hi i’m use jetson agx orin developer kit
when i setting environment this machine for ML
I deleted python3.8 by mistake without thinking dependence
and i reboot machine
nvidia logo display 2seconds and fan is powerfully operate one seconds
and then display off but machine led on
so i want reset this machine
but without recovery mode can’t recognition usb
on recovery mode i can recognition.
but on sdk manager
i can see this notification
The target is in a bad state
The Jetson target is in a bad state and cannot be flashed.
please manually put the target into recovery mode and then retry flashing
on log
10:22:53 INFO: Flash Jetson Linux - flash: [ 1.7578 ] Assuming zero filled SBK key
10:22:53 INFO: Flash Jetson Linux - flash: [ 1.8683 ] Sending applet
10:22:54 INFO: Flash Jetson Linux - flash: [ 2.0772 ] MB2 Applet version 01.00.0000
10:22:54 INFO: Flash Jetson Linux - flash: [ 2.4016 ] MB2 Applet version 01.00.0000
10:22:54 INFO: Flash Jetson Linux - flash: [ 2.5621 ] MB2 Applet version 01.00.0000
10:22:54 INFO: Flash Jetson Linux - flash: [ 2.7558 ] Chip Sample: prod
10:22:55 INFO: Flash Jetson Linux - flash: [ 2.8480 ] MB2 Applet version 01.00.0000
10:22:55 INFO: Flash Jetson Linux - flash: [ 2.9651 ] Saved platform info in /home/yang/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
10:22:55 INFO: Flash Jetson Linux - flash: [ 3.3191 ] MB2 Applet version 01.00.0000
10:22:55 INFO: Flash Jetson Linux - flash: [ 3.4793 ] MB2 Applet version 01.00.0000
10:22:57 INFO: Flash Jetson Linux - flash: — Parsing board ID (3701) succeeded.
10:22:57 INFO: Flash Jetson Linux - flash: “/home/yang/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/flash.sh” jetson-agx-orin-devkit mmcblk0p1
10:22:57 INFO: Flash Jetson Linux - flash: ###############################################################################
10:22:59 ERROR: Flash Jetson Linux - flash: *** ERROR: flashing failed.
10:22:59 ERROR: Flash Jetson Linux - flash: command terminated with error
10:22:59 SUMMARY: DateTime Target Setup - target: Depends on failed component
how can i do to solve this problem
