Warning message
When I compile my code, I have this warning message :
"C:\Program Files\Microsoft Visual Studio 8\VC\INCLUDE\wtime.inl", line 50: warn
ing:
          function "_wctime64" (declared at line 257 of "C:\Program
          Files\Microsoft Visual Studio 8\VC\INCLUDE\time.h") was declared
          "deprecated ("This function or variable may be unsafe. Consider
          using _wctime64_s instead. To disable deprecation, use
          _CRT_SECURE_NO_DEPRECATE. See online help for details.")"
      return _wctime64(_Time);
This doesn’t cause error but I’d like to fix it.
Vince
This isn’t a CUDA problem, - a quick google search reveals that the solution is to define these two values by adding them to the command line compiler options:
/D “_CRT_SECURE_NO_DEPRECATE” /D “_CRT_NONSTDC_NO_DEPRECATE”
ooo this takes me back to my first semester of college…eegghh i got goosebumps all over, yucky yuck
I don’t use Visual Studio. I just use its compiler. I’ve already tried to fix it by looking for in the Internet but without success…
I use cygwin to compile my CUDA fonction like that :
nvcc -o main.exe main.cu
I’ve tried to define these two constants
#define _CRT_SECURE_NO_DEPRECATE 1
#define _CRT_NONSTDC_NO_DEPRECATE 1
but the problem still persists…
I’m not sure but passing to compiler is not the same as defines in the code right?
I have no idea. I’ve just tried what I’ve read on some forums…
Try -D_CRT…
that is same as /D I think only on linux but if you use cygwin.
It works perfectly! Thx dude External Image
you welcome no problem.
