019-11-29 04:21:36.984591: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0515cd00 of size 65536
2019-11-29 04:21:36.984599: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f0516cd00 of size 1024
2019-11-29 04:21:36.984605: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0516d100 of size 1024
2019-11-29 04:21:36.984613: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f0516d500 of size 256
2019-11-29 04:21:36.984624: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0516d600 of size 256
2019-11-29 04:21:36.984635: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f0516d700 of size 256
2019-11-29 04:21:36.984643: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0516d800 of size 256
2019-11-29 04:21:36.984649: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f0516d900 of size 65536
2019-11-29 04:21:36.984657: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0517d900 of size 65536
2019-11-29 04:21:36.984669: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f0518d900 of size 147456
2019-11-29 04:21:36.984679: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f051b1900 of size 147456
2019-11-29 04:21:36.984689: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f051d5900 of size 65536
2019-11-29 04:21:36.984699: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f051e5900 of size 65536
2019-11-29 04:21:36.984708: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f051f5900 of size 2048
2019-11-29 04:21:36.984718: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f051f6100 of size 2048
2019-11-29 04:21:36.984726: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f051f6900 of size 512
2019-11-29 04:21:36.984737: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f051f6b00 of size 512
2019-11-29 04:21:36.984747: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f051f6d00 of size 589824
2019-11-29 04:21:36.984757: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05286d00 of size 589824
2019-11-29 04:21:36.984764: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05316d00 of size 512
2019-11-29 04:21:36.984774: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05316f00 of size 512
2019-11-29 04:21:36.984785: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05317100 of size 131072
2019-11-29 04:21:36.984797: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05337100 of size 131072
2019-11-29 04:21:36.984807: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05357100 of size 262144
2019-11-29 04:21:36.984818: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05397100 of size 262144
2019-11-29 04:21:36.984829: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f053d7100 of size 2048
2019-11-29 04:21:36.984839: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f053d7900 of size 2048
2019-11-29 04:21:36.984846: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f053d8100 of size 512
2019-11-29 04:21:36.984856: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f053d8300 of size 512
2019-11-29 04:21:36.984865: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f053d8500 of size 589824
2019-11-29 04:21:36.984873: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05468500 of size 589824
2019-11-29 04:21:36.984884: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f054f8500 of size 512
2019-11-29 04:21:36.984892: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f054f8700 of size 512
2019-11-29 04:21:36.984903: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f054f8900 of size 262144
2019-11-29 04:21:36.984912: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05538900 of size 262144
2019-11-29 04:21:36.984923: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05578900 of size 262144
2019-11-29 04:21:36.984933: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f055b8900 of size 262144
2019-11-29 04:21:36.984944: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f055f8900 of size 2048
2019-11-29 04:21:36.984952: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f055f9100 of size 2048
2019-11-29 04:21:36.984961: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f055f9900 of size 512
2019-11-29 04:21:36.984970: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f055f9b00 of size 512
2019-11-29 04:21:36.984986: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f055f9d00 of size 589824
2019-11-29 04:21:36.984997: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05689d00 of size 589824
2019-11-29 04:21:36.985006: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05719d00 of size 512
2019-11-29 04:21:36.985015: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05719f00 of size 512
2019-11-29 04:21:36.985023: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f0571a100 of size 262144
2019-11-29 04:21:36.985032: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0575a100 of size 262144
2019-11-29 04:21:36.985041: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f0579a100 of size 262144
2019-11-29 04:21:36.985050: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f057da100 of size 262144
2019-11-29 04:21:36.985059: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f0581a100 of size 2048
2019-11-29 04:21:36.985068: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0581a900 of size 2048
2019-11-29 04:21:36.985077: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f0581b100 of size 512
2019-11-29 04:21:36.985086: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0581b300 of size 512
2019-11-29 04:21:36.985094: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0581b500 of size 589824
2019-11-29 04:21:36.985103: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f058ab500 of size 589824
2019-11-29 04:21:36.985111: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f0593b500 of size 512
2019-11-29 04:21:36.985119: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0593b700 of size 512
2019-11-29 04:21:36.985128: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f0593b900 of size 262144
2019-11-29 04:21:36.985137: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0597b900 of size 262144
2019-11-29 04:21:36.985146: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f059bb900 of size 262144
2019-11-29 04:21:36.985155: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f059fb900 of size 262144
2019-11-29 04:21:36.985164: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05a3b900 of size 4096
2019-11-29 04:21:36.985174: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05a3c900 of size 4096
2019-11-29 04:21:36.985183: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05a3d900 of size 1024
2019-11-29 04:21:36.985193: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05a3dd00 of size 1024
2019-11-29 04:21:36.985205: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05a3e100 of size 1024
2019-11-29 04:21:36.985215: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05a3e500 of size 1024
2019-11-29 04:21:36.985225: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f1f05a3e900 of size 524288
2019-11-29 04:21:36.985235: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05abe900 of size 524288
2019-11-29 04:21:36.985246: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05b3e900 of size 2359296
2019-11-29 04:21:36.985257: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f05d7e900 of size 2627328
2019-11-29 04:21:36.985266: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06000000 of size 1048576
2019-11-29 04:21:36.985276: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06100000 of size 4096
2019-11-29 04:21:36.985286: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06101000 of size 1024
2019-11-29 04:21:36.985296: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06101400 of size 2359296
2019-11-29 04:21:36.985305: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06341400 of size 1024
2019-11-29 04:21:36.985315: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06341800 of size 1048576
2019-11-29 04:21:36.985325: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06441800 of size 1048576
2019-11-29 04:21:36.985335: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06541800 of size 4096
2019-11-29 04:21:36.985344: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06542800 of size 1024
2019-11-29 04:21:36.985351: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06542c00 of size 1024
2019-11-29 04:21:36.985357: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06543000 of size 1048576
2019-11-29 04:21:36.985365: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06643000 of size 2359296
2019-11-29 04:21:36.985375: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06883000 of size 1048576
2019-11-29 04:21:36.985386: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06983000 of size 4096
2019-11-29 04:21:36.985393: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06984000 of size 1024
2019-11-29 04:21:36.985399: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06984400 of size 1024
2019-11-29 04:21:36.985408: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06984800 of size 1048576
2019-11-29 04:21:36.985418: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06a84800 of size 2359296
2019-11-29 04:21:36.985428: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06cc4800 of size 1048576
2019-11-29 04:21:36.985439: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06dc4800 of size 4096
2019-11-29 04:21:36.985449: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06dc5800 of size 1024
2019-11-29 04:21:36.985460: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f06dc5c00 of size 2359296
2019-11-29 04:21:36.985474: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f07005c00 of size 1024
2019-11-29 04:21:36.985489: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f07006000 of size 1048576
2019-11-29 04:21:36.985501: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f07106000 of size 1048576
2019-11-29 04:21:36.985511: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f07206000 of size 4096
2019-11-29 04:21:36.985526: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f07207000 of size 1024
2019-11-29 04:21:36.985539: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f07207400 of size 2359296
2019-11-29 04:21:36.985548: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f07447400 of size 1024
2019-11-29 04:21:36.985557: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f07447800 of size 1048576
2019-11-29 04:21:36.985567: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f07547800 of size 1048576
2019-11-29 04:21:36.985579: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f07647800 of size 8192
2019-11-29 04:21:36.985588: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f07649800 of size 2048
2019-11-29 04:21:36.985596: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f0764a000 of size 10182656
2019-11-29 04:21:36.985607: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f16000000 of size 4194304
2019-11-29 04:21:36.985619: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f16400000 of size 12582912
2019-11-29 04:21:36.985629: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800000 of size 256
2019-11-29 04:21:36.985640: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800100 of size 256
2019-11-29 04:21:36.985651: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800200 of size 256
2019-11-29 04:21:36.985661: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800300 of size 256
2019-11-29 04:21:36.985669: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800400 of size 256
2019-11-29 04:21:36.985677: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800500 of size 256
2019-11-29 04:21:36.985686: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800600 of size 256
2019-11-29 04:21:36.985695: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800700 of size 256
2019-11-29 04:21:36.985704: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800800 of size 256
2019-11-29 04:21:36.985714: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800900 of size 256
2019-11-29 04:21:36.985724: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800a00 of size 256
2019-11-29 04:21:36.985733: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800b00 of size 256
2019-11-29 04:21:36.985742: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800c00 of size 256
2019-11-29 04:21:36.985751: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800d00 of size 256
2019-11-29 04:21:36.985759: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800e00 of size 256
2019-11-29 04:21:36.985768: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f800f00 of size 256
2019-11-29 04:21:36.985777: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f801000 of size 256
2019-11-29 04:21:36.985786: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f801100 of size 256
2019-11-29 04:21:36.985794: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f801200 of size 256
2019-11-29 04:21:36.985801: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f801300 of size 256
2019-11-29 04:21:36.985810: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f801400 of size 256
2019-11-29 04:21:36.985819: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f801500 of size 256
2019-11-29 04:21:36.985828: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f801600 of size 256
2019-11-29 04:21:36.985837: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f801700 of size 256
2019-11-29 04:21:36.985845: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1f9f801800 of size 256
2019-
2019-11-29 04:21:36.987255: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1fc2a10900 of size 147456
2019-11-29 04:21:36.987263: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1fc2a34900 of size 256
2019-11-29 04:21:36.987273: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1fc2a34a00 of size 16384
2019-11-29 04:21:36.987282: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1fc2a38a00 of size 65536
2019-11-29 04:21:36.987291: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f1fc2a48a00 of size 1024
2019-11-29 04:
experiment_spec.txt (9.73 KB)
