PGDBG has encountered an Error.
java.io.IOException : Cannot run program"C:\Proram":Create Process error=2
java.io.IOException:createProcess error=2
Local launch failed
Error in local launch
I started PGDBG, when I press “OPEN”, I see this warning. Could you tell me how can I fix it ?[/code]
What version of PGDBG are you using? See Help | About PGDBG if you’re unsure.
Are you using the Connection tab to set up debugging? If so, what have you specified in the Program field? If not, what OPEN button are you referring to?
Annemarie
