Try to run the Whole-Genome Variant Calling with Deepvariant on dgx-a100 station, and come aross some warning as follows:
[PB Warning 2022-May-25 23:44:59][./inc/common.h:109] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[PB Warning 2022-May-25 23:45:00][./inc/common.h:111] UNKNOWN: Deserialize required 1331536 microseconds.
But it seems that does not effect the normally ending of the program. I just would like to know if the warning bring some negative effection. Thanks.
