Warning messages while running deepstream container
I have the following error and warning messages printed when I try to run a deepstream rtsp-in-rtsp-out example.
I am using nvcr.io/nvidia/deepstream-l4t:6.3-samples image with installing additional packages provided in /opt/nvidia/deepstream/deepstream/user_additional_install.sh
How to resolve these issues?
(Argus) Error FileOperationFailed: Connecting to nvargus-daemon failed: No such file or directory (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 204)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
(gst-plugin-scanner:265): GStreamer-WARNING **: 05:49:12.415: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:278): GStreamer-WARNING **: 05:49:12.417: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:297): GStreamer-WARNING **: 05:49:12.417: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:265): GStreamer-WARNING **: 05:49:12.424: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:278): GStreamer-WARNING **: 05:49:12.425: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:297): GStreamer-WARNING **: 05:49:12.425: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
• Hardware Platform (Jetson / GPU): Jetson Orin Nano
• DeepStream Version: 6.3
• JetPack Version (valid for Jetson only): 5.1.2
• TensorRT Version: 8.5.2.2
This is the gstreamer first startup check, and some plugins require additional libs to use. If it does not affect your use case, you may not need to pay attention.
