When the bootloader components(BR-BCT、PSCBL1、MB1…) are updated, they are packed into the Bootloader Update Payload (BUP) and then the UEFI Capsule payload. But how are they writen into the eMMC or NVMe disk when we flash the board for the first time? If i didn’t get this wrong, they shoud be in the “esp” partition in the flash_l4t_nvme.mxl kind of files, right?
I want to collect logs from the bootloader. In “sample-boot-log” section it says: “The message displayed from MB1 is available from an MB1 debug build that has messages enabled. Messages from MB2 are always available.” But i don’t know anything about building the MB1…
In “Rootfs Selection” section: “If the current rootfs fails to boot a specified number of times, cpu-bootloader marks its Status attribute and switches the roles of the current and unused rootfs slots.” Where can i find more material about the cpu-bootloader?
And, in the " Partition Selection" section about bootloader redundancy: " If a bootable slot fails to boot, Bootloader sets its status attribute as unbootable and switches the roles of the current and unused slots." Which part of the bootloader is doing this judgment job? Where can i find more details about it ?
We use the flash_l4t_nvme_rootfs_ab.xml kind of file to define the the partition layout for a redundant file systems. And then we use something like
$ sudo ROOTFS_AB=1 ROOTFS_RETRY_COUNT_MAX=1 ./flash.sh jetson-agx-orin-devkit mmcblk0p1
to flash TWO rootfs into ONE storage device. So my question is: what if i want to flash TWO rootfs into TWO NVMe disk(In order to maintain reliability in the event of possible damage to the storage device)? Should i start with learning the flash.sh script?
Thanks a lot!
Whenever a bootable slot fails to boot, i can find the information in the serial console log, and i do not need to worry about the “MB1 debug” thing, is that right?
As far as i know, UEFI is a standard. What i am looking for is the software tool you use as the “cpu-bootloader”.
Do you mean “EFI System Resource Table”? As metioned above, what i would like to know is: which part of code is do this “boot fail counting” and “A/B slot switching” job?
If it is something open source, maybe i can do some modification to this A/B redundancy mechanism.
If it is not open source, please let me know too.
