Wake On LAN phy nor working
I connected the phy chip through the RGMII interface of the Orin module on the custom carrier board, and the ENET_RST_N(H5) pin of the Orin module was connected to the reset pin of the phy chip.
We have RGMII working with AGX Orin and L4T 35.3.1
/* EQOS */
ethernet@2310000 {
		status = "okay";
		nvidia,mac-addr-idx = <0>;
		nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA234_MAIN_GPIO(G, 5) 0>;
		phy-mode = "rgmii-id";
		phy-handle = <&phy>;
		/delete-node/ fixed-link;
		mdio {
				compatible = "nvidia,eqos-mdio";
				#address-cells = <1>;
				#size-cells = <0>;
				phy: phy@0 {
						reg = <0>;
						nvidia,phy-rst-pdelay-msec = <224>; /* msec */
						nvidia,phy-rst-duration-usec = <10000>; /* usec */
						interrupt-parent = <&tegra_main_gpio>;
						interrupts = <TEGRA234_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
However, when the Wake On LAN function is enabled, I tap the keyboard to switch the system from hibernation state to wake state. When the system switches from hibernation state to wake state, I detect that the ENET_RST_N(H5) pin of the Orin module will appear a low level pulse for 1 second.
phy chip cann’t work. When the system switches from hibernation state to wake state, how can I make phy chip work normally?
sudo apt-get install ethtool
sudo ethtool -s eth0 wol g
sudo ethtool eth0
ip a
uart.txt (10.1 KB)
dmesg.txt (93.3 KB)
syslog (816.9 KB)
Just to clarify, so is this an issue talking about ethernet fails to work after WoL or this is an issue that WoL itself fails to work?
Ethernet is not working after WoL,I want it to continue to work properly after WOL.
  1. Is this issue able to reproduce with NV devkit?
  2. If you down/up the interface after WoL, will it back to work?
Sorry, I don’t have NV devkit at the moment.
Yes, after WOL, sudo ifconfig eth0 down/up can work normally.
Hi,Is there any new progress?
