I get a lot of these kernel messages, especially when running things like jtop. I can’t seem to find that source file pg-cv-t194.c
in any of the kernel or driver sources. Anyone know where this file is located or which package it comes from? Anyone know what causes it?
I try below on J4.4 didn’t see this message.
sudo apt-get install python-pip python-dev build-essential
sudo pip install --upgrade pip
sudo -H pip install jetson-stats
sudo jtop
That’s odd. I get them even during the boot process. I should have said… These only appear on the serial console and not in any of the logs or even dmesg.
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a069c000
[ 0.000000] Found lut_mem: 00002008@a0696000
��WARNING: at platform/drivers/pg/pg-cv-t194.c:73
WARNING: pll_d2 has no dyn ramp
WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
These prints are from our power and clock management software which is not open source. You can ignore these prints .
We have suppressed these prints in future release. These comes when CCPLEX wants to railgate some rails which is not supported for jetson NX platform.
thanks
Bibek
Thanks for the info!
@Bibek is there a way around these messages. They are making my console unusable.
Are they printk messages I can suppress? I’m on Jetpack 4.4. Is there a binary from Jetpack 4.4.1 that I can swap in?
Use TCU muxer and get only ccplex logs
