[Warning] [omni.physx.tensors.plugin] DEPRECATED: Please use getGeneralizedMassMatrices instead
Hello :)
I updated my Isaacsim to 4.5 because I got some bugs with the tiled rendering of cameras in 4.2. Now after adjusting my code I get this warning:" [omni.physx.tensors.plugin] DEPRECATED: Please use getGeneralizedMassMatrices instead " like every physic step. Is this warning critical? What can I do ? I use an sligthly adapted version of the isaaclab factory environment and there is no explicit usage of omni.physx.tensors.plugin.
Also intersting: When I pause the simulation in gui, I continiue to get this warning-
Thanks in advance :)
Isaac Sim Version
4.5.0
4.2.0
4.1.0
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
Other (please specify):
GPU Information
  • Model RTX 4060TI 16GB:
  • Driver Version: Driver Version: 550.54.14 CUDA Version: 12.4
Additional Information
The warning seems to be triggered, whenever this function is used:
def _compute_intermediate_values(self, dt):
print(“_compute_intermediate_values”)
self.fixed_pos = self._fixed_asset.data.root_pos_w - self.scene.env_origins
self.fixed_quat = self._fixed_asset.data.root_quat_w
    self.held_pos = self._held_asset.data.root_pos_w - self.scene.env_origins
    self.held_quat = self._held_asset.data.root_quat_w
    self.fingertip_midpoint_pos = self._robot.data.body_pos_w[:, self.fingertip_body_idx] - self.scene.env_origins
    self.fingertip_midpoint_quat = self._robot.data.body_quat_w[:, self.fingertip_body_idx]
    self.fingertip_midpoint_linvel = self._robot.data.body_lin_vel_w[:, self.fingertip_body_idx]
    self.fingertip_midpoint_angvel = self._robot.data.body_ang_vel_w[:, self.fingertip_body_idx]
    self.cam_pos = self._robot.data.body_pos_w[:, self.hand_body_idx] # self.scene.env_origins
    self.cam_pos += self.cam_pos_local
    self.cam_quat = torch_utils.quat_mul(self._robot.data.body_quat_w[:, self.hand_body_idx], self.cam_quat_local)
    #delete_prim('/World/envs/vis')
    #cfg_f = FRAME_MARKER_CFG.replace(prim_path="/World/envs/vis")
    #frame_markers = VisualizationMarkers(cfg_f)
    #frame_markers.visualize(translations=self.cam_pos,orientations=self.cam_quat)
    #w_frame_markers = VisualizationMarkers(cfg_f)
    #w_frame_markers.visualize(translations=self.held_pos,orientations=self.held_quat)
    self._wrist_camera.set_world_poses(positions= self.cam_pos,orientations=self.cam_quat, convention =  'world')
    self.hand_grasp_pos = self.fingertip_midpoint_pos.clone()
    #self.hand_grasp_pos[:,2] = self.hand_grasp_pos[:,2] + 0.06
    self.hand_grasp_quat = self.fingertip_midpoint_quat.clone()
    jacobians = self._robot.root_physx_view.get_jacobians()
    self.left_finger_jacobian = jacobians[:, self.left_finger_body_idx - 1, 0:6, 0:7]
    self.right_finger_jacobian = jacobians[:, self.right_finger_body_idx - 1, 0:6, 0:7]
    self.fingertip_midpoint_jacobian = (self.left_finger_jacobian + self.right_finger_jacobian) * 0.5
    self.arm_mass_matrix = self._robot.root_physx_view.get_mass_matrices()[:, 0:7, 0:7]
    self.joint_pos = self._robot.data.joint_pos.clone()
    self.joint_vel = self._robot.data.joint_vel.clone()
    # Finite-differencing results in more reliable velocity estimates.
    self.ee_linvel_fd = (self.fingertip_midpoint_pos - self.prev_fingertip_pos) / dt
    self.prev_fingertip_pos = self.fingertip_midpoint_pos.clone()
    # Add state differences if velocity isn't being added.
    rot_diff_quat = torch_utils.quat_mul(
        self.fingertip_midpoint_quat, torch_utils.quat_conjugate(self.prev_fingertip_quat)
    rot_diff_quat *= torch.sign(rot_diff_quat[:, 0]).unsqueeze(-1)
    rot_diff_aa = axis_angle_from_quat(rot_diff_quat)
    self.ee_angvel_fd = rot_diff_aa / dt
    self.prev_fingertip_quat = self.fingertip_midpoint_quat.clone()
    joint_diff = self.joint_pos[:, 0:7] - self.prev_joint_pos
    self.joint_vel_fd = joint_diff / dt
    self.prev_joint_pos = self.joint_pos[:, 0:7].clone()
    #if self.print_stuff: print("Update: ", self.held_pos[0,:])
    # Keypoint tensors.
    self.held_base_quat[:], self.held_base_pos[:] = torch_utils.tf_combine(
        self.held_quat, self.held_pos, self.held_base_quat_local, self.held_base_pos_local
    self.hand_base_quat[:],self.hand_base_pos[:] = torch_utils.tf_combine(
         self.hand_grasp_quat, self.hand_grasp_pos,self.hand_grasp_quat_local,self.hand_grasp_pos_local
    #in this context the target_held == the held base as the gripper should close on the the held object
    self.target_held_base_quat = self.held_base_quat
    self.target_held_base_pos = self.held_base_pos
    # Compute pos of keypoints on held asset, and fixed asset in world frame
    for idx, keypoint_offset in enumerate(self.keypoint_offsets):
        self.keypoints_held[:, idx] = torch_utils.tf_combine(
            self.held_base_quat,
            self.held_base_pos, #+ self.scene.env_origins,
            self.identity_quat,
            keypoint_offset.repeat(self.num_envs, 1)
        )[1]
        self.keypoints_hand[:, idx] = torch_utils.tf_combine(
            self.hand_base_quat ,
            self.hand_base_pos, #+self.scene.env_origins,
            self.identity_quat,
            keypoint_offset.repeat(self.num_envs, 1),
        )[1]
    if self.debug and False:
        self.draw.clear_points()
        self.draw.clear_lines()
        """num_keypoints = len(self.keypoint_offsets)
        all_held_points = self.keypoints_held #+ self.scene.env_origins
        all_held_points = all_held_points.view(-1, 3).cpu().tolist()  # Alle Environment-Keypoints
        #all_held_points = self.keypoints_held.view(-1, 3).cpu().tolist()
        all_hand_points = self.keypoints_hand #+ self.scene.env_origins
        all_hand_points = all_hand_points.view(-1, 3).cpu().tolist()
        #all_hand_points = self.keypoints_hand.view(-1, 3).cpu().tolist()
        # 2. Farb- und Größenlisten generieren
        held_colors = [(1, 0, 0, 1)] * (self.num_envs * num_keypoints)  # Rot fĂĽr alle Held-Keypoints
        hand_colors = [(1, 1, 0, 1)] * (self.num_envs * num_keypoints)  # Gelb fĂĽr Hand-Keypoints
        sizes = [10] * (self.num_envs * num_keypoints)
        # 3. Batch-Zeichnung aller Punkte
        self.draw.draw_points(all_held_points, held_colors, sizes)
        self.draw.draw_points(all_hand_points, hand_colors, sizes)"""
    #keep the noisy action frame up to date which helps clipping the movments
    _, fixed_tip_pos = torch_utils.tf_combine(
        self.held_quat, self.held_pos, self.identity_quat, self.held_base_pos_local)
    self.fixed_pos_obs_frame[:] = fixed_tip_pos
    self.fixed_pos_action_frame[:] = self.fixed_pos_obs_frame + self.init_fixed_pos_obs_noise
    # get keypoint distances
    self.keypoint_dist = torch.norm(self.keypoints_hand - self.keypoints_held, p=2, dim=-1).mean(-1)
    self.last_update_timestamp = self._robot._data._sim_timestamp
Error Messages
2025-03-26 20:22:19 [19,768ms] [Warning] [omni.physx.tensors.plugin] DEPRECATED: Please use getGeneralizedMassMatrices instead.
2025-03-26 20:22:19 [19,785ms] [Warning] [omni.physx.tensors.plugin] DEPRECATED: Please use getGeneralizedMassMatrices instead.
2025-03-26 20:22:19 [19,801ms] [Warning] [omni.physx.tensors.plugin] DEPRECATED: Please use getGeneralizedMassMatrices instead.
2025-03-26 20:22:19 [19,818ms] [Warning] [omni.physx.tensors.plugin] DEPRECATED: Please use getGeneralizedMassMatrices instead.
The answer was:
update: self.arm_mass_matrix = self._robot.root_physx_view.get_mass_matrices()[:, 0:7, 0:7]
to: self.arm_mass_matrix = self._robot.root_physx_view.get_generalized_mass_matrices()[:, 0:7, 0:7]
Hi @ujixa, that is correct and glad you found the answer. Also, thanks for sharing it!
