When I run deepstream-test3 app, I have this warning and processing speed drops.
WARNING from element nvvideo-renderer: A lot of buffers are being dropped. Warning: A lot of buffers are being dropped.
Sometimes, no warnings and speed is quite fast.
I don’t see this WARNING in deepstream_test3_app.c?
Where can I look into so that no such warning happens and speed is running fast?
I tested with 6 sources with resnet34_peoplenet_pruned.etlt model using AGX Xavier.
My config file is as follows.
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
tlt-model-key=tlt_encode
tlt-encoded-model=../../../../samples/models/tlt_peoplenet/resnet34_peoplenet_pruned.etlt
model-engine-file=../../../../samples/models/tlt_peoplenet/resnet34_peoplenet_pruned.etlt_b6_gpu0_fp16.engine
labelfile-path=../../../../samples/models/tlt_peoplenet/labels.txt
int8-calib-file=../../../../samples/models/tlt_peoplenet/cal_trt.bin
input-dims=3;544;960;0
uff-input-blob-name=input_1
batch-size=1
process-mode=1
model-color-format=0
# 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=4
interval=0
gie-unique-id=1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
[streammux]
gpu-id=0
batch-size=1
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
[class-attrs-all]
pre-cluster-threshold=0.2
eps=0.2
group-threshold=1
