Warehouse Creator Extension. Cannot create warehouse in Isaac Sim WebRTC Streaming Client
Isaac Sim Version
5.1.0
X 5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify): Isaac Sim Headless + WebRTC Streaming Client
Operating System
X Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: 2 x RTX 3080
  • Driver Version:
Topic Description
Detailed Description
I followed the steps in the documentation to install and use the Warehouse Creator Extension in my Isaac Sim: Warehouse Creator Extension — Isaac Sim Documentation
  • Success:
    • Added the extension.
    • Launch Extension: Tools→ Modular Warehouse Creator
    • Set Assets Path to local.
  • FAIL: Draw Warehouse with extension:
    • Click “Build Warehouse”
    • Click (left mouse button) in viewport → Nothing is drawn
Steps to Reproduce
  1. Launch Headless Isaac Sim 5.0 container in remote host
  2. Launch in local host: isaacsim-webrtc-streaming-client-1.0.6-linux-x64.AppImage
  3. Connect with IP
  4. Add to Isaac Sim extension and restart container: omni.warehouse_creator
  5. Launch extension in Isaac Sim:
    1. Fit path to local Asset Library.
    2. Click ‘Build Warehouse’.
    3. Click left mouse button on viewport to try to draw warehouse.
Error Messages
Screenshots or Videos
Additional Information
What I’ve Tried
  • Repeated several attempts and restarted the container.
  • Checked Dev Forum and Discord → Not solution found.
Related Issues
Related Topic: Warehouse Creator: cannot create floor on Isaac Sim - #18 by doremi851225
Additional Context
Does this issue only occur when connecting through the Isaac Sim WebRTC Streaming Client, or can you also reproduce it when using the regular Isaac Sim UI locally (non-WebRTC)?
Hello I am using:
  • Isaac Sim WebRTC Client (isaacsim-webrtc-streaming-client-1.1.5-linux-x64)
  • Isaac Sim 5.1 Headless (official container image with Ubuntu 24.04).
I migrated some weeks ago, before I was using Isaac Sim 5.0, always headless and with WebRTC Client and I had the same issue.
I have not Isaac Sim Desktop locally installed.
Note: In the linked topic I see that this issue seems reproduced from January 2024 in several version of Isaac Sim Desktop: Warehouse Creator: cannot create floor on Isaac Sim - #18 by doremi851225
Thanks for the detailed report and for linking the related thread. This has been confirmed as a known issue, and there is already an internal ticket tracking it. The thread you referenced will be updated once a fix or workaround is available.
Hi, I’m running isaac sim 5.1.0 desktop version on ubuntu 22.04
It seems that I’m running into the same problem as he did.
Can I ask if the bug is fixed now?
This issue is still open and has not been fixed yet. The internal ticket is still tracking it, and this topic will be updated once a fix or workaround is available.
Hi @benjamin.canton and @fn.yang,
Thanks for reporting this issue and for your patience while we investigated.
We confirmed a bug in the Warehouse Creator’s curve-drawing tool that prevented warehouse creation in Isaac Sim 5.0 and 5.1 – this affected both desktop and headless/WebRTC streaming setups.
This has been fixed in the upcoming Isaac Sim 6.0 release, where the Warehouse Creator was completely redesigned. The new version uses a grid-based 2D canvas editor instead of the curve tool, so the underlying issue no longer applies. You can find the updated documentation once 6.0 is publicly available.
Unfortunately, the curve-based tool in 5.0/5.1 will not receive a backported fix.
We recommend upgrading to Isaac Sim 6.0 when it becomes available. If you run into any issues with the new Warehouse Creator, please open a new topic and reference this thread for context.
Thanks for helping us improve Isaac Sim!
