I’m currently trying to move a code to GPUs that, like all my code, is quite complex. With this latest attempt, I am seeing a new Warning on the command line that I’ve never seen before:
./cloudnew.001.gpu(1547): Warning: Cannot tell what pointer points to, assuming global memory space
./cloudnew.001.gpu(1548): Warning: Cannot tell what pointer points to, assuming global memory space
./cloudnew.001.gpu(1551): Warning: Cannot tell what pointer points to, assuming global memory space
./cloudnew.001.gpu(1556): Warning: Cannot tell what pointer points to, assuming global memory space
./cloudnew.001.gpu(1563): Warning: Cannot tell what pointer points to, assuming global memory space
I’m a bit puzzled by these. The relevant code in the .gpu file is:
1537 extern "C" __device__ float dqsat(signed char* _ptl,signed char* _ppl,signed char* _pqsat){
1538 float qi;
1539 float dqi;
1540 float dqq;
1541 float qq;
1542 float _rdqsat;
1543 float ti;
1544 float pp;
1545 float uramp;
1546 uramp = _cloudnew_17.m9908;
1547 pp = __fmul_rn((*(float*)(_ppl)), (1.00000000e+02f));
1548 ti = (*(float*)(_ptl))-_cloudnew_17.m9880;
1549 if( !((ti)<=(uramp))) goto _BB_5;
1550 qq = qsatice0(_ptl, ((signed char*)(&pp)), ((signed char*)(&dqsat)));
1551 *(float*)(_pqsat) = qq;
1552 goto _BB_9;
1553 _BB_5: ;
1554 if( !((ti)>=((0.00000000e+00f)))) goto _BB_7;
1555 qq = qsatlqu0(_ptl, ((signed char*)(&pp)), ((signed char*)(&dqsat)));
1556 *(float*)(_pqsat) = qq;
1557 goto _BB_9;
1558 _BB_7: ;
1559 qq = qsatlqu0(_ptl, ((signed char*)(&pp)), ((signed char*)(&dqq)));
1560 qi = qsatice0(_ptl, ((signed char*)(&pp)), ((signed char*)(&dqi)));
1561 ti = ti/uramp;
1562 _rdqsat = dqq+(__fmul_rn(ti, dqi-dqq));
1563 *(float*)(_pqsat) = qq+(__fmul_rn(ti, qi-qq));
1564 _BB_9: ;
1565 return _rdqsat;
1566 }
and the “real” code is:
3277 attributes(device) function DQSAT(TL,PL,QSAT)
3278 real, intent(IN) :: TL, PL
3279 real, intent(OUT):: QSAT
3280 real :: DQSAT
3281 real :: URAMP, TT, WW, DD, DQQ, QQ, TI, DQI, QI, PP
3282 integer :: IT
3283
3284 URAMP = TMIX
3285
3286 PP = PL*100.
3287
3288 TI = TL - ZEROC
3289
3290 if (TI <= URAMP) then
3291 QQ = QSATICE0(TL,PP,DQ=DQSAT)
3292 QSAT = QQ
3293 elseif(TI >= 0.0 ) then
3294 QQ = QSATLQU0(TL,PP,DQ=DQSAT)
3295 QSAT = QQ
3296 else
3297 QQ = QSATLQU0(TL,PP,DQ=DQQ)
3298 QI = QSATICE0(TL,PP,DQ=DQI)
3299 TI = TI/URAMP
3300 DQSAT = TI*(DQI - DQQ) + DQQ
3301 QSAT = TI*(QI - QQ) + QQ
3302 end if
3303
3304 end function DQSAT
So, the warning is thrown when one of the inputs is mentioned, it seems. Now, I will say that there is a QSAT function just above this that looks kinda similar…could I be seeing a name clash? Or maybe it’s related to the other warning I see with this compile?
Any help is appreciated,
Matt
