Wanted to have clarification about layer fusion within trtexec binary
Hi all, I want to get clarifications on whether the + (plus) symbol before and after a layer name in the trtexec logs indicate that the layers are fused together?.
Please see the below logs. Here it has displayed
[GpuLayer] node_of_gpu_0/conv1_1 + node_of_gpu_0/res_conv1_bn_2 + node_of_gpu_0/pool1_1
Does it mean that layers node_of_gpu_0/conv1_1, node_of_gpu_0/res_conv1_bn_2 and node_of_gpu_0/pool1_1 are all fused together?
Please clarify.
Thanks and Regards
Nagaraj Trivedi
Generally yes but you can find more details with the --verbose flag.
For example:
$ /usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/mnist/mnist.onnx --verbose --buildOnly
[11/16/2023-03:13:43] [I] Finish parsing network model
[11/16/2023-03:13:43] [V] [TRT] Original: 18 layers
[11/16/2023-03:13:43] [V] [TRT] After dead-layer removal: 18 layers
[11/16/2023-03:13:43] [V] [TRT] Applying generic optimizations to the graph for inference.
[11/16/2023-03:13:43] [V] [TRT] Running: ConstShuffleFusion on Parameter193
[11/16/2023-03:13:43] [V] [TRT] ConstShuffleFusion: Fusing Parameter193 with Times212_reshape1
[11/16/2023-03:13:43] [V] [TRT] Running: ConstShuffleFusion on Parameter6
[11/16/2023-03:13:43] [V] [TRT] ConstShuffleFusion: Fusing Parameter6 with (Unnamed Layer* 4) [Shuffle]
[11/16/2023-03:13:43] [V] [TRT] Running: ConstShuffleFusion on Parameter88
[11/16/2023-03:13:43] [V] [TRT] ConstShuffleFusion: Fusing Parameter88 with (Unnamed Layer* 10) [Shuffle]
[11/16/2023-03:13:43] [V] [TRT] After Myelin optimization: 15 layers
[11/16/2023-03:13:43] [V] [TRT] Running: MatMulToConvTransform on Times212
[11/16/2023-03:13:43] [V] [TRT] Convert layer type of Times212 from MATRIX_MULTIPLY to CONVOLUTION
[11/16/2023-03:13:43] [V] [TRT] Running: ConstEltFusion on Parameter6 + (Unnamed Layer* 4) [Shuffle]
[11/16/2023-03:13:43] [V] [TRT] ConstEltFusion: Fusing Parameter6 + (Unnamed Layer* 4) [Shuffle] with Plus30
[11/16/2023-03:13:43] [V] [TRT] Running: ConstEltFusion on Parameter88 + (Unnamed Layer* 10) [Shuffle]
[11/16/2023-03:13:43] [V] [TRT] ConstEltFusion: Fusing Parameter88 + (Unnamed Layer* 10) [Shuffle] with Plus112
[11/16/2023-03:13:43] [V] [TRT] Running: ShuffleShuffleFusion on Times212_reshape0
[11/16/2023-03:13:43] [V] [TRT] ShuffleShuffleFusion: Fusing Times212_reshape0 with reshape_before_Times212
[11/16/2023-03:13:43] [V] [TRT] Running: ConvReshapeBiasAddFusion on Times212
[11/16/2023-03:13:43] [V] [TRT] Running: ConvScaleFusion on Convolution28
[11/16/2023-03:13:43] [V] [TRT] ConvScaleFusion: Fusing Convolution28 with Parameter6 + (Unnamed Layer* 4) [Shuffle] + Plus30
[11/16/2023-03:13:43] [V] [TRT] Running: ConvScaleFusion on Convolution110
[11/16/2023-03:13:43] [V] [TRT] ConvScaleFusion: Fusing Convolution110 with Parameter88 + (Unnamed Layer* 10) [Shuffle] + Plus112
[11/16/2023-03:13:43] [V] [TRT] Applying ScaleNodes fusions.
[11/16/2023-03:13:43] [V] [TRT] After scale fusion: 9 layers
[11/16/2023-03:13:43] [V] [TRT] Running: ConvReluFusion on Convolution28 + Parameter6 + (Unnamed Layer* 4) [Shuffle] + Plus30
[11/16/2023-03:13:43] [V] [TRT] ConvReluFusion: Fusing Convolution28 + Parameter6 + (Unnamed Layer* 4) [Shuffle] + Plus30 with ReLU32
[11/16/2023-03:13:43] [V] [TRT] Running: ConvReluFusion on Convolution110 + Parameter88 + (Unnamed Layer* 10) [Shuffle] + Plus112
[11/16/2023-03:13:43] [V] [TRT] ConvReluFusion: Fusing Convolution110 + Parameter88 + (Unnamed Layer* 10) [Shuffle] + Plus112 with ReLU114
[11/16/2023-03:13:43] [V] [TRT] After dupe layer removal: 7 layers
[11/16/2023-03:13:43] [V] [TRT] After final dead-layer removal: 7 layers
[11/16/2023-03:13:43] [V] [TRT] After tensor merging: 7 layers
[11/16/2023-03:13:43] [V] [TRT] After vertical fusions: 7 layers
[11/16/2023-03:13:43] [V] [TRT] After slice removal: 7 layers
[11/16/2023-03:13:43] [V] [TRT] After concat removal: 7 layers
[11/16/2023-03:13:43] [V] [TRT] Trying to split Reshape and strided tensor
[11/16/2023-03:13:43] [V] [TRT] Graph construction and optimization completed in 0.00541636 seconds.
Hi, thank you for your response. I have verified it. In my case also it is doing the the layer fusion.
I have search taking few words from the log messages related to fusion. For example “Fusing” “fusion” and searched in the entire directory of source code /usr/src/tensorrt/
but could not find in the source that logs this message particularly the any string or sentence containing “fusion” or “Fusing”
Also another clarification which I have is what if I don’t want the layer fusion to happen, then how to disable it?
Please clarify it.
Below are the log messages from where I took the words Fusing and fusion for greping(searching) in the source code.
[11/15/2023-10:24:12] [V] [TRT] Fusing convolution weights from node_of_gpu_0/res5_2_branch2b_1 with scale node_of_gpu_0/res5_2_branch2b_bn_1
[11/15/2023-10:24:12] [V] [TRT] Fusing convolution weights from node_of_gpu_0/res5_2_branch2c_1 with scale node_of_gpu_0/res5_2_branch2c_bn_1
[11/15/2023-10:24:12] [V] [TRT] After scale fusion: 123 layers
[11/15/2023-10:24:12] [V] [TRT] ConvReluFusion: Fusing node_of_gpu_0/conv1_1 with node_of_gpu_0/res_conv1_bn_2
[11/15/2023-10:24:12] [V] [TRT] ConvActPoolFusion: Fusing node_of_gpu_0/conv1_1 + node_of_gpu_0/res_conv1_bn_2 with node_of_gpu_0/pool1_1
[11/1
Thanks and Regards
Nagaraj Trivedi
The optimization is done by default and cannot be turnoff.
