Summary
While uninstalling Nsight, a warning may appear with the following text: “Warning 1910. Could not remove Shortcut Nsight HUD Launcher 3.0.lnk. Verify that the shortcut file exists and that you can access it.”
Known Causes
This issue is caused by a bug in the Microsoft Installer. It may occur removing Nsight after installing new NVIDIA graphics drivers.
Solution
The warning is harmless, and the file will be properly removed after the user clicks “OK”.
See More
